    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 05-08-2014, 08:57 PM   #4201
rigor's Avatar
Trader Rating: 38 (100%+)
Originally Posted by rcfiend View Post
I just finished building my B5M and I noticed I have about a 1-2 mm gap on the rear arms. Anyone else experienced this?
If you have all the stock plastic C & D arm mount pieces then yes. Shim the rear arms forward and you'll be fine.
* Jesse H. *
rigor is offline   Reply With Quote
Old 05-08-2014, 09:03 PM   #4202
gticlay's Avatar
Originally Posted by Wildcat1971 View Post
i thought you were selling everything
Famous last words of a club racer
gticlay is offline   Reply With Quote
Old 05-08-2014, 09:11 PM   #4203
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
lol, it is someone with a similar name.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-08-2014, 09:15 PM   #4204
Tech Legend
Wild Cherry's Avatar
Rear Hard arm way good in corner & decent forward bite.
Less side bite though, maybe -25% ...
Will be racing um tommorow ..
Fit & finish is great...
Tip
You have to always pre tap & grease the threads first with the HARD plastic.
can use a steel screw & grease or the best way a threaded hand tap.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-08-2014, 09:54 PM   #4205
gticlay's Avatar
Tip
Wow, that's a big hit to side bite! I'm running hard stuff except for the arms. You most def need to pre-tap with a steel screw but haven't found need to use grease.
Old 05-08-2014, 09:55 PM   #4206
Does the MM need 25% less bite? and he is seeing this on HIGH bite.
Old 05-08-2014, 10:35 PM   #4207
SilentHunter's Avatar
Tip
Again you are writing posts that you know nothing about. Earlier you said you built your kit with the hard parts right away, so how do you know there is %25 less side bite???
Teammates? What team are you on? The team that gets there kits months after they are out? You have been posting for 2 months on a car you didn't even own
Anyone who checks this thread for advice should be smart enough to read that you often try to give advice, then say something that contradicts your previous post. Sometimes just hours after you last post.
SilentHunter is offline   Reply With Quote
Old 05-08-2014, 10:54 PM   #4208
me? why would i sell this bueatiful car? lol i just took 2nd in my local series race!
xTotalghost is offline   Reply With Quote
Old 05-08-2014, 10:56 PM   #4209
Originally Posted by vr6cj View Post
Until pucks is oug you can just use tlr 22 alum bones. Fit fine
will these work?
http://www.amain.com/product_info.ph...2-C-CVD-Bone-1
Old 05-08-2014, 11:01 PM   #4210
http://www.amain.com/product_info.ph...m-Driveshaft-2
These jones?
roundguy is offline   Reply With Quote
Old 05-08-2014, 11:13 PM   #4211
Originally Posted by roundguy View Post
those are the ones I use
Old 05-08-2014, 11:27 PM   #4212
Tech Legend
your just fine with your front end but the Hard rear may be a bit lean on grip for you.
Looking to find out which is faster at Trcr.
Performs the same as using a carbon arm verses plastic with the B4 .
Big difference between the two
in other words.
Have to grease the screws , faster...
Bridge told me go all Hard ...
George W. Cherry
Old 05-09-2014, 12:08 AM   #4213
what is that one euro company that makes b5m parts?
Old 05-09-2014, 12:22 AM   #4214
markt311's Avatar
Trader Rating: 32 (100%+)
Psm or pms, something like that
PR Racing Bellgate Distributors
Caster Racing Parts
311 RC Graphics
markt311 is offline   Reply With Quote
Old 05-09-2014, 12:32 AM   #4215
Trader Rating: 138 (100%+)
Got picked up by Trakpower for this year. I had the B5R and hated it. No parts and no setup. I will eventually have to go back to 2wheel drive buggy and the the Xray buggy for dirt is probably a year off. Is the B5M finally established setup wise? How about parts?.
TLR 22T 3.0, 2X Yokomo YZ-2 DTM, YZ-4 SF (please hurry), Mugen MBX7R Eco, Hobbywing, Futaba, LRH Hobbies, Amain Hobbies, iCharger.
jpcopeland1 is offline   Reply With Quote
