    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 05-17-2014, 09:20 PM   #4546
davidbarton87's Avatar
Trader Rating: 18 (100%+)
Anytime, I love breaking out the Dremel.
Team Associated Team B5M , LRP Flow Works, XP Digital, SMC 8.5, Airtronics
Team Associated Team B5 LRP SXX V2.1, Savox, SMC 17.5, Airtronics
davidbarton87 is offline   Reply With Quote
Old 05-17-2014, 10:04 PM   #4547
vito's Avatar
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 05-17-2014, 10:24 PM   #4548
Anyone try out the anti-roll bar kit? I've never ran one before. Is the bar suppose to be solid so it can't move back and forth on the shock tower?
splking1 is offline   Reply With Quote
Old 05-18-2014, 01:24 AM   #4549
Send a message via AIM to slappomatt
Originally Posted by thecman26 View Post
It's a great build, I just got mine finished!
FWIW the Schelle gearbox bearings are worth their weight in gold!
just helped a buddy with a money spending issue build his B5M with full schelle bearings and the ceramic trans bearings are NICE. trans has a slipper eliminator, schelle ceramic bearings, protek ceramic balls, lunsford ti screws and MIP alum top shaft. spins REALLY nice.
slappomatt is offline   Reply With Quote
Old 05-18-2014, 05:38 AM   #4550
Having trouble with front grip on a hard packed outdoor dusty track. Running the box setttings and using AKA rebars with the red inserts. Running in stock.
What would people suggest I try? Thanks
moch8 is offline   Reply With Quote
Old 05-18-2014, 07:11 AM   #4551
moch8..... first thing I would try is to take out the little silver 2mm spacer that goes behind the front steering hubs.... pull that outter hingepin and move the silver spacer from behind the steering hub to infront of it.. this will change the weight bias of the car a little and put more weight over the front increasing steering and traction in front. it basically moves your front wheels back twards the middle of the car 2mm putting more of the nose of the car over them.
that should help a lot. let us know and if you need more help just ask.
rickster is offline   Reply With Quote
Old 05-18-2014, 10:50 AM   #4552
First I would suggest trying an open cell insert, next I would try a softer compound. The last thing I would try is a different tire.
Shirk is offline   Reply With Quote
Old 05-18-2014, 11:08 AM   #4553
Tech Legend
Wild Cherry's Avatar
Plus 1
mock why are using the mid motor ?
Think a B5r would perform better for your track conditions ...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-18-2014, 04:52 PM   #4554
Hi Rickster,
I assume you are talking about the caster block spacer in Step 6 of the manual. Funnily enough I accidentally built it that way in the first place. I am considering running a softer front suspension for more weight transfer to the front when turning in.
Old 05-18-2014, 04:54 PM   #4555
Thanks. I'll look into that.
Old 05-18-2014, 04:54 PM   #4556
Originally Posted by Wild Cherry View Post
Plus 1
Hi Wild CHerry, you could be right about that but I haven't treid a MM 2WD before so I thought I'd give it a go.
Old 05-18-2014, 04:59 PM   #4557
vito's Avatar
my mid is all done whats a good 17.5 motor to get I like to try a rev thec one
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
Old 05-18-2014, 06:02 PM   #4558
racer_guy's Avatar
in the past i have had nothing but great results from reedy motors. im getting back into the hobby (last time i raced was 2005) and i got a reedy motor goin into my b5m
W.E.D. Winning Edge Designs
racer_guy is offline   Reply With Quote
Old 05-18-2014, 08:21 PM   #4559
moch.. ya go to the green front and try that too..... I have mine all set up for outdoors and its really good. But I like a very aggressive car so I know my setup isn't for everyone.. have you done the rear end mods for more traction? either taking a mill off the front of rear arm or using b5r rear arms? I also use the 30deg. caster block as well.
if your indoors or a hard outdoor track with traction then keep the heavier front spring and also go to a white rear spring.
Old 05-18-2014, 09:07 PM   #4560
suby723's Avatar
Trader Rating: 21 (100%+)
Inline shorty lipo was no good. Switched back to Hartson's inline setup and was dialed again. Would not recommend wasting time on the inline shorty mod.
suby723 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
christopher_2
