    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree10Likes
Old 04-11-2014, 03:48 PM   #3436
predu's Avatar
Originally Posted by rigor View Post
Hartson's setup from the MHOR race last weekend:
http://www.teamassociated.com/pdf/ca...ls_Hartson.pdf
i hear that track is closing
SC10.2 , LRP, SCHUURSPEED 17.5
B4.2, LRP, SCHUURSPEED 17.5
TC6.1, LRP, SCHUURSPEED17.5
TC7 , LRP, SCHUURSPEED 17.5
10R5.1, H/W, SCHUURSPEED 17.5
predu is offline   Reply With Quote
Old 04-11-2014, 05:15 PM   #3437
Originally Posted by BIGTIME View Post
I keep hearing if you are running stock and stock only B5R is better.
Is there any truth to that?
Yeah a lot of people tell me this also. I'm one of the few with a b5m in the stock class at our track.
splking1 is offline   Reply With Quote
Old 04-11-2014, 08:12 PM   #3438
Trader Rating: 14 (100%+)
This makes no sense to me. Stock is all about momentum and corner speed. Thats what MM is built for. RM is more point and shoot. You need motor to be able to start from a dead stop every turn. Of course that is an over generalization but you get the point.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 04-11-2014, 08:14 PM   #3439
seth556's Avatar
Trader Rating: 42 (100%+)
That's Intermountain. MHOR, in Denver, has been around forever and ever.
seth556 is offline   Reply With Quote
Old 04-11-2014, 08:21 PM   #3440
DG.... you are right on... although some of these guys are obsessed with the weight of the car and it has to be as light as possible and that's the only way they can be fast.. but you are right.. corner speed and momentum are huge....
I know people will disagree with me, but I don't care how light a car is , if you cant drive it fast the whole time your still not going to win.
yes the rear motor is lighter, but with a good setup the mid motor is faster because of what you said.. corner speed and momentum.
rickster is offline   Reply With Quote
Old 04-11-2014, 11:02 PM   #3441
predu's Avatar
Oh. The sheet said intermountain on top
Old 04-12-2014, 12:20 AM   #3442
Nemaris's Avatar
Trader Rating: 18 (100%+)
Originally Posted by splking1 View Post
For anyone that has done the b5 rear arms. Did you use a spacer at all? I'm using im the 1mm spacer on the back side and it real tight. Didn't know if you guys sanded the arms down or just pulled the washer.
I would also like to know what exactly people did besides tapping out the hinge pin holes in order to run the b5 rear arms.
Nemaris is offline   Reply With Quote
Old 04-12-2014, 03:39 AM   #3443
F18engineguy's Avatar
Trader Rating: 216 (100%+)
Here is what it looks like under the hood
What did you do to that servo wire so that it did not hit the servo mount?
VA Beach
F18engineguy is offline   Reply With Quote
Old 04-12-2014, 04:50 AM   #3444
Trader Rating: 315 (100%+)
Does the B4.2 gear diff fit?
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 04-12-2014, 08:28 AM   #3445
seth556's Avatar
AH ok, I just saw MHOR. You're right.
Old 04-12-2014, 10:59 AM   #3446
cbaranski's Avatar
Trader Rating: 43 (100%+)
I have a question, where do the 2 silver washers go for the aluminum steering arms? Thank you in advance.
Chuck
Chuck Baranski www,pikemotorsportsrc.com
Xfactory SCX60CF w/ 12mm BB, Tekin RSX, Tekin RPM 17.5, Savox 1258
AE B5M FT, Tekin RS, Tekin RPM 17.5, Savox 1258tg
cbaranski is offline   Reply With Quote
Old 04-12-2014, 11:05 AM   #3447
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I am running a .5 mm spacer
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-12-2014, 11:47 AM   #3448
Chuck
They go between the bearings in the composite portion of the steering rack. I installed my bottom bearings first, placed the crush washers in, then installed the upper bearings. Then you can use a little bit of blue loctite on the screws and carefully snug the rack to the aluminum steering arms. I have to say mine is the smoothest bellcrank I think I have ever assembled, it has zero slop and is tight but free also. Very good tolerances.
StadiumRC is offline   Reply With Quote
Old 04-12-2014, 11:53 AM   #3449
I took the back case off and relocated the wires to come out the back
Old 04-12-2014, 11:55 AM   #3450
Not sure what your talking about. I didn't tap anything. Just put the right are on the left side. I did shave the chassi down just to make sure the arms didn't hit since I spaced them foward 1mm
