    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 07-27-2014, 09:13 AM   #6361
Tech Legend
Wild Cherry's Avatar
Andrew
Were just using the lead , its cheap and is not expensive .
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 07-27-2014, 09:37 AM   #6362
hey Andrew. you really only need the brass blocks if conditions are really loose.. like dry dusty. I like them better then just adding weight as it puts it in the very lowest and farthest back portion of the car.
rickster is offline   Reply With Quote
Old 07-27-2014, 01:13 PM   #6363
I have a b5m running on a clay indoor track that has a little push going into corners and does not have the same low end punch as the other 17.5's. I was told to lighten up the tranny with an aluminum top shaft, mip puc system, nova slipper, bfast diff and b5 front a arms and shock tower. Any suggestions or advise if I'm going in the right direction or additional mods. Thanks.
gearit is offline   Reply With Quote
Old 07-27-2014, 01:32 PM   #6364
mxracer458's Avatar
Trader Rating: 47 (100%+)
lol and 250 bucks later….and don't forget to charge at 40amps otherwise you won't have a chance
mxracer458 is offline   Reply With Quote
Old 07-27-2014, 01:41 PM   #6365
I honestly would just get the lightened top shaft, and invest in a better motor. The cars so light you shouldn't have any issues with low end, maybe mess with your timing/gearing. On my car I use the b5 rear and front arms and b5 front shock tower
bh796B is offline   Reply With Quote
Old 07-27-2014, 02:20 PM   #6366
suby723's Avatar
Trader Rating: 21 (100%+)
My 17.5 roller has about $500 invested lmao and thats including a slrc lightened chassis. Sitting at 1505 grams and dialed. I like mod so I built another b5m.. what a cruel hobby this is sometimes!
The slrc chassis has been mentioned alot on Facebook in the b5 nation but just if you havent heard the details..
6061 aluminum, .5 thinner over stock chassis, about 24grams lighter. Dropped .3 off my fastest lap time and highly recommend this chassis if your serious about stock racing.
Team Associated RC10 B5m Mid-Motor Thread-screenshot_2014-07-27-13-23-26.jpg
suby723 is offline   Reply With Quote
Old 07-27-2014, 02:25 PM   #6367
vito's Avatar
Originally Posted by Wild Cherry View Post
Andrew
wc this car is awesome ran it some need to get it on the track bad
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 07-27-2014, 02:42 PM   #6368
chonchachencho's Avatar
Can you post a link good man
chonchachencho is offline   Reply With Quote
Old 07-27-2014, 02:58 PM   #6369
thanks for the non information, sorry to bother you with meaningless questions.
Old 07-27-2014, 03:21 PM   #6370
Tech Legend
I just added a thin piece of lead under
my short pack, weights 2.8 oz more but Oman !!
Drives better then ever....
If you try ?
Use the inside hole on rear tower
rear shock 2x 1.6 piston,35w oil &
B5r rear plastic arm ..
Money......
George W. Cherry
Old 07-27-2014, 03:36 PM   #6371
Trader Rating: 20 (100%+)
I can't find a website that sells it. Where did you
buy the SLRC chassis?
GTSSTANG is offline   Reply With Quote
Old 07-27-2014, 04:18 PM   #6372
suby723's Avatar
If you try ?
Money......
Your running a mod car im not even going to argue with you why a lighter car is better in stock racing! Lap times dont lie..all im saying. In stock you are better off being at 1499grams.
Old 07-27-2014, 04:20 PM   #6373
suby723's Avatar
Search "Stiky liks rc painting" on Facebook.
Old 07-27-2014, 04:23 PM   #6374
Tech Legend
If you try what we are doing ?
Your ride will be a lot smoother and consistent in the corner.
More grip too...
BTW
my ride is at 59.6 oz ,1672
Lighter is not necessarily better...
More weight under the battery will help you more then lighter parts every where else on the car ..
Huge difference...a game changer in my book
George W. Cherry
Old 07-27-2014, 06:01 PM   #6375
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
More grip too...
BTW
I don't know about that. It's probably because I race stock, but lighter has always been faster for me. I'm down to 1460 race weight. I had to go to softer spring more oil and lower roll centers but it is faster.
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
