    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 05-28-2014, 09:41 AM   #4801
gticlay's Avatar
Originally Posted by Wildcat1971 View Post
most of them are using the 150gram super light shorty. That saves you 50-70g grams over a normal shorty. Then Pucks, alum topshaft, alum pinion, alum screws, shorty servo, slipper eliminator, Ti turnbuckles, Ti front axles and so on. A shorty servo is about 20 grams lighter than a full servo.
I have ti turnbuckles, screw kit, front axles, and upper shock mounts. Also aluminum top shaft and Schelle slipper so I thought I would be "moar closer" than I am. Thought it might be 1550 with a shorty but I guess not!
gticlay is offline   Reply With Quote
Old 05-28-2014, 11:20 AM   #4802
seth556's Avatar
Trader Rating: 42 (100%+)
Maybe try lighter shock oil?
On another note, what motor do you have? What about esc? Also your body may be pretty heavy depending on how thick the paint is.
seth556 is offline   Reply With Quote
Old 05-28-2014, 11:27 AM   #4803
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
the 120g battery savings and the ~20grams saving with a shorty servo can be 170 grams of savings. Plus, I think someone said 15-18g or so for the Pucks. That is around 150grams of weight saved. Also, some guys are switching to Ti ball studs with TLR 22 cups. The cups are more free than the AE ones and lighter. Plus the Ti studs are lighter than the sc10 4x4 studs the B5 uses. I plan to convert my b5 to the TLR cups/balls, just because i am getting tires of sanding and polishing non stop, lol.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-28-2014, 12:16 PM   #4804
Default 1500 Gram Setup Sheet
Looks like more and more of us are discovering how to get our buggies down to the 1500g range. Would be nice to have some setup sheets or just some general pointers from those who have already gone thru the process.
Micah123 is offline   Reply With Quote
Old 05-28-2014, 12:16 PM   #4805
Tech Legend
Wild Cherry's Avatar
dup
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-28-2014, 12:17 PM   #4806
Tech Legend
Weighed my car this morning and it's a real pig. 1671 grams. Looks like if I were to go to a shorty I would loose 70g plus if I move the ESC back into the battery brace another 10g or so? Man, I'm not sure how you guys get your cars so light!
No brain er ..
14 grams off just from grinding tray & water fall.
Then if your clever ? Use that new a Reedy 14 grade thin wire & even more weight savings for free...
I believe were talkN about a savings in the 1 oz range.
You get those alloy hubs yet ? Lol
George W. Cherry
Old 05-28-2014, 02:00 PM   #4807
Hey Guys,
So I finished my first build. I am looking for tips on what to buy for the motor, speedo and servo.
I was told 17.5 to start with and upgrade from their.
Would a Tekin RS Gen2 Sensored Brushless ESC with a reedy 17.5 brushless work well together? Leaving room to upgrade motor in future to 8.5 or something?
Anyway, feel free to list off the parts you'd piece together or what you would do and Ill take a look at each.
Thanks!
edgetechNY is offline   Reply With Quote
Old 05-28-2014, 02:45 PM   #4808
Cridd's Avatar
Trader Rating: 16 (100%+)
HBRob I have the 1.6 and 1.7 tapered with the 32.5 weight oil all around, White and Green springs. I used that at JBRL at OCRC but now put the pucks in and top shaft, so about 35 grams lighter, thinking of going to 30 weight oil front and 27.5 rear, dropping spring rates by one setting front and back and tune from that point.
Next race is outdoor at CCR, never been but yesterday in Exeter car was bouncy, track had some rough bumps and getting ready for a rebuild but need to lighten up and absorb a little more.
Running stock class so helps to be close to 1500 grams.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 05-28-2014, 02:55 PM   #4809
I bought all my Ti stuff and schelle slipper at amain for a good deal using this link to their coupon code here.
Nebula is offline   Reply With Quote
Old 05-28-2014, 03:47 PM   #4810
Super Moderator
Trader Rating: 17 (100%+)
ran my car at 1680 outside and it was dialed. Pulling wheelies
Only 3rd time I've even run it and it was still setup for indoors
Super Soft Impacts rear M3 holeshot fronts.
Here's the track we were on. It grooved up nicely.
https://www.youtube.com/watch?v=O5LnXHqkrNc
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 05-28-2014, 05:01 PM   #4811
Suspended
Originally Posted by edgetechNY View Post
Hey Guys,
Thanks!
Sounds like a good start to me bro.
C4.2
LRP
Reedy
XP
johnnyfresco is offline   Reply With Quote
Old 05-28-2014, 08:50 PM   #4812
the tekin is worth the money and wont bottle neck future engine upgrades?
Old 05-28-2014, 09:53 PM   #4813
Jason Turner's Avatar
Trader Rating: 64 (100%+)
Anyone else broke this in this way yet?
Jason Turner is offline   Reply With Quote
Old 05-28-2014, 10:06 PM   #4814
gticlay's Avatar
I bet the hard hubs wouldn't do that.
Old 05-28-2014, 10:06 PM   #4815
Tech Legend
Jason did you also include a motor washer under the ball stud ?
Good reason to recommend the alloy hub , their stronger..
George W. Cherry
