    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree15Likes
Old 07-20-2014, 04:31 AM   #6136
Trader Rating: 117 (98%+)
is there a motor fan that will work for this car.
ashxxx is offline   Reply With Quote
Old 07-20-2014, 09:42 AM   #6137
Default Need 1500 Gram Set Up Suggestions
Dropping approximately 60 grams (new battery) and would like to hear from those who are already running 1500 gram set ups. Looking for shock oil, springs, ride height, etc info.
Micah123 is offline   Reply With Quote
Old 07-20-2014, 03:01 PM   #6138
racer_guy's Avatar
must be almost ready...finnisher for the b5m.
W.E.D. Winning Edge Designs
racer_guy is offline   Reply With Quote
Old 07-20-2014, 03:08 PM   #6139
mxracer458's Avatar
Trader Rating: 47 (100%+)
so i finally got to run my mm last night,it was also my first time running a mid motor card period,my car is bone stock, i run stock also. it was set up box setup and it was ok just a little loose for the 1st couple packs,so i switched my arms over the rm front and rear arms. Ran it again and it helped out a lot but still wasn't satisfied on how the car was running,granted i didn't have the typos everyone was using but traction was coming up.My 1st qualifier i ended up 2nd in the heat but 13th overall out of 33 or so buggies,and there was a lot of chassis sponsored guys running stock because there was no mod,i would say the top 7 were chassis sponsored guys. That first round i ran m3 ions and i just couldn't push it like i wanted to. So the next round i went to 3/2 rear inserts and .5 in my rear hubs and ran ss handlebars,My car was much better and i felt i could push it a little harder and ran a 20.073 and the fast sponsored guys were running 19.2s i believe.I felt i had the car in the right direction. So my main was up and i put the soft ions back on thinking i could push it a little more with this tires since i was 6th in the b,boy my car was stuck like velcro and it was hard to drive,i think i was running 5th and i was getting plowed by one car corner after corner (didn't think he knew how to use brakes) and finally he spun me into a pipe and i ended up 7th in the b. Not were i wanted to finish but the class had some heavy hitter and for someone with no expectations other then trying to make the car good i felt like it was a good night. So i can't wait to get some more wheels time on the car and see what else i can do with it,not to shabby for a bone stock heavy car
mxracer458 is offline   Reply With Quote
Old 07-20-2014, 06:11 PM   #6140
What would you guys recommend for a cost saving decent stock only ESC? I am building a RM (sold my slash and even though I don't need it I wanted to build another car). My mm I have a RS Gen2 because the "stock" class at one of the tracks I will run at allows boost and what not. But for the RM I want to run straight stock to get started. Is it worth it to go for a high end esc or are there any low end ones that I really wouldn't notice a difference on. Id probably get a D4 or another killshot as the motor, unless there is any reason to get anything different.
Thanks for any advice!
hcopp is offline   Reply With Quote
Old 07-20-2014, 06:32 PM   #6141
Light, cheap and works great:
http://www.falconsekido.com/products...k-esc-for-1-10
34x17 is offline   Reply With Quote
Old 07-20-2014, 06:33 PM   #6142
Jcozz's Avatar
Trader Rating: 20 (95%+)
Looks like a c4.2 finnisher. I know lots of guys are running them. I run my c4.2 finnisher body on my rear motor and mid motor.
Jared Cozzocrea
HobbyPro PRS1 / HobbyPro SB401 / Fusion Graphics / Mayor RC
Premier RC Raceway and Hobbies
Dave's RC Tracks
Jcozz is offline   Reply With Quote
Old 07-20-2014, 06:49 PM   #6143
racer_guy's Avatar
not arguing with you on that one. there are alot of ppl that use them. the only thing is though, is that rivkin, cav, and hartson are running these at the hotrod shootout that is happening right now. and pw @ jconcepts said they would be an aug. release or maybe sooner. just speculation.
Old 07-20-2014, 06:56 PM   #6144
Jcozz's Avatar
I can't wait to get one!! Finnisher bodies Are definately my favorite.
Jared Cozzocrea
Dave's RC Tracks
Old 07-20-2014, 07:33 PM   #6145
Tech Legend
Wild Cherry's Avatar
Hcoop
alot of good racers around here went to the Orion..
But they all purchased the less expensive
Stock stock spec version and they use it in mod
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 07-20-2014, 09:28 PM   #6146
senneville's Avatar
Finish to read all 410 pages And i decided to up grade to b5m. Tank you guy's
senneville is offline   Reply With Quote
Old 07-20-2014, 09:55 PM   #6147
Jake S's Avatar
Trader Rating: 66 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
Originally Posted by Wild Cherry View Post
Hcoop
http://www.horizonhobby.com/products...s--ORI65120#t1
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 07-20-2014, 10:12 PM   #6148
Tech Legend
Yes that is the one Jake, thanks..
inexpensive & smooth
And
A top brand ..
Tip:
Check your steering rack out.
If it's smooth on top , your good ..
You have installed correctly.
But some here may have not ....Bad...
A common mistake that often does not get caught.
George W. Cherry
Old 07-20-2014, 10:13 PM   #6149
Jake S's Avatar
inexpensive , smooth a top brand name.
cant find the manual for it, but i saw on orions site it says its good down to a 5.5 on 2s.
Old 07-21-2014, 07:04 AM   #6150
I can definitely swing the orion, but at that point id probably stick with another RS Gen 2 as I have the hotwire setup and what not.
I was more curious about the hobby wing stuff. As I said this would be for pure stock 17.5 blinky.
When I want to step up that car I would probably go for an orion pro or something. For ~$60 will it do what I need it to do? Better way to phrase the question - Will I be at a huge disadvantage running the hobby wing stock vs someone with a "better" ESC?
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
Crazyybikerdude
