    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 04-08-2014, 04:12 PM   #3301
Originally Posted by gticlay View Post
He used the wrong nuts. I used the flanged nuts and they are a perfect fit.
Yeah i didnt use the stock one. I liked the blue nuts better and no one had the flanged blues
splking1 is offline   Reply With Quote
Old 04-08-2014, 04:15 PM   #3302
gticlay's Avatar
Try these. http://www.dynamiterc.com/Products/D...ProdID=DYN8552
gticlay is offline   Reply With Quote
Old 04-08-2014, 04:24 PM   #3303
bilster44's Avatar
Originally Posted by -WHEELMAN- View Post
Nowhere
Grrrrr!
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 04-08-2014, 04:53 PM   #3304
Awesome! Thank you
Old 04-08-2014, 05:24 PM   #3305
Trader Rating: 50 (98%+)
Send a message via AIM to micrors4guy
I should be getting one hopefully by the end of the month. we will be doing some carpet offroad and clay racing with it. Cant Wait
Rob Jensen
Thanks to the following companies for their support in 2017: Team Associated, Maclan, Fierce R/C Solutions
micrors4guy is offline   Reply With Quote
Old 04-08-2014, 08:41 PM   #3306
BillPear's Avatar
Send a message via Yahoo to BillPear
Originally Posted by bilster44 View Post
Where can I get a milled/machined motor plate? (that is in stock NOW) LOL
Your local machinist.
BillPear is offline   Reply With Quote
Old 04-08-2014, 08:44 PM   #3307
BillPear's Avatar
Here it is at ready to run with battery.
Is that with a standard shorty or the 3200mAh Pro-tek? Either way congrats.
Old 04-08-2014, 08:47 PM   #3308
BillPear's Avatar
Originally Posted by Wildcat1971 View Post
is your tire touching the scale? if so, it will throw off the numbers. Also it will be thrown off by not centering the weight on the scale.
No it won't, stand on your bathroom scale with one foot and see how much thinner you are! The only thing that will throw as scale off is not being level. If you do lose weight by shifting the load on the balance plate assume your scale is crap anyway. Saulters are a very well recommended kitchen scale.You can argue with me if you like but I did spend 3 years working in a calibration lab, for NASA.
Old 04-08-2014, 09:02 PM   #3309
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
lol, with my scale it maters. But it is just a $10 postal scale. So I need to center the weight
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-08-2014, 10:11 PM   #3310
Yeah just got them in today :-)
Old 04-08-2014, 10:13 PM   #3311
Need some help. My car comes in at 1473. Tonight is the first time running it this light. The car pushes so bad. I've moved battery all the way foward. Also went to black springs. I'm running 30 wt oil in front. Any tips on getting it not to push so bad
Old 04-08-2014, 11:21 PM   #3312
rigor's Avatar
Trader Rating: 38 (100%+)
Thanks for the advise. I'll try all whites tomorrow before switching oil
Why are you still running black springs ?
Did you ever post your setup sheet ? Seems everyone having success and enjoyment with the car are all very close in setup. I can post my updated one tomorrow if it helps.
* Jesse H. *
rigor is offline   Reply With Quote
Old 04-08-2014, 11:26 PM   #3313
I ran the white springs all the way around at first. It pushed even more. I'm running the Ryan mayfield setup since it's the same track. Only difference is shock set up. 2x1.6 pistons front oil 30w. Rear oil 27.5 with black springs all around.
Front arms are flat with b5 tower along with b5 rear arms as well.
If you can post your that would be great man I appreciate the help.
Old 04-08-2014, 11:43 PM   #3314
racer x 1's Avatar
Trader Rating: 27 (100%+)
I ran the white springs at first. It pushed even more. I'm running the Ryan mayfield setup since it's the same track. Only difference is shock set up. 2x1.6 pistons front oil 30w. Rear oil 27.5 with black springs all around.
try going stiffer all around. youd be surprised to find that a stiffer front spring can make the car react a bit quicker as the front will not dump over as far. for a while I was running gray fronts and blue rears on my xfactory! Yes I know different car.... same theory.
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 04-09-2014, 05:56 AM   #3315
Super Moderator
Trader Rating: 17 (100%+)
put a square pack in for more weight transfer
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
