    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 01-13-2014, 09:17 AM   #421
Originally Posted by xTotalghost View Post
So what gearing should I be running for 17.5 in this thing. In my current b4.2 I run 69/34
You can run the same FDR in the B5 as you do in your B4.
On your B4:
FDR = (spur / pinion) x Internal Trans Ratio
FDR = (69/34) x 2.6
FDR = 5.28
On your new B5 (RM or MM):
5.28 = (81 / Pinion) x 2.6
5.28/2.6 = 81/pinion
2.03 = 81/pinion
pinion(2.03) = 81
pinion = 40 tooth
Well, you're going to need a smaller spur gear than what comes with the kit! I don't recall if the existing spur gears fit...
Brushless Gearing Guide - gearing.rcgearhead.com
RC Wiki - www.rc-wiki.com
It's ever so useful!
CraigV is offline   Reply With Quote
Old 01-13-2014, 09:18 AM   #422
gticlay's Avatar
Originally Posted by Davidka View Post
The easy fix is don't take a bunch of practice laps. It's usually the motor (heat) that goes soft more than the battery.
I suppose wherever you live heat may be a problem. Up here it's 40-50* at our indoor track and you can run a properly geared car for the whole pack and have it only warm.
gticlay is offline   Reply With Quote
Old 01-13-2014, 10:24 AM   #423
Cptn Cartwheel's Avatar
Originally Posted by JiuHaWong View Post
My understanding is he did the TC5/6(?), 12R5.1/2. Not sure what else.
Ask him. I believe he's posted in here a couple times.
Chris Madsen
Cptn Cartwheel is offline   Reply With Quote
Old 01-13-2014, 10:51 AM   #424
Default Gearing
The kit comes with two spur gears (81 and 72). This way stock and modified can achieve proper gearing.
Kody Numedahl is offline   Reply With Quote
Old 01-13-2014, 10:58 AM   #425
Send a message via ICQ to JiuHaWong
Red-Line was asking...
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 01-13-2014, 01:12 PM   #426
Davidka's Avatar
Trader Rating: 75 (100%+)
The magic bit is highlighted. A properly geared motor doesn't overheat.
Old 01-13-2014, 01:57 PM   #427
gticlay's Avatar
I was referring to the comment you made about the car feeling "soft" due to heat, not the pack. I was saying no, it's not heat. But really, it's not even an important issue anyway, compared to WHEN do I get my B5!?!?
Old 01-13-2014, 02:46 PM   #428
tommy911t's Avatar
Trader Rating: 50 (100%+)
Why would AE not center the motor?
tommy911t is offline   Reply With Quote
Old 01-13-2014, 02:49 PM   #429
Super Moderator
Cpt.America's Avatar
Trader Rating: 52 (100%+)
<insert speculation> Because centering the motor would probably introduce a tiny bit of unbalance to the car considering the weight of the motor plate and spur assembly.
A big thanks to my sponsors:
- Fantom Racing - www.fantomracing.com -
- Fusion Graphix- www.fusiongraphix.com -
- RCSpecialties -
Cpt.America is offline   Reply With Quote
Old 01-13-2014, 03:03 PM   #430
tommy911t's Avatar
That could suggest brushed motors were actually not balanced left to right.
All very interesting.
Still looking forward to seeing and feeling this kit in person.
Old 01-13-2014, 03:35 PM   #431
The motor looks more "centered" on the B5M than the Centro. I added the Avid centering kit onto my centro because it was more balanced on the scales. I believe someone else on the centro thread posted their numbers.
Old 01-13-2014, 03:57 PM   #432
Ae posted a parts list detailing the parts specific to the b5 and the b5m respectively. http://www.teamassociated.com/news/r...0B5M_Team_Kits
C.Borgia is offline   Reply With Quote
Old 01-13-2014, 04:05 PM   #433
Dave De Voe's Avatar
Default RM vs MM
As far as witch is faster, it seems at or local tracks mid is slowly catching on..they do seem to be faster mid corner.
Our fastest drivers are all runnin mid motors now but our stock class is still dominated by rear motor...With more time i think mid WILL be the way to go...top cars at our track are Centro,KYO,Losi,shuey..nice mix on brands here and not one car dominates over another...The fastest cars are the new out of box types with fresh plastic
VOE RACING/LUNSFORD Ti/CIPRIOTTI CUSTOM RC/TEAM DRIVER CGRC
Team Associated RC10 B5r-B5m/RC10Worlds/RC8B Nova 21+4
"Don't think,don't blink,it takes way too long"
Best in the Northwest '11 Nitro Stadium Truck
CGRC- COTTAGE GROVE RC RACEWAY
Dave De Voe is offline   Reply With Quote
Old 01-15-2014, 12:35 AM   #434
C4PT4IN's Avatar
Had to pop in and say that this buggy looks fantastic! My only wish is that a couple more parts could be swapped over from the B4.. All my pretty aluminum..
C4PT4IN is offline   Reply With Quote
Old 01-15-2014, 10:17 AM   #435
C4PT4IN's Avatar
Are the battery thumbscrews the same on the new B5 as the old B4? Or were they 'outdated' in the whole switch to Metric? I guess they come with the 'Team Kit' at least.. I will just miss my red ones..
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
