    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 05-11-2014, 07:50 PM   #4306
gticlay's Avatar
Originally Posted by Wild Cherry View Post
Don't go by me if you like, but still think white in the rear is max ....
Car ran well, same over all time as usual , was scuffing in fresh tires though.
I like the set up..
A little less traction but more stable , you can driver harder into the corner with out the car stalling.
Tip
Discovered you may like to use the Hard rear camber mount when using the alloy hubs for extra grip. Alloy camber mount + alloy rear hub = less grip.
Also
Alloy hubs
Don't tighten down the set screw very hard as it can blind if to tight.
I wouldn't know. My hard rear camber mount broke in the first lap. Maybe it was defective (NICK!) or maybe they break easily but I wasn't happy
gticlay is offline   Reply With Quote
Old 05-11-2014, 07:54 PM   #4307
Tech Legend
Wild Cherry's Avatar
No Doublt you can't break a alloy but was surprise how much the plastic part contributes to traction for the car..
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-11-2014, 07:58 PM   #4308
gticlay's Avatar
I'll trade you my regular plastic for your aluminum...
Old 05-11-2014, 07:59 PM   #4309
If thats the case is it a bad idea to switch over to the full aluminium hubs?
splking1 is offline   Reply With Quote
Old 05-11-2014, 08:16 PM   #4310
i switched to metal rear hubs and metal camber mount with no negative effects to traction.
evolution03 is offline   Reply With Quote
Old 05-11-2014, 08:31 PM   #4311
skrichter's Avatar
Send a message via AIM to skrichter
Ridge
This inline mod has the Esc placed in the rear of chassis with the inside middle of the water fall trimmed. You put the Esc under the water fall, receiver goes on rear side next to battery like we use to do with b4.
We're also trimming the side rails of chassis brace thinner so the chassis can flex more in the area in front of the water fall to the servo.
Trim the plastic in between the battery thumb screws so battery fits inside.
Doing the mod today.
I figured this would be tested eventually -- since KYO runs this config in MM. The more things change, the more they stay the same. I think this is partly the reason why the RM car seems to corner faster (along with the swing weight).
Curious if folks will want to run the speedo in front of the battery like the TLR. It should fit if you cut the brace after the servo (on the front cradle).
Let us know how it goes.
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 05-11-2014, 08:54 PM   #4312
ridgerunner1's Avatar
Trader Rating: 21 (100%+)
You guys have something to understand , my cat dump my digital off the desk, its broken....
So I can't give you a image of the mod easy like
I'm gona try to get someone else to go though the trouble for all of you.
Its important, already know from the first test run most of you will like to do.
GTI grey way to stiff for your rear, you need green and switch back to middle hole.
If you feel like it try white rear. I Doublt you will even like compared to green.
Your gona find the B5 has mass grip & like us will be working for more steering & less stall in the corners..
And
middle holes on b5 towers are like the inside holes on b4 .
I watched George do some of his modding yesterday and the end result and watched him run it he did a very good job looks like it came that way and looked good on the track also.
Mike Craig
A&E B5M - Viper ESC
New Home Track Tacoma TRCR http://www.tacomarc.com
RIP Beremerton RC race way
ridgerunner1 is offline   Reply With Quote
Old 05-11-2014, 09:06 PM   #4313
For those who are or have run cut gears....are you shimming them to stay centered in the tranny case? If so what are you using? Thanks guys
Old 05-11-2014, 09:10 PM   #4314
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
They stay centered by themselves. The outdrives keep the diff centered and the idler gear is centered by the 2 bearings.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 05-11-2014, 09:24 PM   #4315
Thanks Matt
Old 05-11-2014, 10:30 PM   #4316
Tech Legend
Really like the alloy hub with its vertical ball stud, so I just switched back to the plastic camber mount.
Having both sides metal was a bit to stiff for my ride , it benefited from the extra grip gain by using a plastic camber mount .
George W. Cherry
Old 05-12-2014, 04:59 AM   #4317
markt311's Avatar
Trader Rating: 32 (100%+)
Wc,am I correct in assuming this is how you're cutting the battery cradle? I'll be doing the inline conversion when the kids leave for school, no dremel before 7am
PR Racing Bellgate Distributors
Caster Racing Parts
311 RC Graphics
markt311 is offline   Reply With Quote
Old 05-12-2014, 05:58 AM   #4318
Trader Rating: 312 (100%+)
1+ All these theories are just that theories.
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 05-12-2014, 06:06 AM   #4319
What hole location are you using with the alloy hubs?
Old 05-12-2014, 06:14 AM   #4320
markt311's Avatar
Attempting this post on my phone with photobucket, bear with me[URL=http://s262.photobucket.com/user/poon311/media/IMAG0547.jpg.html][/URL[URL=http://s262.photobucket.com/user/poon311/media/wildflower/IMAG0545.jpg.html][/URL[URL=http://s262.photobucket.com/user/poon311/media/IMAG0547.jpg.html][/URL[URL=http://s262.photobucket.com/user/poon311/media/wildflower/IMAG0541.jpg.html][/URL[URL=http://s262.photobucket.com/user/poon311/media/wildflower/IMAG0540.jpg.html][/URL[URL=http://s262.photobucket.com/user/poon311/media/wildflower/IMAG0542.jpg.html][/URL[URL=http://s262.photobucket.com/user/poon311/media/wildflower/IMAG0545.jpg.html][/URL[URL=http://s262.photobucket.com/user/poon311/media/wildflower/IMAG0546.jpg.html][/URL
Caster Racing Parts
311 RC Graphics
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
