    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 07-26-2014, 08:22 AM   #6346
SilentHunter's Avatar
Originally Posted by Cridd View Post
What are the reasons for using the offset caster block bushings? What is the change to the car and why?
http://www.amain.com/product_info.ph...lock-Bushing-4
I run these and a couple guys at the track do too. More exit speed when coming out of turns.
SilentHunter is offline   Reply With Quote
Old 07-26-2014, 08:23 AM   #6347
Tech Legend
Wild Cherry's Avatar
Try it out for your self, learn how it feels on the track.
When you try it out note how much more difficult accelerating out of the corner with the axle raised.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 07-26-2014, 08:24 AM   #6348
Racing stock ang you get your car to 1500 grams, what shock packages change should be made from stock set up of 32.5 white fronts and green rear?
2x1.6 all around 32.5 front 30 rear. Green or white rears and grey or white fronts. I'm running green rear and grey fronts on a Med to high bite clay track.
Old 07-26-2014, 09:43 AM   #6349
Cridd's Avatar
Trader Rating: 16 (100%+)
fronts look good, just need to get 1.7s out to 1.6 and drop weight on oil.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 07-26-2014, 09:44 AM   #6350
Trader Rating: 485 (100%+)
If I got my car down to 1500g I'd run green/green. I did not like the way my car felt last night with the 3500mah lipo which put me at 1510 or so. I run white/green 37.5/32.5.
Now that I've discovered the ignore list I plan to use it.....14 and counting!
QDRHRSE is offline   Reply With Quote
Old 07-26-2014, 11:17 AM   #6351
djhSPAWN's Avatar
I could use some advice. I'm racing today and there is one double that halfway through the qualifier when I start to notice a slight fade and it causes me to just come up a few inches short. I am currently running 34/69. What should I move to for just a hair more top speed? I should note that the current gearing gives me temps of 135 max.
SC10 / DEX210
djhSPAWN is offline   Reply With Quote
Old 07-26-2014, 11:49 AM   #6352
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
Increase motor timing, leave gearing alone.
Kevin Van Ert | MFR | CRC Racing | Team Scream Racing | Hobbywing | Xenon USA | Dumpers Speed Shop | Genesis RC | Race Rewards | Lake Superior RC Car Club | www.lsrcc.com
Kave is offline   Reply With Quote
Old 07-26-2014, 12:01 PM   #6353
djhSPAWN's Avatar
I wish I could, but it's all Novak stock system that does not seem to have the timing on the motor. I should of noted that.
SC10 / DEX210
Old 07-26-2014, 12:36 PM   #6354
In that case, gear up.
Old 07-26-2014, 12:55 PM   #6355
elex300's Avatar
Trader Rating: 102 (100%+)
If its a Novak SS (Silver can with a purple label) motor with the colored timing ring then you can turn the timing up. Its just not marked on the can. Just loosen the screws as you would for any motor and turn the colored ring.
Erik Everett
EZ Customs (Rc Painting) www.facebook.com/ezcustomspainting
Jconcepts - Trinity/Revtech - Xtreme Hobbies - RCADDICTION Products
elex300 is offline   Reply With Quote
Old 07-26-2014, 08:47 PM   #6356
JatoTheRipper's Avatar
Originally Posted by Wildcat1971 View Post
are you running +4? or +3?
+4. I'm starting with the stock setup since this is my first buggy ever.
Originally Posted by RickSlick View Post
I will probably get some kickback on this comment but just want to throw this out to all of you.
I own the following offroad AE cars, Rc8.2e, B4.1, RC10 4X4 and now the B5M.
I was always been impressed at Associated's quality, engineering, build plans, but have some criticism on the B5M.
I know it is great to save weight, reduce size but I think the AE crew went too far with the B5M. The 2 biggest problems I have encountered are ones which do not have to be given just a little more room in the chassis and a little more height on the body.
1. If the front area were just a little bit wider, perhaps 10-15mm, I would not have had to buy an extra small reciever to fit along side the ESC.
2. If the body height had been just 10mm higher, I would not have be installing the low profile 4mm battery bullets to keep wire height down so I can fit the body far enough down to velcro it to the sides of the chassis.
I know many will say the engineers put a lot of work into design, but would just a little larger area in these places REALLY matter that much in performance? I am disappointed in how I needed to buy unnecessarily different parts to accommodate this recent build.
Rick
The battery hold down screw posts are what screwed me. I think they're poorly placed.
The manual needs work. It's wrong in a couple of places. I also thing certain things should have better notes.
Leaf Spring Mafia - Member #1
https://www.shapeways.com/shops/leafspringmafia
https://www.facebook.com/LeafSpringMafia
https://www.instagram.com/LeafSpringMafia
JatoTheRipper is offline   Reply With Quote
Old 07-26-2014, 10:28 PM   #6357
Tech Legend
Like using the B5r plastic arm using the inside hole for the shock on the rear tower.
Redid my oil and bump the rear oil up to 35w for tommorow race.
Using the heavier oil to slow down the roll.
Also
Installing a thin piece of lead under the shorty lining the whole tray.
O yeah , that's right adding weight. Oman.
George W. Cherry
Old 07-27-2014, 08:02 AM   #6358
Andrew Selvaggi's Avatar
I've been reading a lot of people adding led underneath the shorty, or weight on the rear tower. But haven't read anything about those running the brass toe blocks.
Are those who are adding weight just trying to add total weight to the car to settle it down, or is it for more rear grip? To me the brass blocks would be the first point of call in my mind. Just looking for peoples opinion as I haven't seen a lot using the brass.
Team Associated ~ JConcepts ~ Hobby Wing ~ Team Orion ~ nVision ~ Sav÷x ~ Upgrade RC
Andrew Selvaggi is offline   Reply With Quote
Old 07-27-2014, 08:05 AM   #6359
Tech Legend
Extra weight ???
More stability & traction for sure..
George W. Cherry
Old 07-27-2014, 08:07 AM   #6360
Razathorn's Avatar
First day out with the b5m outdoors. The 1.7 tapered worked great. Made a few changes for low traction conditions. Went to zero caster inserts and 3mm trailing axle. Car was amazing.
AE B6D / AE B44.3 / AE RC10WC / AE RC8B3
Razathorn is offline   Reply With Quote
