    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 05-25-2014, 06:13 PM   #4741
Nick_n's Avatar
Wildcerry: What made you decide to put the esc in back instead of in front of the battery?
Nick_n is offline   Reply With Quote
Old 05-25-2014, 06:53 PM   #4742
vito's Avatar
•Remove the cup from the stock Associated shock bushing (ASC91445) for proper spacing.
what part of it is it to take off
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 05-25-2014, 07:07 PM   #4743
Is it easy to switch back and forth in between rear motor and mid motor?
rcbrad27 is offline   Reply With Quote
Old 05-25-2014, 07:07 PM   #4744
gticlay's Avatar
Originally Posted by vito View Post
cut off the pice that go over the nut?
No, dremel the nut sharp edges till they fit in the bushing easily. It doesn't take much. I'm sure Kelly will be doing this to them soon but first run stuff...
gticlay is offline   Reply With Quote
Old 05-25-2014, 07:12 PM   #4745
BLKXJ96's Avatar
I have both cars built and running, I switch between the two all the time. I take both cars to the track, if the Mid motor car starts to fade I run the Rear motor car. Both cars drive the same but different under different conditions...if that makes sense.
Jeff
RC10 Team Car, Gold Pan, RC10 B5m B5mCE, Sc5m, Rc8B3e, B6
BLKXJ96 is offline   Reply With Quote
Old 05-25-2014, 07:41 PM   #4746
3srcracing's Avatar
Trader Rating: 25 (100%+)
30/27.5
2limiters/2limiters
Does that sound about right?
3srcracing is offline   Reply With Quote
Old 05-25-2014, 08:20 PM   #4747
Pittsdriver's Avatar
What weights are you seeing with your mid setups?
B5
B5M
T4.2
Pittsdriver is offline   Reply With Quote
Old 05-25-2014, 08:23 PM   #4748
BLKXJ96's Avatar
Originally Posted by 3srcracing View Post
1.6/1.6
30/27.5
2limiters/2limiters
How does it drive? I think I'm about the same with green fronts and white rears. a few of us here in Michigan spent about nine hours at the track getting out buggies to work.
Jeff
Old 05-25-2014, 08:25 PM   #4749
Trader Rating: 22 (96%+)
1564 with the alminum inner rear ballstud mount, and typos with a shorty pack
dezertranger96 is offline   Reply With Quote
Old 05-25-2014, 08:30 PM   #4750
asc6000's Avatar
Trader Rating: 15 (100%+)
I believe he meant switching (changing) the car itself from mid to rear.
"you reach the limit, you touch the limit, then you pass the limit, now there is a new limit"
Ayrton Senna
asc6000 is offline   Reply With Quote
Old 05-25-2014, 08:31 PM   #4751
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I have been trying the rcshox 2 stage pistons in my rm and plan to try in mm also. Feels like a 1.6 in the corners. But crap tons of pack of jumps.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-25-2014, 08:45 PM   #4752
BLKXJ96's Avatar
kinda what I thought but what most people don't understand.....it's one or the other...not both....two different cars.
Jeff
Old 05-25-2014, 08:57 PM   #4753
Fabulous's Avatar
Trader Rating: 42 (100%+)
What is the most common shock setup for a indoor clay medium-high bite track?
Front;
1.6
32.5
grey
Rear;
1.6
30
white
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Fabulous is offline   Reply With Quote
Old 05-25-2014, 09:00 PM   #4754
Fabulous's Avatar
Currently 1506 with battery strap and battery foam. pic is without battery strap and foam
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Old 05-25-2014, 09:10 PM   #4755
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Send a message via AIM to T-BirdJunkie Send a message via MSN to T-BirdJunkie
Originally Posted by JiuHaWong View Post
I thought you always talked about yourself in the third person?
I did, but ThunderbirdJunkie got bored with it :P
Basically, it's completely disassembling a car, and then completely reassembling a car. If that's easy, then yes. If that's not easy, then no.
I'm at 1580, stock, with an RS Pro and way too much wire and a portly, old Airtronics 94358. The 13.5 in this car is just HUMMIN
If you don't allow yourself to make mistakes, you'll never allow yourself to succeed
T-BirdJunkie is offline   Reply With Quote
