    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree17Likes
Old 06-02-2014, 11:19 AM   #4981
gticlay's Avatar
I got up early this morning to try out my new Wolfpack shorty and a little different setup. I really do like how it drives with the shorty but honestly, I'm still not happy with it - the car is still difficult to drive. Man, my B5RM had so much traction coming on to the straight that it could do wheelies sometimes. B5M, not so much. I actually went so far as to put .5 toe in out back. It's worst coming on to the straight and when off power coasting into sharp turns. Starting to wonder if the MM just isn't for me. The 4wd car on the other hand was a really treat to drive today! I just can't get enough of driving that car!
gticlay is offline   Reply With Quote
Old 06-02-2014, 11:35 AM   #4982
Rybeau40's Avatar
Have you tried it with 0 anti-squat?
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 06-02-2014, 11:37 AM   #4983
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
GTI, is that 17.5 or mod?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-02-2014, 12:02 PM   #4984
gticlay's Avatar
No, it doesn't come with a 0 anti-squat does it? I think, but am not sure, that I would have to sources the aluminum piece plus the little plastic inserts. Do you happen to know anywhere that has them?
Old 06-02-2014, 12:04 PM   #4985
gticlay's Avatar
7.5 modified with a 22t pinion. The nice thing is that it runs really cool.
I wonder how much differently it would drive if I moved the ESC back into the battery tray? I can also move the battery back one thin pad but I can't imagine it would make the car hook up like I want it to.
Old 06-02-2014, 12:18 PM   #4986
I am sure you know this, but did you try the 75 tooth spur to move the motor back.
Old 06-02-2014, 12:47 PM   #4987
gticlay's Avatar
I tried using a smaller pinion but not a spur. I wonder which one makes a bigger difference, 7 teeth on the spur or 2 on the pinion?
Old 06-02-2014, 12:50 PM   #4988
well, with a smaller spur, you will probably use a smaller pinion. motor depending. So both.
Old 06-02-2014, 12:59 PM   #4989
gticlay's Avatar
Might be fun to try the 96t 64 pitch gear (same as a 72t 48p). Is 75 the sweet spot people have been finding?
Old 06-02-2014, 01:28 PM   #4990
Tech Legend
Wild Cherry's Avatar
GTI
Hey remember all my trouble with the Centro ?
Was not the car, just needed to learn how to drive & tune a mid motor.
Once I understood mid motor tune & driving I went respectably quick.
B5r had made me even quicker then the C4.
Look how quick I'v been going, this car is awesome ...
NO way anyone could take it from me..
you need to post your setup including Esc setting & motor timing & gear
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 06-02-2014, 03:06 PM   #4991
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Shove it back even further... LOL!
http://www.amain.com/product_info.ph...-Spur-Gear-49T
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 06-02-2014, 04:33 PM   #4992
gticlay's Avatar
Originally Posted by Wild Cherry View Post
GTI
Went back at lunch for a couple more packs. Sort of interesting as I put another set of tires on the back - same everything except the ones I've been using, the foam feels a little bit worn out. BAM! lots of traction and the weird stuff it was doing is gone. I know it's not the tire itself because we can run till there's absolutely nothing left for tread (when it's not very wet). Anyway I guess the foam is just shot in there.
I also played around a little bit with the battery further back and it felt like there was the "stall" and a funky little annoying push right in the middle of the corner. Moved it back forward and it felt better. Plus it jumped funky.
Old 06-02-2014, 07:25 PM   #4993
gticlay's Avatar
When the outside ribs start wearing off your favorite front tires do you keep running them as is, cut the ribs off, or toss em? Proline says the ribs are there to reduce the aggressiveness of them and I've run fronts with the ribs gone before but wondering what you guys do. Scrubs or barcodes are a good example.
Old 06-02-2014, 07:31 PM   #4994
3srcracing's Avatar
Trader Rating: 25 (100%+)
Less anti squat= ???
3srcracing is offline   Reply With Quote
Old 06-02-2014, 08:27 PM   #4995
brad996's Avatar
To me it adds more rear grip
SIRCS, Asylum Xtreme
TLR 22 4.0, TLR 22 3.0 lay down, TLR 22-4 2.0 Yokomo BD8/SV, Yokomo YR10F
brad996 is offline   Reply With Quote
