    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 04-10-2014, 04:52 PM   #3406
Super Moderator
Trader Rating: 17 (100%+)
Originally Posted by thecman26 View Post
The tiny Protek 3000mah shorty is the crazy light one!
http://www.area52.cc/news/2266-prote...-70c-lipo.html
151g
yeah I saw one of the guys try this in his 22 at Motorama and he had to take it out. He said the car just wouldn't handle right with it. Put his std shorty back in and was good to go.
It definitely is tiny and light though if that's what you are looking for.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 04-10-2014, 05:01 PM   #3407
Carranza76's Avatar
Originally Posted by Cpt.America View Post
yep. Most shorties are ~200, most full sized are around ~300. 150g for a shorty? that would be one low capacity battery... or a 1 cell.
this battery for 17.5 stock buggy is awesome. and the punch for a 7 min main is great. Really no fall off near the end of a race. I have two.
http://www.amain.com/product_info.ph...ts-74V-3200mAh
Pegasus Raceway
IERC Raceway
TLR & Tekin are my main squeeze's!
Yokomo BD7
Carranza76 is offline   Reply With Quote
Old 04-10-2014, 05:09 PM   #3408
http://www.promatchracing.com/prodde...prod=2S350090C
These have 300 mah less than the venom ones everyone runs and they quite a bit lighter.
Justinb86 is offline   Reply With Quote
Old 04-10-2014, 05:41 PM   #3409
gticlay's Avatar
Those last two links look like the exact same pack from the same manufacturer except one is $20 more...
gticlay is offline   Reply With Quote
Old 04-10-2014, 06:10 PM   #3410
Jake S's Avatar
Trader Rating: 66 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
and has less rated mah :P
what i want is a 4200mah square... so its like 240g for mod.
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 04-10-2014, 07:05 PM   #3411
thecman26's Avatar
Trader Rating: 99 (100%+)
I liked it in my B4.2 for stock class, it was a porker anyways, so the less battery weight was great. In my B5 I like saddles as they are a bit heavier.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 04-10-2014, 10:59 PM   #3412
Cridd's Avatar
Trader Rating: 16 (100%+)
Trackpower has a good battery coming out soon. I love my shorties though.
2S/7.4V 3250mAh 90C Battery
TKPC0607
Continuous Discharge Rate: 90C (297A)
Discharge/Balance Connectors: 4 mm bullet / 2 mm bullet
Dimensions: 1.9 x 0.75 x 3.7 in (47 x 19 x 94 mm)
Weight: 5.4 oz (153 g)
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 04-10-2014, 11:29 PM   #3413
Update from tonight at the track. Here is what I changed and it seemed to help the pushing issues on throttle
Green springs 27.5 weight up front
White springs 30 weights in rear
Front hubs spaced back
Steering/ank 1mm
Every thing else is the Ryan mayfield setup at warehouse 3
splking1 is offline   Reply With Quote
Old 04-11-2014, 12:16 AM   #3414
Tech Legend
Wild Cherry's Avatar
Splking, try adding 1/2 oz in front of servo on the chassis.
We add that much to keep the front down & smooth the steering entering the corners & sweeper.
We will also add the weight when ever the car begins to pull wheelies coming onto the straights.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 04-11-2014, 03:57 AM   #3415
Bcholka's Avatar
Splking:
Apologies if you already tried these 2 things:
Raise front spindle height?
Ball diff too tight?
2-Tekno EB48.2's, 1-Tekno ET48, 1-Tekno NB48, 1-Tekno NT48, 1-Tekno SCT-410, 1-AE B5, 1-AE B5M, 1-Kyosho RT6, 1-Kyosho MP9e TKi, 1-TLR Losi Mini 8ight
Our Awesome Sponsors: Tekno RC, AKA Tires, Dialed Designs Airbrushing
Special Thanks to: Trackside Raceway, Clark R/C Park & RC Scoring Pro
Bcholka is offline   Reply With Quote
Old 04-11-2014, 05:26 AM   #3416
Raise the rear ride height and lower the front so you're at a 1mm split biased to the rear (rear higher). To go along with that, I would add another limiter to the front shocks to keep the weight on the front end. Unless you have tried those things already, then kindly disregard
adam lancia is offline   Reply With Quote
Old 04-11-2014, 07:29 AM   #3417
Hey,
im searching for the original kit Body but noone knows anything when/where to buy. Even associated Germany doensn`t know. Any thoughts?
Ice22 is offline   Reply With Quote
Old 04-11-2014, 08:36 AM   #3418
racer_guy's Avatar
jconcepts silencer
W.E.D. Winning Edge Designs
racer_guy is offline   Reply With Quote
Old 04-11-2014, 08:45 AM   #3419
Ok ill do that today before the track. Ill have to mount that to my transponder and that is were it is located
Old 04-11-2014, 08:54 AM   #3420
Tech Legend
Splking, keep it simple and just add the 1/2 oz on top of the servo.
If you like or not easy to remove or move later in front of servo.
I have one team mate who is using the extra weight of the front, he is using a shorty servo.
He adds it right on the back of the servo .
George W. Cherry
