    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 05-31-2014, 06:29 PM   #4936
suby723's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Wild Cherry View Post
Were doing the opposite, been working to free the car up so it's Hard everywhere & battery forward to get better jumping & stability in the corners.
You tried adding some bump steer yet ?
That's my next change to test..
Heard good things about doing.
Hears the thing..from what I have tested, I feel that moving the arms forward will free the car up laterally and gain forward traction and helps free the car up from the mid corner stall we all refer to. Less stability but way better cornering. I have also swapped all parts to hard plastics except a few pieces that I will be getting shortly. I will say that with the shorty inline the car jumped a lot better over centered setup but I am far more consistant with the centered setup. I just installed the brass offset bushings today actually and am looking forward to testing it out.
suby723 is offline   Reply With Quote
Old 05-31-2014, 07:00 PM   #4937
Tech Legend
Wild Cherry's Avatar
Default off set bushing
Can 't wait to hear all about...
already found out how for myself.
Up ^ more on power steering. I don't believe your gona like.
Let me know...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-31-2014, 07:42 PM   #4938
Originally Posted by HBRob View Post
Probably not going to get the top speed out of it that you want. I'm running 33/72 with a 17.5 and 30 degree timing on a reedy. You are going to want to get the 72 tooth spur.
Robert
Wouldn't a smaller spur give me more top end? I was worried about losing torque. Or am I thinking about this wrong
scythe23 is offline   Reply With Quote
Old 05-31-2014, 10:02 PM   #4939
HBRob's Avatar
Trader Rating: 61 (100%+)
Send a message via Skype™ to HBRob
Sorry, you are right - was late when I answered this. Heres the math - also may explain why you run a bit hot. Likely will only get worse with 33/66
33/66 2.000:1 - 5.2 FDR (tall gearing / lower # = more top end, less torque)
33/69 2.091:1 - 5.436 FDR
33/72 2.182:1 - 5.673 FDR
Associated recommends 31/69 for stock, which is FDR of 5.79
You could try 30/66 which is 5.72, or 31/66 which is 5.535 and adjust timing according to heat. May have a problem getting pinion close enough to mesh though.
Heres a good article on gear ratios that helped me get my head around it years ago - and again when i just had a brain fart.
http://www.teamassociated.com/pdf/ca...ear_ratios.pdf
**Privateer** - Getting Out 11/12/16
TLR 22 3.0 | TLR 22T 2.0 | TLR 22-4
Fantom Racing | Hobbywing | Futaba
#ocrcarmy
HBRob is offline   Reply With Quote
Old 05-31-2014, 10:05 PM   #4940
Awsome. Thanks for the help. I'll run the 66 tomorrow and on tue when. Parts come in I'll snag a 72
Old 06-01-2014, 12:42 AM   #4941
Trader Rating: 44 (100%+)
I'm going to finally build my M this week but I am going to build it 17.5 first and see how it compares to my rm which is also 17.5, I will not be doing any of the tricks to lighten it I want to drive the car stock before I go extreme. Wish me Luck lol
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 06-01-2014, 12:54 AM   #4942
HBRob's Avatar
Will be great toner your feedback for those of us that are considering both
#ocrcarmy
Old 06-01-2014, 01:37 AM   #4943
will def let you guys know hopefully I can get out on wensday and race it
T5M 7.5
22 3.0 7.5
Old 06-01-2014, 07:26 AM   #4944
mason, its the rear alum part that the inner camber link ball stud attaches to.
cherry, I have my speedo just in front of the battery like Hartson has his , I cant post pics, sorry
Mike Richardson
At the track having fun with my friends
blingy is offline   Reply With Quote
Old 06-01-2014, 07:50 AM   #4945
Tech Legend
No big bout the image..
Were all going the other way , with ESC in the rear you get rid of the spaghetti look making for a lighter car.
when you pack all the weight towards the rear its just too much ,car can bottom easier slapping the ramp & then it tends to also jump nose high much easier.
Give our way a try because the car gains a great deal of stability in the corners , jumps & landing improve a great deal.This is in comparison to how your running the car now.
Notice how we are grinding the battery tray off the side pod, this helped restore traction from the weight being moved forward. Either way has about the same grip but with more weight foward you get all that stability & jumping improvements.
George W. Cherry
Old 06-01-2014, 08:45 AM   #4946
Tech Legend
images
George W. Cherry
Old 06-01-2014, 08:55 AM   #4947
Tech Legend
George W. Cherry
Old 06-01-2014, 09:03 AM   #4948
vito's Avatar
will a 200mm wire will be long to the motor esc in the stock spots
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 06-01-2014, 09:31 AM   #4949
Fabulous's Avatar
Trader Rating: 42 (100%+)
200mm will work but will be long. These will work well.
http://www.teamassociated.com/news/l...s+By+Design%29
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Fabulous is offline   Reply With Quote
Old 06-01-2014, 09:33 AM   #4950
vito's Avatar
thank you I got a round lrp 200mm all the shop had
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
