    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree10Likes
Old 07-24-2014, 12:13 PM   #6286
Trader Rating: 71 (100%+)
Originally Posted by hcopp View Post
he still had to click a link though. Two as a matter of fact!
I was just showing my work for the answer provided.
negatv1 is offline   Reply With Quote
Old 07-24-2014, 12:16 PM   #6287
hey bubonic.. no my car isn't twitchy.. its perfectly dialed... what I was saying is instead of saying never use an adjustment , maybe try it .. granted it wont be right for every track but if your running on a really loose track where everyone is searching for traction the a speed adjustment on servo is good. if your running on good traction you don't need to worry about it..
same with epa.. you use them as just another tuning option. anything to give you an advantage helps.. that's why the companies put those things into the radios.
hope that helps.
rickster is offline   Reply With Quote
Old 07-24-2014, 12:50 PM   #6288
ray_munday's Avatar
Originally Posted by gticlay View Post
Oohhhhhh Myyyyyy does this look good! B5M Finnisher.
http://blog.jconcepts.net/2014/07/jc...innisher-body/
New front alloy brace?
Team Associated Factory Driver: B6/B6D, B64D, SC5M
JConcepts Factory Driver: Tyres, Rims, Wings, Bodies & Accessories
Reedy Factory Driver: Blackbox 510R ESC, Sonic 3 BL motors, Lipo
KO Propo EX-1 KIY_____www.keilorrc.com.au
Check out my help thread: http://www.rctech.net/forum/10587838-post1.html
ray_munday is offline   Reply With Quote
Old 07-24-2014, 01:00 PM   #6289
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I am sure. new motor plate too from the pics. The AE alloy brace is crap. But in either car, the plastic one is fine. The bumper offers not protection so the brace will look like crap in a week or 2.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 07-24-2014, 01:56 PM   #6290
hope that helps.
Why did you say it was twitchy? Nope I make changes to my setup As everybody else said they dont change the servo speed they make other changes doesnt make any sense to me to slow down the speed of the servo.
That really doesnt help... Do what you want But Im not
Bubonic-X is offline   Reply With Quote
Old 07-24-2014, 01:58 PM   #6291
Trevor Williams's Avatar
Trader Rating: 195 (100%+)
George Cherry.....what is a good base starting setup for indoor, damp, medium bite and technical...90x60 I think and we run black/green JC barcodes and dirt webs....thanks
Reedy 8.0 w/ LRP flow works team...reedy 3800 wolfpack
RC10-B6d | RC10-B64d
SmacTrac
#WeAreAE #ReedyPower #AE4Life
Trevor Williams is offline   Reply With Quote
Old 07-24-2014, 06:36 PM   #6292
hey bubonic.. no I said if your driving on a really loose track and you are using a really fast servo it can make your car twitchy... or at least that's what I meant..
I also said that if your on a high traction track you don't need to worry about it.. I also said it works better on some cars more then others.
with the traction you have in az you don't need to worry about it.. if your running on a really loose dirt track that's kinda dry and you have super fast steering chances are good you will spin out nomatter what 2wd your driving. if you slow down the steering it makes it easier to control the corners. and I said its used as just another tuning option.
no worries though.. you guys have some sweet tracks down there. and the days of really loose tracks seem to be fading away more and more. now I am hearing rumors a couple places want to do carpet outdoor offroad tracks so they don't have to water or worry about the dust. we may all be running on tracks like in Europe next..lol
Old 07-24-2014, 08:34 PM   #6293
BillPear's Avatar
Send a message via Yahoo to BillPear
Spencer, still running "Gull Wing" arms.
BillPear is offline   Reply With Quote
Old 07-24-2014, 09:07 PM   #6294
lbckevin's Avatar
Trader Rating: 91 (99%+)
just a photo car
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 07-24-2014, 09:09 PM   #6295
Ostach24's Avatar
Trader Rating: 85 (100%+)
Hey, just picked up a b5m. Will my old centro bodies fit nice or will I need to paint up some new ones? Also any idea on eta for the finnisher body?
Cobra Graphics
For all your graphic design needs.
CobraGraphics.net
Ostach24 is offline   Reply With Quote
Old 07-24-2014, 09:11 PM   #6296
lbckevin's Avatar
Centro bodies fit...just a slight trim.
The new finnisher body is available now.
Kevin Smith
Old 07-25-2014, 07:56 AM   #6297
Rybeau40's Avatar
So everyone leaves the sever at 100% speed on the controller and just adjusts the EXP or EPA on the controller to help tune out twitch?
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 07-25-2014, 08:00 AM   #6298
well, I normally try to tune it out on the car. mine was too twitchy when it was soft. I stiffened the front up and it was great
Old 07-25-2014, 08:05 AM   #6299
Trader Rating: 20 (100%+)
First, I use EPA to stop the servo from over traveling and make sure left and right turn in equally.
I then use dual rate right on the transmitter handle. It is an on-the-fly-adjustment with your thumb.
On a big sweeping track, you might turn it down to 80% ,this way you don't over steer the car. On a tight track, you may want more travel so you set it higher.
GTSSTANG is offline   Reply With Quote
Old 07-25-2014, 08:47 AM   #6300
Yep, servo at 100% - set EPA to set the hard travel end points (dont allow servo to push further than it physically can or needs to go), and like others have said can use dual rate to take equal throw out of the steering range on the fly if needed.
Expo for steering has always just felt weird to me. Steering is something that feels best when is linear with the turning of the radio wheel (or stick if you are that guy). I think it can make useful for throttle feel if you are into that sort of thing.
Chances are your car itself is just twitchy (tires, general setup,etc) and/or you just need to get used to it more. Even with the fastest of servos, the actual travel should be linear to the turning of the wheel.
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
Crazyybikerdude
