    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree10Likes
Old 04-19-2014, 05:10 AM   #3676
Trader Rating: 90 (100%+)
I was thinking that also.. May want to run a longer SS steel 3mm screw or 3mm tap to tap the those holes.
dan-o is offline   Reply With Quote
Old 04-19-2014, 05:48 AM   #3677
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
SS is softer. That only makes the issue worse. But tapping it would be good
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-19-2014, 07:39 AM   #3678
racer_guy's Avatar
Originally Posted by mdowney View Post
Quick tip for anyone using the 3x8mm set screws in the front caster blocks (which eliminates most of the slop): those little screws strip VERY easily so don't over-tighten and back them out very carefully. If they strip you'll never get that caster block off the hinge pin in one piece. You'll be hacking away at it with the Dremel like I just did.
good lookin out!! so is it worth getting them as far as getting the job done is concerned?
W.E.D. Winning Edge Designs
racer_guy is offline   Reply With Quote
Old 04-19-2014, 07:43 AM   #3679
Trader Rating: 27 (100%+)
Good tip...you can use one of the longer M3 BHCS screws from the kit to thread the holes first.
Trying to take the RC racing world by storm (of course I have a long, long way to go)!
AE RC10B5 | Airtronics | Sanwa | Reedy | SMC | Savox | J-Concepts | Schelle
langsky is offline   Reply With Quote
Old 04-19-2014, 07:44 AM   #3680
They most defininately take the slop out.
Old 04-19-2014, 08:22 AM   #3681
Bracer11's Avatar
I currently race a schumacher KF and have always had a B5m in the back of my head. From the guys that race what have you seen comparing the two and would it be an "upgrade" to switch? I run on indoor ozite offroad track.
Bracer11 is offline   Reply With Quote
Old 04-19-2014, 10:51 AM   #3682
suby723's Avatar
Trader Rating: 21 (100%+)
The kf really isn't the greatest dirt track car. I have my b5m paired with a k1 btw. Get the b5m if you want a better working mm car for dirt tracks.
suby723 is offline   Reply With Quote
Old 04-19-2014, 12:36 PM   #3683
mdowney's Avatar
Definitely worth using. My mistake was using stainless steel as it's softer. I'm switching to standard. They're cheaper anyways.
Great idea! Thanks!
Mike Downey
I try all of the RC kits and usually race at Tacoma RC Raceway
mdowney is offline   Reply With Quote
Old 04-19-2014, 02:02 PM   #3684
Bracer11's Avatar
Yeah I agree about the KF not being a good dirt track car. Im wondering how they compare on carpet.
Old 04-19-2014, 03:35 PM   #3685
Trader Rating: 17 (100%+)
Now that the low traction kit is out for the KF it will be great on dirt too. No mid motor corners or jumps quite like the KF. Combine that with traction on dirt and it will hang with the B5M I am sure. But price wise the B5M is the way to go.
AlderBoy is offline   Reply With Quote
Old 04-19-2014, 08:19 PM   #3686
Set screws came in the mail today and just finished installing them. Most if not all slop is gone. I was most concerned with the rear hubs and the excessive play, but I used 2 on each side and the rear feels like a fresh build with no play. If you haven't done this yet, consider doing it. You will be amazed how everything tightens up.
Oldgearhead is offline   Reply With Quote
Old 04-20-2014, 09:31 AM   #3687
racer_guy's Avatar
ey guys. so what servo horn would i use for a ko propo rsx2? there are only ones for airtronics, futaba, hitec, and jr. thanks in advance
Old 04-20-2014, 09:52 AM   #3688
Tradin Paint's Avatar
Quick internet search showed that they are the same as the JR and Airtronics
Happy with: Team Associated, Team Tekin, Airtronics, Avid, JConcepts, Fantom motors and Aero Model batteries.
Proud Supporter of Warehouse 3 RC Hobby Shop, that just happens to have an indoor track
"Because Size Does Matter"
Ryan H.
Tradin Paint is offline   Reply With Quote
Old 04-20-2014, 10:25 AM   #3689
rigor's Avatar
Trader Rating: 38 (100%+)
Just start trying them on. I'm sure one will fit properly.
* Jesse H. *
rigor is offline   Reply With Quote
Old 04-20-2014, 10:40 AM   #3690
Tech Legend
Wild Cherry's Avatar
Getting inpatient , been waiting for more kits & parts long ,long time now..
Hoping I see the parts and all this week...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
