    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 05-12-2014, 09:08 PM   #4366
Jake S's Avatar
Trader Rating: 66 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
Originally Posted by racenut123 View Post
If the focus is to get the weight over the rear then the battery back makes sense. Considering he runs the shorty servo and is able to get the electronics relatively inline as far as weight goes,how is this even similar to stock?
Explain this to me like I am 5 because I am obviously not seeing your point.
i think he is saying that the center of mass of the battery looks similar to the stock back position, but with this you remove alot of "mass-roll" so the car doesnt dump in the center of the corner as much.
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 05-12-2014, 09:11 PM   #4367
Thumbs up
Yeah I see what he is saying. I ran by battery all the way forward so it won't be remotely the same. I found that to work best with the shorty packs that are 155 grams.
splking1 is offline   Reply With Quote
Old 05-12-2014, 09:12 PM   #4368
Trader Rating: 28 (100%+)
This makes sense. The roll is what we are addressing by going inline correct?
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-12-2014, 09:31 PM   #4369
Jake S's Avatar
i believe that is the main purpose. but looking at it a shorty is not much wider then the motor/trans anyway....
Old 05-12-2014, 09:32 PM   #4370
Tech Legend
Wild Cherry's Avatar
Originally Posted by splking1 View Post
I'll be testing it tomorrow. Thanks Wild Cherry for sharing this mod.
my pleasure, make sure to check ride height before running.
Suggest 23.5mm front & rear.
Take the time to remove the battery tray & separate the thumb screws.
Its the fun part....lol
If you feel the need for more traction suggest green rear spring.
I'm running for shocks
Front
1.4 x 3 piston ,37.5w ,Grey front
Rear
1.6 x 2 , 32.4w, white spring
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-12-2014, 09:37 PM   #4371
Tech Legend
Oman !
Speaking bout shocks .....
Tomorrow testing Losi # 55 x 4 piston
35w front 30w rear..
I tell everyone want happens , can trust me..
George W. Cherry
Old 05-12-2014, 10:27 PM   #4372
markt311's Avatar
Trader Rating: 32 (100%+)
I'm going to corner weight my car Wednesday, see exactly what the ratio is. It good having friends that race oval!
PR Racing Bellgate Distributors
Caster Racing Parts
311 RC Graphics
markt311 is offline   Reply With Quote
Old 05-12-2014, 10:29 PM   #4373
Trader Rating: 22 (96%+)
what weights are you all coming in at? im at 1594 with the stock body, shorty, extra wire, and rear aluminum ballstud mount
dezertranger96 is offline   Reply With Quote
Old 05-12-2014, 10:44 PM   #4374
Suspended
I got mine down to 1417
Pimp Formally Known as OG
PFKAOG is offline   Reply With Quote
Old 05-12-2014, 10:57 PM   #4375
vr6cj's Avatar
Trader Rating: 124 (100%+)
Legal roar rules state 1499 right? Mine was about 1610 stock then I worked on getting it to the 1499.
vr6cj is offline   Reply With Quote
Old 05-13-2014, 12:54 AM   #4376
markt311's Avatar
1554 box stock, except for shock mounts, and inline electronics. Was 1608ish before that. I'm waiting on some new 14 gauge wire to redo mine and put the esc up front. It's really starting to feel like I own a kyosho lol.
Caster Racing Parts
311 RC Graphics
Old 05-13-2014, 01:19 AM   #4377
Originally Posted by leskai View Post
Most of the guys that are replacing plastics are trying the hard composite stuff. From what I know these pieces have less flex than the standard plastics. So with that said they have a greater chance of snapping in wrecks. From what I heard from some of the guys running them is that it allows for the suspension and all the mechanical parts to do their job rather than some of it being soaked up in flex. I personally have only ran the stock plastics and setup and had a few rough tumbles due to high speed traction rolls coming off the straight into a table jump. The worst that has happened was a bent turnbuckle. I am still using the stock ones which are not very durable. Most guys switch over to the lunsford ones (still waiting for backorder).
But beside the turnbuckles you haven't experienced any big weaknesses?
Thx
racer
racer_hh is offline   Reply With Quote
Old 05-13-2014, 07:06 AM   #4378
I eventually want to race this in stock, so would this list be a decent start?
Mip top shaft
Mip pucks
Shaved gears
Nova slipper
Ceramic tranny bearings
No bearing shields
Titanium front axles and tierods
Mixed in titanium and aluminum screws
Hobbywing extreme stock esc, very light and great in stock
Ceramic motor bearings
Old 05-13-2014, 07:16 AM   #4379
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Mip top shaft
Mip pucks
Shaved gears
Nova slipper
No bearing shields
still might want the alum rear camber block for durability.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 05-13-2014, 07:26 AM   #4380
Already have it, and I will probably get the arm mounts to remove the slop in them
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
