    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree10Likes
Old 06-03-2014, 12:01 PM   #5011
Rybeau40's Avatar
Originally Posted by Wildcat1971 View Post
huh? the rear "should" work fine. I use tlr 22 rears on my b5. The fronts have a completely different off set. Your car will be narrow in the front.
Thus, my question. People have talked about the clamp hexes and I though part of the reason people want those is due to the fact they allow you to run other rims such as tlr style etc...
I may have misunderstood, so wanted to ask if I can use the crate of tires/rims I have for my tlr 22 2.0 or do I need to stock up on new rims/tires.
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 06-03-2014, 12:06 PM   #5012
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
People want clamping hexes because they are pretty. Oh and the fear that the axle screw might come out. The rear will fit fine, I switched from 22 to b5 and use my rear just fine. But, it is a no go on the fronts. I think the offset is so far off that you can not even shim it out.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-03-2014, 01:03 PM   #5013
Tower finally got the conversions in stock, so my backup RM car will be MM very soon.
Old 06-03-2014, 01:14 PM   #5014
offroad dude's Avatar
Trader Rating: 25 (100%+)
You better get 1 while they say stock is limited because they will sellout fast.
offroad dude is offline   Reply With Quote
Old 06-03-2014, 05:04 PM   #5015
bilster44's Avatar
Lol! The 4th gear (second idler) is there so the car will go "forward" with the motor and gear box mounted essentially "backwards", as opposed to a rear motor car.
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 06-03-2014, 05:05 PM   #5016
yeah, I placed my order already.
Old 06-03-2014, 05:13 PM   #5017
eper's Avatar
Trader Rating: 14 (100%+)
"not into debating which is to drive Ryeau
My reason for such a statement
#1 4w requires far more throttle control because you can't just lift power & glide flat on landings. Lift power all the way & expect a big nose dive with 4w. Driver needs to hold more on power throttle in the corner as well.
2w has far better suspension & can land harder with no slap.
4w has to be landed on every down hill ramp off the jumps and has to be driven smoother.
A wheeler is a must have tool in any pit"
4wd is just different. Any wheel time is good but running a 2wd buggy is the hardest class to run consistently and takes the most finess. If u can drive a 2wd buggy good u can drive anything
As for the 3 vs4 gear tranny. It changes the rotation direction. If U ran a three gear tranny in mm when you jump throttle and braking would have the opposite effect that it does on rm.
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 06-03-2014, 05:16 PM   #5018
bilster44's Avatar
Punch it!
Old 06-03-2014, 08:10 PM   #5019
gticlay's Avatar
You just reverse the motor rotation. Durango has the 3 gear option.
gticlay is offline   Reply With Quote
Old 06-03-2014, 08:53 PM   #5020
Whether a car is 2wd or 4wd has exactly zilch to do with if the chassis slaps on landings or not.
Follow my rc products on Facebook at Raborn Racing Originals and the line of 3D printed parts at
http://www.shapeways.com/shops/rebellionrc
fredswain is offline   Reply With Quote
Old 06-03-2014, 08:56 PM   #5021
FRED, I knew when 3 gear MM was mentioned you would be here. :-)
Old 06-03-2014, 10:13 PM   #5022
Chief's Avatar
Default Aluminum arm mounts
Guys
Installing the aluminum arm mounts and was wondering if the little lock washers are needed since the screws will be threaded into the aluminum with loctite?
Thanks! Jason
____________
TC6
B4.1
FT SC10
Chief is offline   Reply With Quote
Old 06-03-2014, 10:19 PM   #5023
I would just use a little locktite
Old 06-03-2014, 10:59 PM   #5024
cbl
cbl's Avatar
My esc is not that small, does anyone know the dimensions of the space provided for the electronics. I will be using my saddle packs so my space will be really limited.
Thanks.
cbl is offline   Reply With Quote
Old 06-03-2014, 11:07 PM   #5025
if you have a small receiver it should fit. if you have a sr300....welll then it wont
