    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 05-22-2014, 08:30 PM   #4666
suby723's Avatar
Trader Rating: 21 (100%+)
Originally Posted by Wildcat1971 View Post
IMO, 17.5 is sketchy for MM. Not because MM sucks or anything weird. Its power and heat. The car is heavier unless you spend $$$$$ to make it light, and in general 17.5 motors are run hot to get speed out of them. But the MM has much less cooling, so that makes the whole thing worse. Almost every mod car at the local track is MM and they can do wheelies all day with the traction level. But in stock, 90% of the cars are RM. Mostly for the power. MM handles just fine. I am hoping to put together a mod MM car soonish. I need a second class to run.
I have to disagree on the $$$$ part for lower weight. I have spent no money on light parts and im at 1552g rtr. Used v2 slipper and b4.2 turnbuckles and modded the car to the hartson setup.
suby723 is offline   Reply With Quote
Old 05-22-2014, 09:00 PM   #4667
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Some people are getting to 1500 grams. Lol, I dont want to ague what is needed and what is wanted. lol. Many people beleive they need 1500 grams for stock. I dont believe that, but many do. People are buying carbon fiber motor plates, lol. That dont really displace heat like the alum one. I run my cars mostly stock with zero mods. I dont believe in mods. If the car "needs" mods, I sell it.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-22-2014, 09:24 PM   #4668
you guys with a lot of experience in 17.5 if you had $275 burning a hole in your pocket to buy a 17.5 motor and a esc to put in a 5m what would you buy?
Solo1 is offline   Reply With Quote
Old 05-22-2014, 09:29 PM   #4669
vr6cj's Avatar
Trader Rating: 124 (100%+)
r10 pro and a R1 wurks motor
vr6cj is offline   Reply With Quote
Old 05-22-2014, 09:54 PM   #4670
racer x 1's Avatar
Trader Rating: 27 (100%+)
hands down a hobbywing v3.1 stock and likely a x20 lrp motor. I havent run the motor yet bet ive seen a few recently that deff caught my eye. and I run a d3.5 for club races.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 05-22-2014, 11:07 PM   #4671
racer_guy's Avatar
so i made a stupid mistake. ordered aluminum c and d mounts...but i accidentally ordered the ones for the b5 instead of the b5m. super mad at myself. we will see if amain has a heart for stupidity.
W.E.D. Winning Edge Designs
racer_guy is offline   Reply With Quote
Old 05-23-2014, 04:00 AM   #4672
mxracer458's Avatar
Trader Rating: 47 (100%+)
i like my x12 17.5 when i had it,only downside is they like to run a bit warmer then most motors,Might not be such a good idea in mm
mxracer458 is offline   Reply With Quote
Old 05-23-2014, 05:18 AM   #4673
They will give you a store credit. But you need to ship it back
Old 05-23-2014, 06:23 AM   #4674
Trader Rating: 18 (100%+)
Originally Posted by racenut123 View Post
It's all perception. A couple mm cars at stock nats that weighed in at 1600+ finished right behind Hartson. A really fast local who installed a fan has his motor coming off at about 130 after 10 plus minutes of running straight. I am not saying what you said has zero validity, but there are ways around those obstacles.
Here's my setup that racenut is talking about for those that are interested.
From the R1wurks motor thread:
http://www.rctech.net/forum/electric...proved-11.html
Running 69/32 with 20* timing. Before mounting the fan in my B5m i was coming off @ 180* (no holes cut in body). With the fan I can run as long as I want and stay around 130*. With the fan my car is very consistent thru out the run and has very little fade allowing me to continue setting fast laps towards the end of my run. The fan touches the top of JC silencer body and C4.2 body. The fan is a little on the big (30mm x 15mm) side but produces 10 grams of thrust. I tried a smaller fan that clears the body with ease and that can be positioned a little more centered on the waterfall but it doesent move as much air resulting in higher temps (160* after 10 min and noticeable power drop off).
I used this mount and made a few simple modifications (dremel) to the brace to mount the fan.
R1 Fan (13.2 grams)
http://r1wurks.com/product.php?id_product=49
R1 Fan Mount (1.5 grams)
http://r1wurks.com/product.php?id_product=57
I have a few pics on how I mounted it on R1wurks thread.
Ryan Sagisi
Schelleracing.com | Raceaka.com | R1wurks.com
B5M | B44.2 | T4.2 | Top Photon
SAGISI is offline   Reply With Quote
Old 05-23-2014, 06:25 AM   #4675
You can also shave the chassis brace and mount it this way. I had a friend of mine mount it this way and it kept the motor cool but he got T-boned and the fan shattered (must have been the perfect hit). Also mounting this way requires you to cut out body to clear fan.
Ryan Sagisi
Old 05-23-2014, 06:35 AM   #4676
30x10mm fan works well for those with less aggressive gearing setups and clears top of body by 3mm. **Smaller fan also allows you to center fan on waterfall and use battery brace.
Ryan Sagisi
Old 05-23-2014, 07:40 AM   #4677
pumpkinfish's Avatar
Did you drill/shave other chassis parts? MIP pucks? I run mod but was thinking of dropped a few g's here and there if it doesn't weaken the buggy.
pumpkinfish is offline   Reply With Quote
Old 05-23-2014, 07:45 AM   #4678
Trader Rating: 22 (96%+)
I have mine mounted in my cut out waterfall/chassis tub. It is one of the orion fans so it pushes a ton of air, and is flush with the battery tray. It moves tons of air, and doesn't impede on the battery tray.
dezertranger96 is offline   Reply With Quote
Old 05-23-2014, 07:53 AM   #4679
suby723's Avatar
I run mod as well so I dont have the puck system. I have modded my chassis for the hartson inline setup. Time with a dremal will drop some weight off the car.
Old 05-23-2014, 08:34 AM   #4680
Yeah, I do. But I have a bad habit of charging and storing my packs in the cars...I hate thumb screws, lol. But yeah, I go over my cars and try to clean them up between rounds. I only run 1 class, so it keeps me from getting bored.
So here is a mod for you then! B44.2 battery hold downs....
B5M
22 2.0
B44.2
TC4
SC10 4x4
Pellefa is offline   Reply With Quote
