    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 05-24-2014, 06:11 PM   #4711
Send a message via ICQ to JiuHaWong
Needs an aluminum chassis too?
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 05-24-2014, 06:24 PM   #4712
SH
Trader Rating: 18 (100%+)
Originally Posted by xTotalghost View Post
Well you probally have to drive it a little slower because yhere is not that much weight down low to keep the car planted like with the aluminum chassis
More flex potentially though.
SH is offline   Reply With Quote
Old 05-24-2014, 06:26 PM   #4713
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
needs to not be a turd
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-24-2014, 06:29 PM   #4714
Aren't you racing an RM at the moment?
Old 05-24-2014, 06:32 PM   #4715
Yeah, waiting for my conversion kit for my second B5. I would not run that CF chassis if you gave it to me. Why? simply because its flat and does not fit the side pods well. If your going to make a chassis, make new side pods to match it.
Old 05-24-2014, 06:37 PM   #4716
I had to look at the picture again on the facebook.
Not a perfect fit, but that's common with cottage-manufactures. Looks like he didn't curve the graphite to meet the edges of the side pods?
Good first attempt though. I'm waiting for Exotek to do one.
Nothing wrong with Carbon fiber for a chassis, it just requires a different dampening package.
Old 05-24-2014, 09:24 PM   #4717
Originally Posted by slick1 View Post
BAM!!!
that carbon chassis look nice!!! but this car look like it to stiff to start out with??? i know it's not for weight. this must be set-up for a super high grip track... or your just a show-off!!! but still nice ride.
gatorage is offline   Reply With Quote
Old 05-24-2014, 11:27 PM   #4718
I run xfactory stadium and SC trucks. The fact that u can tune the flex is a great advantage. Who cares about side pods? I wouldn't care if my car was shaped like a brick or even a dog Turd. As long as it performs well.
Justinb86 is offline   Reply With Quote
Old 05-25-2014, 12:06 AM   #4719
Tech Legend
Wild Cherry's Avatar
All this hub talk got to me...
So tonight I soup up my plastic hubs.
Used a longer 8mm ball stud & included a motor washer under the stud with a nut on the back side for max strength.
Cus who likes breaking hubs, right ??
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-25-2014, 07:20 AM   #4720
Originally Posted by Wild Cherry View Post
Using currently...
Front
4 x 55 Losi piston
37.5w Ae oil
Ae grey spring
Rear
4 x 55 Losi piston
32.5w Ae oil
Ae green spring
24.5mm ride height
Hi WC, do you have a copy of the rest of your set up? Is this run with a shorty across the rear? I run on a bumpy track will the 4 hole pistons work better on this than a 2 hole setup?
notyou is offline   Reply With Quote
Old 05-25-2014, 08:08 AM   #4721
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Send a message via AIM to T-BirdJunkie Send a message via MSN to T-BirdJunkie
So, I ran my B5M for the first time yesterday.
Car is absolutely dialed! It pushes just a little bit, but holy crap this car is awesome. I even did a half assed job building the shocks.
If you don't allow yourself to make mistakes, you'll never allow yourself to succeed
T-BirdJunkie is offline   Reply With Quote
Old 05-25-2014, 08:21 AM   #4722
I dont care about side pods... The maker mounted them up and they didnt look good. And yeah, I am anal about things like that.
Old 05-25-2014, 08:45 AM   #4723
Tech Legend
setup still under construction...
I run on smooth indoor clay, med high traction.
The 4 hole pistons are for improved cornering, they don't really improve performance on jumps or bumps .
George W. Cherry
Old 05-25-2014, 09:50 AM   #4724
Tech Legend
Originally Posted by iterator View Post
I got a chance to take some photos of WC's B5M and the individual parts he modified. Pretty interesting stuff, I haven't tried it on my car but I wanted to share the photos.
images
George W. Cherry
Old 05-25-2014, 10:04 AM   #4725
J_Bone's Avatar
images
I like the idea of getting everything as close to center but is that chassis going to have more torque flex?
With the new aluminum hub, you might want to replace the ball stud every so often. I had similar hubs on my old B4 and had a ball stud break off and I couldn't get the lock tite threaded part out.
You mentioned the B5M stall a while back, what have you done to remedy that?
J_Bone is offline   Reply With Quote
