Team Associated RC10 B5m Mid-Motor Thread
#4591
anyone concerned that the FT turnbuckles are shorter than the stock ones?
#4593
looking at the b5 the turnbuckles are imperial 2.06"
can you use a 3mm turnbuckle wrench i.e. hudy
or fo i need to swap them for a metric turnbuckle i.e. 3 racing?
#4594
Why is there so much talk about changing the turnbuckles? Are they weak n need to be replaced? If so, I better order mine before I build my kit.
#4595
WTF? They skipped over me?!? j/k I hope you're right tho. I'm tired of waiting to get this buggy!
#4596
R/C Tech Elite Member
I will summarize for you: some people are having a hard time adjusting camber due to the ballcups/turnbuckles being too tight. The turnbuckles can be seen as a little too long and thread too far into the ballcup. That's why people are going with the B4 turnbuckles as they are shorter (and also happen to be titanium, instead of steel).
I think I covered that pretty well...
#4597
For 17.5 blinky, is the gearing going to be the same as the B4? I haven't raced a buggy in about a year and I just want to be sure I'm in the ballpark.
#4600
Also speaking of setup for those that are not following the B5Nation group on facebook, I have been dialing in a setup for outdoor/blue groove/high traction track.
Front:
3mm trailing axle
32.5 AE oil
Black spring
-1* camber
1* toe out
Rear:
30 weight AE oil
White spring
-1* camber
3.5* toe in
2* anti squat
2mm infront of hub
Orange barcodes all around.
I also have .25 FT ae stick on weight on the servo because I was under weight at our last race.
Front:
3mm trailing axle
32.5 AE oil
Black spring
-1* camber
1* toe out
Rear:
30 weight AE oil
White spring
-1* camber
3.5* toe in
2* anti squat
2mm infront of hub
#4601
#4604
Jason
#4605
What battery options are there for the B5? Is the square reedy pack the best option?
