    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree17Likes
Old 04-30-2014, 08:01 AM   #3961
aeRayls's Avatar
Originally Posted by TJ Hart View Post
In a recent video by Jason Snyder, he talked about tire wear and a wear line down the middle of the rear tire is caused from too much wheelspin. I just got done with 2 days of racing this weekend with my B5m, and my rear tires are bald down the center. Is there anything I can do, or anything I should do to prevent this from happening? I have a lot of traction, so that isn't an issue.
Prevent that from happening? Ummm no, that's precisely what is supposed to happen lol
Tires do not wear uniformly. Where at on the tire depends on your camber and type of track. My local track usually has more right hand turns and high speed ones at that, so our left rears always wear faster.
If your tires are wearing right down the middle, that's called business as usual haha.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 04-30-2014, 08:16 AM   #3962
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I have noticed the CC foams wear in a wider pattern than OC foams. For me because of this, I get a little longer life out of the rears. I also noticed the same thing on my fronts as you said, we have a lot of lefts and my right front has way more wear than the front right.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-30-2014, 09:27 AM   #3963
rigor's Avatar
Trader Rating: 38 (100%+)
Not directed at or meant in any offensive way... but don't believe everything you hear or read in RC.
* Jesse H. *
rigor is offline   Reply With Quote
Old 04-30-2014, 09:36 AM   #3964
rigor's Avatar
Originally Posted by sir_thomas View Post
Hey guys, this just got posted a few minutes ago. Schoettler's winning setup and pics from the JConcepts Spring Indoor Champs @ TRCR.
http://2wdmod.com/2014/04/29/schoett...concepts-trcr/
Bookmark, save, share!
O M G. The elusive, magical, super dialed in after days of intense tortuous testing for just this specific tire... on only the TCRC clay setup sheet!
Oh. Wait. It's practically just kit setup with some different oil and springs
Good job MS on holding it down up there. However this looks like every other indoor clay setup I've come across. Less tweaks here actually.
* Jesse H. *
Old 04-30-2014, 09:44 AM   #3965
Mason's Avatar
you noticed it too.. well if it works for him i guess. can't wait to hear from the fanbois that absolutely need to know what gauge servo wire he ran.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 04-30-2014, 09:53 AM   #3966
Well IMO, Jason was not wrong per say, but maybe not very clear. If your tired balloon up when you get on power coming out of the corners, the thin middle section will wear faster with open cells. I have less issues ballooning with closed cells. "If" you over revving and ballooning the tires, the middle will wear quickly. I assume Jason was referring to something along those lines. I have seen guys balloon the inside tires coming around a 180. I mean, their tires are like 4in tall at the center. It is very very visible to anyone. This sort of thing will wear out the centers faster, because the main reason that tire is that big is a combo of lack of traction (weight is being transferred off the tire) and too much trigger or too sudden trigger pull. But, you can also run the centers out fast with a hot motor that is quickly getting up to rpm. The higher your rpm, the more the center of the tire is the only thing making contact with the track. And with less rubber on the track, you also increase your chance of slipping/losing traction.
Old 04-30-2014, 10:09 AM   #3967
Tech Legend
Wild Cherry's Avatar
Who is Jason Snyder ?
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 04-30-2014, 10:19 AM   #3968
Suspended
Bob Snyder's brother
Pimp Formally Known as OG
PFKAOG is offline   Reply With Quote
Old 04-30-2014, 10:27 AM   #3969
Tech Legend
good job ???
Mike best the world champ
TACOMPTON Style.... welcome to the hood bro.
George W. Cherry
Old 04-30-2014, 12:07 PM   #3970
Originally Posted by Sean Cochran View Post
OK we should have included a slip of paper to clear all this up. Sorry.
This is the way it should be.
The etched 0 faces the shock. This means rear motor it is forward and mid motor it's back.
3mm of ball-stud spacing makes the high position. 1mm is the low. The kit hub has 5 link length options, with the aluminum hub you no longer have the longest/ outer ball position. Be careful about the thread length ball stud you use, if it's too long it will crush the bearing in a couple of positions. 6mm thread is recommended with 3mm spacing.
Sean is this going on the AE website -- perhaps on the page for the hubs?
34x17 is offline   Reply With Quote
Old 04-30-2014, 12:33 PM   #3971
Send a message via ICQ to JiuHaWong
Is that 16 guage wire?
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 04-30-2014, 12:33 PM   #3972
Adam you arent wrong by any means......but being over motored can definitely make things worse.....and cause premature tire wear.....which is why guys like Maifield go down to 8.5's for indoor when traction is lower......when he normally goes 7.5 everywhere else.
Jason Snyder
Check out my "YouTube" channel
www.youtube.com/shortcourseworld
Jason Snyder is offline   Reply With Quote
Old 04-30-2014, 12:34 PM   #3973
hard to tell, maybe TQ thin walled 13awg
Old 04-30-2014, 12:34 PM   #3974
Or ................long pause
the guy that owns Snyder's Pretzels!
Just Sayin!
Jason Snyder
Old 04-30-2014, 12:51 PM   #3975
Tech Legend
Tip:
Ck out how Mike vents the tire ....
George W. Cherry
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
