    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 05-14-2014, 08:07 PM   #4471
rigor's Avatar
Trader Rating: 37 (100%+)
Originally Posted by Wild Cherry View Post
Really like the alloy hub with its vertical ball stud, so I just switched back to the plastic camber mount.
Having both sides metal was a bit to stiff for my ride , it benefited from the extra grip gain by using a plastic camber mount .
Interesting. I thought I was crazy, but I also noticed what I felt was a slight loss in traction after going alum / alum on both rear pieces. I think I might switch back to "stock" rear hubs and keep the alum rear camber ballstud mount, as I haven't had any breakage on the rear hubs at all.
* Jesse H. *
rigor is offline   Reply With Quote
Old 05-14-2014, 08:46 PM   #4472
Originally Posted by RCBuddha View Post
Correct!
Just curious how much the weight bias changes...
Check the b5 nation fb page. Someone just posted the weight change.
I believe it was very minor. 62 % on the rear prior and 60% after. (Ive rounded to what I can remember)
robbie_gtc is offline   Reply With Quote
Old 05-14-2014, 09:49 PM   #4473
Tech Legend
Wild Cherry's Avatar
Keep the alloy hubs because they
allow more tunability with the vertical stud .
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-14-2014, 09:51 PM   #4474
Does anyone have the link to the b5 nation Fb page. I can't seem to locate it.
splking1 is offline   Reply With Quote
Old 05-14-2014, 10:23 PM   #4475
Originally Posted by Wildcat1971 View Post
so are avid's. I suggested the avid, then he suggested caspers. I was wondering what was better about caspers.
Bfast sells the same caged thrust assemblies. There $17.99 for pair. I'm sure that bfast, Casper, and avid all buy them from the same place tho
Justinb86 is offline   Reply With Quote
Old 05-14-2014, 10:27 PM   #4476
suby723's Avatar
Trader Rating: 21 (100%+)
Search rc10b5 nation.
suby723 is offline   Reply With Quote
Old 05-14-2014, 10:51 PM   #4477
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Just what I said earlier...I have both the Casper and the Avid, and they work equally well. Next Bfast order I make, I'll order their version of the caged thrust to try.
RCBuddha is offline   Reply With Quote
Old 05-14-2014, 10:53 PM   #4478
RCBuddha's Avatar
Just looked it up. Interesting that there was only a small % change. Also fascinating that the guy who did it owns a $800 set of scales!
Old 05-15-2014, 12:06 AM   #4479
markt311's Avatar
Trader Rating: 32 (100%+)
Correct!
My car went from 61.4% rear stock, to 60.4% inline. I did mine a little different than WC as you can see a few pages back.
Got a chance to run a few packs tonight, small medium traction clay. It didn't feel like it lost much rear traction. It changed direction sharper and didn't over rotate. I gained some high speed steering, but felt like I lost a little on the low speed 180's.
Overall I like the inline car, I'm going to get another cradle and cut it like WC did his and see if there is any difference.
PR Racing Bellgate Distributors
Caster Racing Parts
311 RC Graphics
markt311 is offline   Reply With Quote
Old 05-15-2014, 12:09 AM   #4480
markt311's Avatar
That was me, lol I don't own the scales. We have some die hard carpet oval guys at my local track
Caster Racing Parts
311 RC Graphics
Old 05-15-2014, 04:21 AM   #4481
eper's Avatar
Trader Rating: 14 (100%+)
Originally Posted by blingy View Post
I noticed that cav was running the rear motor rear arms and someone else was running them on petit rc also ,what difference is there between the two ? thnx
I noticed te same thing what are they looking for with the rm front arms and I think the shock tower. I know the geometry is different but what's different feel wise
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 05-15-2014, 05:22 AM   #4482
dmatter's Avatar
1% is a big difference. You have to move your battery pack around quite a bit to get 1%. Not only are you adding 1% to the rear of the car you are taking 1% off the front. This is a generalization not WC's modification. He changed the whole weight of the car which is another story.
dmatter is offline   Reply With Quote
Old 05-15-2014, 06:46 AM   #4483
SilentHunter's Avatar
I thought you had 25% less side bite with the alloy hubs??? Why would you run with that???
SilentHunter is offline   Reply With Quote
Old 05-15-2014, 07:15 AM   #4484
gticlay's Avatar
I think that was the hard arms.
gticlay is offline   Reply With Quote
Old 05-15-2014, 07:16 AM   #4485
gticlay's Avatar
More rear bite, drives more square with the RM arms flipped. On the front it smooths out the steering.
