    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 06-24-2014, 01:52 PM   #5566
Speed Freak RC's Avatar
Originally Posted by mschumi101 View Post
Now that I think about it, this would be true. If the car had 0 degrees of kickup/caster in the front, then it shouldn't affect it... correct? But with the buggies having 25-30 degrees, it would somewhat affect toe. But only in small increments as you stated. My mistake! Thanks for pointing that out.
Kickup & Caster have nothing to do with it. It's because you have 3 points (arm mount, camber link mount, steering link mount) that are stabilizing the wheel. So when the top camber link mount moves in relation to the arm mount, the steering mount which is in the middle will be affected. That's why we have bump steer adjustment, to combat the changes to the steering mount as the relation of the arm mount and camber link mount change as the suspension moves.
Speed Freak RC is offline   Reply With Quote
Old 06-24-2014, 05:06 PM   #5567
brad996's Avatar
Originally Posted by [email protected] View Post
Just wanted to share for those like me that are just trying without letting go their TLR cars.
I did this mod a while ago on my team-c vehicule so ive re-use it on the b5m. Ive cut the 22 front hex and drill them bigger. Used cuntershunk screw and a 1mm spacer to get same offset.
So how does the car drive ? Did you notice any difference from the stock wheels ? I had a set of stock hexes cut down and the car was so nervous I couldn't drive it with losi wheels. I think the offset difference is 4.5mm per side.
SIRCS, Asylum Xtreme
TLR 22 4.0, TLR 22 3.0 lay down, TLR 22-4 2.0 Yokomo BD8/SV, Yokomo YR10F
brad996 is offline   Reply With Quote
Old 06-24-2014, 05:41 PM   #5568
J@UNE's Avatar
I did mesure 4.20mm difference in offset and I'm at 4.05mm with the shim. Should be very close. I can still play with inner shim if needed. Will see how it goes tomorrow.
Jon Gagnon
DirtTrax - Team FLR
J@UNE is offline   Reply With Quote
Old 06-24-2014, 05:54 PM   #5569
TOO-TALL's Avatar
Anyone have a fix for all the play in front wheel bearings?thought the play was in the trailing inserts so I glued them in this got rid of alot of the play, but there is still more I would like to get rid of.I can see the screw holding the axle in moveing around....maybe aftermarket bearings??
www.skyski.com
www.foilforum.com
"Hey Baby want to make fourteen dollars...the hard way??" ----Rodney Dangerfield--Caddyshack.
TOO-TALL is offline   Reply With Quote
Old 06-24-2014, 07:59 PM   #5570
gticlay's Avatar
Thought I'd share a pic of my B5M with the new PL VTR rims/tires. I haven't had the chance to run them yet but here's my ride!
gticlay is offline   Reply With Quote
Old 06-24-2014, 08:07 PM   #5571
Jake S's Avatar
Trader Rating: 66 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
let us know i was looking at the electrons
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 06-24-2014, 08:27 PM   #5572
I run the AKA EVO series on mine, love them. Much more stable and less ballooning at full throttle.
Old 06-24-2014, 08:40 PM   #5573
gticlay's Avatar
That was one thing I noticed - way less ballooning just playing around with the car on my workstand.
Old 06-24-2014, 08:56 PM   #5574
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
Finishing up the body/wing on my build, and had a question: How are you guys mounting the wing, as far as which holes are you using? Do you have it further forward or further off the back? How does this affect the handling?
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 06-24-2014, 08:57 PM   #5575
BIGSKI15's Avatar
Trader Rating: 18 (100%+)
I'm on vacation and one of the indoor tracks is carpet. I ended with Michael schoettler's set up because tcrc is said to have very high traction. I also installed a gear diff with 3000 weight oil.
The shop carries a lot of carpet tires and they suggested dboots terabytes in either A or B compound. I ran B compound only because they were out of A.
It is very good although I wish that I had gray springs to try.
It was my first time ever on carpet so I really wasn't sure but it has been great so far.
Also, there are carpet set ups on petitrc.com.
Originally Posted by Jcozz View Post
Just converted one of my b5's to a B5M. Super easy conversion. Took about 1.5hr and it's a mid now! Anybody have a good starting set up for indoor ozite carpet? One of My local tracks just went carpet and have no clue where to start besides putting in a gear diff And lowering ride height.
B6D
B5M
Airtronics M12
BIGSKI15 is offline   Reply With Quote
Old 06-24-2014, 09:13 PM   #5576
gticlay's Avatar
White to gray makes quite a big difference.
Old 06-24-2014, 09:56 PM   #5577
Tech Legend
Wild Cherry's Avatar
Big Skill
Will ask Mike right now what to do & report back.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 06-25-2014, 12:53 AM   #5578
Just had a blast with my mm. We had a new track open that runs an all clay track...holy traction. I had to get a new set of tires in clay compound lol. Awesome set up at the new SRS. I sucked it up but had a blast. My normal track is medium/high traction but this clay had such good grip and my MM really came to life!
scythe23 is offline   Reply With Quote
Old 06-25-2014, 06:05 AM   #5579
Buggy kid90's Avatar
I just rebuilt my shocks a week ago with the low friction rings and I'm using the blue csi piston all I can say is wow it's crazy how much those low friction rings make a difference and I'm lovin the csi pistons if you guys haven't tried them you should. http://www.amain.com/product_info.ph...ton-Set-Blue-4
Buggy kid90 is offline   Reply With Quote
Old 06-25-2014, 07:40 AM   #5580
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
How were your temps in 17.5 at SRS?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
JsK
