    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree10Likes
Old 04-29-2014, 10:04 AM   #3916
Default Schoettler's winning setup!
Hey guys, this just got posted a few minutes ago. Schoettler's winning setup and pics from the JConcepts Spring Indoor Champs @ TRCR.
http://2wdmod.com/2014/04/29/schoett...concepts-trcr/
Bookmark, save, share!
sir_thomas is offline   Reply With Quote
Old 04-29-2014, 10:06 AM   #3917
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Originally Posted by JiuHaWong View Post
Or someone can just post the information on the first page. Something like:
THERE IS NO ETA ON THE FACTORY TEAM KIT.
You would have to get ahold of the person responsible for that....
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-29-2014, 10:07 AM   #3918
Send a message via ICQ to JiuHaWong
Don't they read the thread anymore?
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 04-29-2014, 10:09 AM   #3919
Super Moderator
He's busy making reviews of Liquid Wrench...
Someone would have to pm him the info needed to put on the 1st page.
Old 04-29-2014, 10:57 AM   #3920
Originally Posted by aeRayls View Post
AE alum rear hubs:
Mid car=etching to the rear
Rear car=etching to the front
I can't see this as being right. When i look at the hubs if you install them the way you are saying the the off set on the metal hub wouldn't be the same as the stock hubs. Associated needs to release some info.
evolution03 is offline   Reply With Quote
Old 04-29-2014, 11:01 AM   #3921
aeRayls's Avatar
Sure feels right on my rear car....
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 04-29-2014, 11:05 AM   #3922
kinda aggravating They should have released the info when they released the hubs. i don't even want to install them. Which hole are you using ? Are you using 3mm spacer ?
Old 04-29-2014, 11:06 AM   #3923
Super Moderator
They are 0...put them on either way. It doesnt matter.
Old 04-29-2014, 11:08 AM   #3924
it does matter it effects the sweep of the axle and hub they are offset
Old 04-29-2014, 11:10 AM   #3925
Super Moderator
It looks like the only thing that is 'offset' from center is the camber link mount.
Old 04-29-2014, 11:12 AM   #3926
exactly so it does matter the axle would be swept forward or back depending on the way the hubs were mounted and it effect the holes too on top of hub.
Old 04-29-2014, 11:22 AM   #3927
Just built up my B5M. I want to run flat front arms but I can't find a flat tower anywhere.
I can run the gull wing tower if I use the outer shock mount holes on the tower and the outer holes on the flat arms (both holes on the arms will work).
Any reason I can't do this? Would the outer or inner holes on the arms be better?
DWill is offline   Reply With Quote
Old 04-29-2014, 11:24 AM   #3928
Super Moderator
Where the camber link mounts has no effect on where the axle is positioned.
http://events.redrc.net/wp-content/u...Sun-BTB5-5.jpg
There isnt etching on these but i would say it looks like etching is forward on the rear motor.
Old 04-29-2014, 11:55 AM   #3929
lee_double2000's Avatar
Trader Rating: 45 (100%+)
Check team associated website. They have the front towers in stock.
lee_double2000 is offline   Reply With Quote
Old 04-29-2014, 11:59 AM   #3930
Default curious
Are u running the b5 rear arms or are u running the standard b5m rear arms? In my opinion if u are running the b5 rear arms on ur b5m wouldn't u want to run aluminum hubs with etching forward then? Just curious. Thanks
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
