    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 05-30-2014, 12:51 PM   #4906
I'm running a heartson set up with 1.6 pistons all around white springs all around 30 weight in front 27.5 weight in the rear b5 front tower and arms std locations w/2mm spacer under the c/l and no Ackerman spacer shorty all the way back and speed control back against shorty for the rear alum pivots 3* toe 2 anti squat and alum rear camber block andI have the camber block so the +2 mm is towards the bottom . so I have 3 mm on camber block and hubs I'm in rear holes on the alum hubs and have 2mm under with the 0*facing the shocks .as for the conditions its outdoor watered mid to high as the sun drops ,as for tires I'm running green hybryds(sp)and green groovies there is enough traction i can pull wing dragging wheelies I think that covers my set up and track . thanks for the help guys .
Mike Richardson
At the track having fun with my friends
blingy is offline   Reply With Quote
Old 05-30-2014, 05:52 PM   #4907
Can someone tell me which savox servo would work best in the B5M
gearit is offline   Reply With Quote
Old 05-30-2014, 06:15 PM   #4908
Trader Rating: 33 (100%+)
Why don't you look at the Savox specs and determine which you'd prefer to run?
BTW.. while you are comparing specs, I'd check out other manufacturers to see if Savox is really where you want to be.
dnuggett is offline   Reply With Quote
Old 05-30-2014, 06:45 PM   #4909
Send a message via AIM to slappomatt
spektrum s6040 is a very popular buggy servo.
slappomatt is offline   Reply With Quote
Old 05-30-2014, 07:50 PM   #4910
I run a 1257tg and it strong and fast
Mike Richardson
Old 05-30-2014, 08:18 PM   #4911
vito's Avatar
is a 150 price good for a fantom apex 17.5 motor works
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 05-30-2014, 08:52 PM   #4912
zeakemedia's Avatar
Trader Rating: 74 (100%+)
Vito
I am sure those are nice motors but take a look at SMC. I love their 17.5 and the price is way better. The money you save can buy more shiny stuff to make your ride fancy.
Blake
DJO Race Designs | Fastraxx Hobbies | R1Wurks | Speedy's Racing Parts | The Ohio RC Factory
zeakemedia is offline   Reply With Quote
Old 05-30-2014, 09:45 PM   #4913
BLKXJ96's Avatar
Originally Posted by 3srcracing View Post
Personally I thought my Mid motor seemed way faster to drive then my rear motor. Took me a little bit but I am almost a full second faster with the the mid motor. Now I"m not as consistent but I am faster.
After you drive the car more and figure out where and when it is faster, you will start to be a little more consistent. Most setups will get you close, then just tune from there. The midmotor carries so much corner speed, that if you can slow down enough for the corner and make it clean cutting all the corners as close as possible....this is where I made up most of my time on the track.
hope this helps.....
Jeff
RC10 Team Car, Gold Pan, RC10 B5m B5mCE, Sc5m, Rc8B3e, B6
BLKXJ96 is offline   Reply With Quote
Old 05-31-2014, 07:23 AM   #4914
Mason's Avatar
Blingy, whats a rear camber block???
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 05-31-2014, 07:38 AM   #4915
Default Protek 3200 mah battery
Anyone using with the b5m and 17.5 motor? Wondering if puffing is an issue when running stock 17.5 motor. Also would like to know its performance in regards to supplying sufficient power to motor and any drop off within a 10 minute run. Thanks
Micah123 is offline   Reply With Quote
Old 05-31-2014, 07:39 AM   #4916
danny d's Avatar
consider the Futaba 9551 low profile servo. this way it is lighter than full size, and you have the option to run inline battery configuration.
danny d is offline   Reply With Quote
Old 05-31-2014, 08:09 AM   #4917
Fantom has a website. On the website there are prices.
Old 05-31-2014, 09:27 AM   #4918
vito's Avatar
I bin on there site they have a list of mod to add to the motor I payed 150 at the track
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
Old 05-31-2014, 09:35 AM   #4919
Tech Legend
Wild Cherry's Avatar
If you could please post a image of your ride ...
Like to see how you fit the esc in front of battery..
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-31-2014, 10:26 AM   #4920
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Vito, it is my opinion that you are better off getting something else for less and using the extra cash for tires, inserts, wheels, etc.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
