    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree17Likes
Old 04-26-2014, 12:01 AM   #3841
what are the 2 small silver washers that come with the aluminum steering for?
SDRC
Associated
TLR
Tekno
uclabruins89 is offline   Reply With Quote
Old 04-26-2014, 12:02 AM   #3842
gticlay's Avatar
Crush washer between the bearings.
gticlay is offline   Reply With Quote
Old 04-26-2014, 01:31 AM   #3843
Anyone have a good set up for these new aluminum rear hubs? I called AE and they had no clue what even the stock setup was
splking1 is offline   Reply With Quote
Old 04-26-2014, 12:34 PM   #3844
Suspended
Just ordered mine from racedayhobbies.com.
They had them in stock.
Hope I can get it ready for the first race at LRT.
Top step of the podium; here I come.
irishracing31 is offline   Reply With Quote
Old 04-26-2014, 03:17 PM   #3845
lee_double2000's Avatar
Trader Rating: 45 (100%+)
I found this in the B5 thread. Not sure how accurate but may give you some new input:
Originally Posted by toddmanley View Post
Just got off the phone with AE...
On the rear motor B5 you want the "0*" etching facing backwards (opposite for the mid-motor). Time to swap things around.
Ugh...they called me back and told me otherwise. Apparently the etching needs to face the shock. So it will face forward on the rear-mount, backward on the mid-mount. Sorry for the confusion. They also shared the intent to get a quick document published online to show how the hub differences convert vis-a-vis the ball stud hole mounts and how that compares to the hub inserts on the plastic version.
lee_double2000 is offline   Reply With Quote
Old 04-26-2014, 03:53 PM   #3846
Whats the best lubricant to use on the gears inside the transmission case for minimum friction, i'm running stock class.
I have permatex white lithium grease, plus the normal RC greases.
SDRC
Associated
TLR
Tekno
Old 04-26-2014, 04:41 PM   #3847
I run the stock and don't recommend using anytype of grease. I use bearing oil from avid racing.
Old 04-26-2014, 04:45 PM   #3848
Thanks ill have to pick some up my track owner also recommended bearing oil... for now using low friction white lithium grease made by permatex...works well so far in my rear b5
SDRC
Associated
TLR
Tekno
Old 04-26-2014, 05:17 PM   #3849
SilentHunter's Avatar
Green Slime works great
SilentHunter is offline   Reply With Quote
Old 04-26-2014, 05:41 PM   #3850
Great they told be otherwise. Wonder which is really the right direction. I had talked to someone there yesterday before I installed them. Saying on the mid motor eching needs to face foward
Old 04-26-2014, 06:33 PM   #3851
mdowney's Avatar
Trader Rating: 21 (100%+)
Just wanted to point out that this is super important. The first batch of aluminum steering racks that went out did not include the crush washer and it resulted in a gritty feel in the steering rack. If you got one of the first batch just email AE and they'll send you a replacement.
And to be clear, you put that little washer in between the two bearings on the rack. It's just like the crush washer that goes between the bearings in the front steering blocks.
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 04-26-2014, 09:40 PM   #3852
I was running the 0 degree marks forward. Car handled horrible yesterday. I hope switching them will solve the issue. Find out Tuesday
Old 04-26-2014, 09:56 PM   #3853
which camber link location is a good start for the rear aluminum hubs?
SDRC
Associated
TLR
Tekno
Old 04-27-2014, 10:19 AM   #3854
Cridd's Avatar
Trader Rating: 16 (100%+)
Anybody know weights on turnbuckles, FT, Lunsford and JC's. Need to buy a set and just really want the lightest set.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 04-27-2014, 10:36 AM   #3855
aeRayls's Avatar
AE alum rear hubs:
Mid car=etching to the rear
Rear car=etching to the front
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
