    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 04-03-2014, 07:29 PM   #3121
rigor's Avatar
Trader Rating: 37 (100%+)
Originally Posted by pumpkinfish View Post
I run mod also. 8.5turn feels great in this car on my track. Still curious about gear diff also. One guy with a Centro runs one and his car is always locked in.
Gear diff should only really be needed in 2wd buggy if you're on carpet or super high bite dirt/clay. You can obviously use it on any surface, but that is where it shines and is needed from my understanding.
* Jesse H. *
rigor is offline   Reply With Quote
Old 04-03-2014, 07:53 PM   #3122
BillPear's Avatar
Send a message via Yahoo to BillPear
Originally Posted by rigor View Post
Yeah I never grabbed the old Avid slipper setup for my B4.1 (running stock at the time). I was running my B44.2 a lot which had the VTS when it was brand new from AE, and it was way more consistent and easier to set than the old style slipper on on my old B44.1 , so I was happy.
Just bought a bunch of other new goodies for my B5m, so I'll have to yet wait again to try the Schelle slipper setup.
Most good indoor clay setups I've seen have been pretty similar, with very slight tweaks in oil / spring / roll centers
Seems a lot are gravitating towards 3 x 1.4mm front pistons, and oils are getting lighter. Also the inside rear shock tower hole on the rear seems to be a popular option.
What'd you get? Maybe I'll see you tomorrow and you can tell me.
I'm surprised you never tried Kody's setup with the 1.4x3 pistons.
BillPear is offline   Reply With Quote
Old 04-03-2014, 08:41 PM   #3123
Skinny_j's Avatar
So has anyone tried to put b4 a arms on the b5 yet? they look identical as far as mounting points go, same length, same shock mounting position, and even the spacing for the hubs and inner hinge pins are the same. Theyre just straight instead of gullwing. The hinge pin diameters might be different, not sure. Yeah the geometry for the straight arms might not be perfect without the tower but I might get you through a race. Im too lazy to tear the front apart and see if it will fit, but I did muster up enough energy to take a comparison pic.
Skinny_j is offline   Reply With Quote
Old 04-03-2014, 10:14 PM   #3124
racer x 1's Avatar
Trader Rating: 27 (100%+)
drill the b4 arms for 3mm hinge pin and you should be golden. I have the b5 hubs on my b4
Matt Bell
Mugen MRX5 Ae R5.2 X6^3 M11x All powered by Speedtech Rc
racer x 1 is offline   Reply With Quote
Old 04-03-2014, 10:32 PM   #3125
Tech Legend
Wild Cherry's Avatar
Originally Posted by Skeeter36 View Post
as of late how dare you mention adding weight lol, im jk but alot of peers on here are doing everything in their power to shed weight. Car comes in at roughly 1550 gr. which in my opinion is pretty good. If i need a lil more steering or rear bite i will transfer a weight stack to either fron or rear and it seems to help. I run mod though, stock driver would probably frown on this tuning option.
Not sure about using front ballast unless you are using a shorty servo.
With a standard servo like a Xp ?
I'm adding the alloy front arm brace for its extra weight. So I do appreciate where your coming from though.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 04-03-2014, 10:39 PM   #3126
markt311's Avatar
Trader Rating: 32 (100%+)
Only weight I added was 10 grams in the nose, pull the front arm mount and there is plenty of room to stick a weight in the cavity there.
PR Racing Bellgate Distributors
Caster Racing Parts
311 RC Graphics
markt311 is offline   Reply With Quote
Old 04-03-2014, 10:51 PM   #3127
suby723's Avatar
Trader Rating: 21 (100%+)
It works! Of course doing this with b5rm tower.
suby723 is offline   Reply With Quote
Old 04-03-2014, 10:54 PM   #3128
Ok so I moved my shorty all the way forwrd running 3mm front inserts and 1mm washer instead of 2mm washer on the front shock tower. This should fix my pushing issuee
xTotalghost is offline   Reply With Quote
Old 04-03-2014, 10:58 PM   #3129
just shows there are several ways to tune the car to personal liking...
rickster is offline   Reply With Quote
Old 04-04-2014, 12:21 AM   #3130
thecman26's Avatar
Trader Rating: 99 (100%+)
If that doesn't totally fix it, you could also try unscrewing the front shock ends a turn or two.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 04-04-2014, 06:31 AM   #3131
Mason's Avatar
xTotalghost.. can you post your complete set up again?
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 04-04-2014, 07:27 AM   #3132
Mason's Avatar
Anyone else figure out how to alter the front axle height seeing how the setup sheet has a spot for it? Move the shoulder bushings to the outside and shim accordingly??
Mason McCombs
Old 04-04-2014, 07:32 AM   #3133
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
AE is releasing bushings that will allow you to do this...they just arent out yet. I took the ones on my rear motor and dremeled (took about 5 minutes) 1mm off 2 of them so that I could move the spindle up. I really liked it on my rear and plan on trying it on the mid next time out.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-04-2014, 07:40 AM   #3134
xghost.. I am not sure the type of track your running on but if you need more steering try the 30 deg caster blocks.. or first try taking the 2mm spacer that's behind the front steering/axel block out and putting it infront of it. this will move the front wheels back 2mm and put more weight over front end giving more steering everywhere.
unless you like the battery all way forward... traction in back still?
Old 04-04-2014, 08:54 AM   #3135
rigor's Avatar
Wow... Too lazy ? It's 4 screws (2 front bumper, 2 front hinge block) plus the small capture screws to hold the hinges in. 90 seconds to find out dude
Since the actual B5 gullwing arms don't have the right geometry for the flat B5 shock tower, and vice versa, I'm guessing the B4 ones aren't going to work out. It might fit and work, but suspension travel will likely suffer. Guess we all won't know because you'd lose 20 seconds of your life to find out! J/K
* Jesse H. *
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
