    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree10Likes
Old 06-03-2014, 11:27 PM   #5026
Chief's Avatar
Trader Rating: 14 (100%+)
Originally Posted by Wildcat1971 View Post
I would just use a little locktite
Thanks. Worked out!
____________
TC6
B4.1
FT SC10
Chief is offline   Reply With Quote
Old 06-03-2014, 11:41 PM   #5027
if you have a small receiver it should fit. if you have a sr300....welll then it wont
The case is pretty thick....
mk2rocco is offline   Reply With Quote
Old 06-04-2014, 04:13 AM   #5028
Rybeau40's Avatar
What ball cups does everyone use with their titanium turnbuckles. Kit ones?
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 06-04-2014, 04:39 AM   #5029
TRyan's Avatar
That's what I do. works great.
TRyan is offline   Reply With Quote
Old 06-04-2014, 05:38 AM   #5030
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
he said is esc was not very small. The tekin is probably smallest receiver, and you barely got it to fit. Anyway, some people are putting the receivers on the sides. You just have to play with it
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-04-2014, 08:12 AM   #5031
Tech Legend
Wild Cherry's Avatar
A 4W's extra weight & lower ride height ?
Go figure ...
Must have something do with it slapping on landings easier then
the 2w.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 06-04-2014, 08:28 AM   #5032
Rybeau40's Avatar
My 4wd weighs less than my old 2.0 mod class buggy. If you're slapping, the tuning is off...shouldn't matter whether 2 or 4. Different vehicle, different tuning. 2wd will always be harder to drive and better to learn on.
Futaba 4PLS
Support your LHS.
Old 06-04-2014, 08:43 AM   #5033
vito's Avatar
need to fine a esc like a tekin rs gen 2 to run a fantom apex 17.5 be a good set up
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 06-04-2014, 09:00 AM   #5034
Mason's Avatar
in regards to 4wd chassis slap, its part tuning and part throttle happy drivers.
Anyways, back on topic. Can't wait for the offset shoulder bushings to come in..
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 06-04-2014, 09:07 AM   #5035
I saw Maiflied and Rivkin slapping. You jump long enough and flat land, you can slap a MM no problem. Saw RM's do the same jump and land dead silent. I would think the RM would slap more with all of that weight over 2 shocks.
Old 06-04-2014, 10:43 AM   #5036
t0p_sh0tta's Avatar
Trader Rating: 35 (100%+)
Depends on the car and the shock package.
B44s are slap monsters, but they run 20-22mm ride height. They used to make even more racket when people ran lexan chassis protectors.
Regarding 2WD slap, MM will generally slap more because you're using a shock package with softer dampening to aid in weight transfer.
For those running mod, how are you liking the B5M? I've been off for a few months and thinking about making the move back to a MM buggy. Any of you running on med to low grip tracks?
I've met some of the strangest people while playing with my toy cars...
t0p_sh0tta is offline   Reply With Quote
Old 06-04-2014, 12:03 PM   #5037
Rybeau40's Avatar
Agree.
Futaba 4PLS
Support your LHS.
Old 06-04-2014, 12:03 PM   #5038
Some guys swear the MM works outdoors on low bite. But, my experience has been a big no. Mainly because an outdoor watered track can greatly change mid heat and the car becomes hard to drive. On, the upside, if you get a MM and dislike it, the mm to rm conversion is pretty cheap, lol. The RM to MM is more pricey to convert
Old 06-04-2014, 02:42 PM   #5039
Trader Rating: 20 (100%+)
Hey Wild Cherry, I am looking to try a different setup. I am running 17.5 with the MIP Puck system ready to go in, could you suggest a good setup for stock?
GTSSTANG is offline   Reply With Quote
Old 06-04-2014, 02:53 PM   #5040
Send a message via ICQ to JiuHaWong
Originally Posted by fredswain View Post
Whether a car is 2wd or 4wd has exactly zilch to do with if the chassis slaps on landings or not.
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Crazyybikerdude
