    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 07-16-2014, 12:41 AM   #6046
Tech Legend
Wild Cherry's Avatar
Originally Posted by Micah123 View Post
need to rebuild my diff and see only carbide balls from ae. anyone use steel balls from mpi in their b5m ball diff? not getting more than 1 build out of carbide so thinking I might go steel and save some money
Skip the carbide and go ceramic , they they will never wear out .
That saves you lots of money.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 07-16-2014, 01:44 AM   #6047
racer_guy's Avatar
so was a little confused about the aluminum shock mounts. ive heard you need short ones and regular ones. and ive heard one or the other...so i emailed team ae and this was the response i recieved...
"Thank you for contacting customer support. You will want to get the standard ones all the way around. You will also need #91447. These are the shock bushings."
so there is your answer if you have the same question i did
W.E.D. Winning Edge Designs
racer_guy is offline   Reply With Quote
Old 07-16-2014, 06:20 AM   #6048
thought I read there is some sort of downside to ceramics
Micah123 is offline   Reply With Quote
Old 07-16-2014, 06:26 AM   #6049
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
narrower tuning range, because the balls bite less.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-16-2014, 07:10 AM   #6050
If i were to just stock up on balls. would this be a bad move?
http://www.craigballsales.com/3-32-2...lot-of-25.html
hcopp is offline   Reply With Quote
Old 07-16-2014, 07:34 AM   #6051
I dont know anything about those, but they are a good price. while your at it, might as well get his 2mm ones for the thrust.
Old 07-16-2014, 08:44 AM   #6052
Tech Legend
Who ever told you that has misinform.
They also say carbide performs better but the facts are ...
No differences in performance , big savings on never having to repurchase diff balls for each rebuild.
George W. Cherry
Old 07-16-2014, 09:19 AM   #6053
kdeleon's Avatar
My latest rebuild of my diff I went to ceramics. I have to say that I'm a convert. It wasn't any harder to dial in exactly the right amount of tension for the diff. Seemed as easy. I did go slow but never missed my target and had to back off or the other way around. If they do last, then I will keep using them going forward.
kdeleon is offline   Reply With Quote
Old 07-16-2014, 09:27 AM   #6054
Tech Legend
My first set of Ae ceramics ?
Purchase them for my B4 two years ago..
They went to my C4 ...
I just stole them from the C4 & installed in a Gt2 now.
Dang , my Gt2 has never had a smoother diff....
Can't wear the ceramic out ..
George W. Cherry
Old 07-16-2014, 09:47 AM   #6055
BRSracing's Avatar
Trader Rating: 55 (100%+)
When I spoke to AE they told me short bushings for the MM regular length for RM. However the stock bushings that come with the mm and rm are the same, so I am not sure why they suggested the short for the aluminum.
BRSracing is offline   Reply With Quote
Old 07-16-2014, 11:16 AM   #6056
racer_guy's Avatar
hmm...thats odd
Old 07-16-2014, 11:41 AM   #6057
ended up ordering 3 sets of ceramic balls from acer racing - $6.99 for 14. can't beat that.
With all of this diff talk.... the outdrives should be totally fine, right? not really a way those can get damaged except on the outside of em?
Old 07-16-2014, 12:53 PM   #6058
AE-Reedy
The tall shock mounts can be used on both ends of the car for B5 or B5M.
They are the same as the kit shock bushings
The short mounts are intended only for the rear of the B5M. They line the shock up a little better than the tall one. No big deal really just a little better shock angle.
Sean Cochran is offline   Reply With Quote
Old 07-16-2014, 08:22 PM   #6059
Rybeau40's Avatar
So, I upgraded my bearings to the new AE blue ones, but still having issues with my front left bearings going bad and not being able to tighten the wheel down to far so it can still spin. I've tried a new crush tube, but still the same issue. Any suggestions?
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 07-16-2014, 08:22 PM   #6060
thecman26's Avatar
Trader Rating: 99 (100%+)
I buy mine in bulk on ebay, pretty cheap and great quality!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
