    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 05-07-2014, 11:35 AM   #4156
SMcD's Avatar
Trader Rating: 61 (100%+)
Originally Posted by Wild Cherry View Post
Could of just flipped it , no shims..
Or
no flip, but can adjust the amount of shim's for more tuneability.
@Rigor and Wild Cherry, thank you for this information
We Shall See
The Track Raceway, RCRNV, JMR
Team Jacobs Racing
YouTube: looking for turtles entertainment
B6D, X-1 2016, T4 2014 VTA, SCX-10 II
SMcD is offline   Reply With Quote
Old 05-07-2014, 12:21 PM   #4157
Send a message via ICQ to JiuHaWong
Originally Posted by Micah123 View Post
Heard different opinions on eliminator. I run a tight slipper anyway so I was used to controlling things with my trigger finger. Definitely an item you can wait on until you have a chance to practice some more. FYI, I had tightened my stock slipper to the max to emulate an eliminator but still had the associated weight of a slipper. Normally, you want to back off the throttle when landing with a tight slipper or eliminator but I have not had a problem stripping idler gears to date. The 17.5 does not have the torque of my 7.5 (strip idler gears frequently on my sc10) so probably not so critical to be off the throttle on landings.
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 05-07-2014, 03:20 PM   #4158
Leodis's Avatar
Trader Rating: 16 (100%+)
I'm liking the aluminum hubs. The black ones have a really nice finish and they only added seven grams of weight to the buggy.
Leodis is offline   Reply With Quote
Old 05-07-2014, 04:31 PM   #4159
beedee's Avatar
Made a gif.
ASSOCIATED ★
beedee is offline   Reply With Quote
Old 05-07-2014, 04:44 PM   #4160
In stock at AMain and stormer fyi
RedFormula2K is offline   Reply With Quote
Old 05-07-2014, 08:23 PM   #4161
Send a message via AIM to slappomatt
Originally Posted by beedee View Post
Made a gif.
snip
Still looks like moving your shocks to the lower holes will give you damn near the same thing with a lower CG.
slappomatt is offline   Reply With Quote
Old 05-07-2014, 08:26 PM   #4162
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Made a gif.
Aren't the two pictures at different angles?
RCBuddha is offline   Reply With Quote
Old 05-07-2014, 08:38 PM   #4163
Tried to install an Orion vortex 8.5 in my b5m and the shaft is hitting the gear cover......anyone just cut the shaft a little? I'm thinking taking the motor apart and using a cut off wheel to trim the end off. Any ideas???
losiracer22 is offline   Reply With Quote
Old 05-07-2014, 09:23 PM   #4164
Jcozz's Avatar
Trader Rating: 20 (95%+)
You could just get longer screws for the motor cover and put a 2mm washer behind the gear cover.
Jared Cozzocrea
HobbyPro PRS1 / HobbyPro SB401 / Fusion Graphics / Mayor RC
Premier RC Raceway and Hobbies
Dave's RC Tracks
Jcozz is offline   Reply With Quote
Old 05-07-2014, 09:35 PM   #4165
hanulec's Avatar
Trader Rating: 27 (100%+)
i had amazing grip with b5r front arms, b5r front tower, and b5r rear arms reversed left/right tonight. now i just need to keep my pistons from blowing out the eclips.
is anyone shimming the 'space' out of the stock pistons? i tried this -- but i think i over did it as 3 of 4 blew the eclip right off tonight ..
FJ / ROAR #2-122945 / MaxRotation FPV Drone Racing / [email protected] Awesomatix USA / Wild Turbo Fan / Mon-Tech Racing / RocheRC USA / Side Piece /
LRP / John's BSR Tires / TeamEAM / TQ Wire / R1 / Team Scream / PCR / MIX
RacerLog wiki Awesomatix A700 / 2wd offroad 4 life
hanulec is offline   Reply With Quote
Old 05-07-2014, 09:56 PM   #4166
gticlay's Avatar
That's not something you need to do.
gticlay is offline   Reply With Quote
Old 05-07-2014, 10:07 PM   #4167
kdub's Avatar
Originally Posted by NovaCX12 View Post
Assembled mine today. Have one on my B4.2. Does this look right? Kit came with a silver spacer, not sure what its for.
Looks perfect! The shim is for the TLR users that may need it if they have a long topshaft. Sorry we left that out of the instructions, will fix it next time.
Chief Engineer, Schelle Racing Innovations, SchelleRacing.com - Team Associated - Reedy - JConcepts - Sanwa - MIP - StickyKicksRC - UpGradeRC - Darkside Designs
kdub is offline   Reply With Quote
Old 05-07-2014, 10:11 PM   #4168
hanulec's Avatar
sorry.
that is an onroad guy thing to do. you guys caught me...
Old 05-07-2014, 10:36 PM   #4169
Tech Legend
Wild Cherry's Avatar
Have the Hard front end , arms & nose plate.
Adding the Hard rear tower & arms tomorrow.
Still can't get the Hard front tower.
Leaving chassis brace & tray plastic.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-08-2014, 03:13 AM   #4170
gticlay's Avatar
Wow, where do all my electronics and wires fit? Dropped right in the RM but with the MM, not so much. It's a bowl of spaghetti.
And, installed hard front camber, steering, RM tower, reg flat arms, and hard rear hubs and tower. Can't wait to drive it!
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
