    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-29-2014, 07:26 PM   #2926
racer_guy's Avatar
lets talk shock mounts...whats the difference between the 91446 and the 91533 ? both are in the ft section of the manual
W.E.D. Winning Edge Designs
racer_guy is offline   Reply With Quote
Old 03-29-2014, 08:06 PM   #2927
Jmuck69's Avatar
Trader Rating: 14 (100%+)
Same design but the 91533 (shorter) is used on the rear of the B5M and the 91446 (longer) is used on the front. On the B5, the 91446 is used front and rear. You also have to get the 91447 bushings for the mounts.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 03-29-2014, 08:22 PM   #2928
racer_guy's Avatar
fo sho. well at least you will have an xtra set :/
Old 03-29-2014, 10:06 PM   #2929
BillPear's Avatar
Send a message via Yahoo to BillPear
That seems a little bit odd since both cars you the same plastic mount/bushing.
BillPear is offline   Reply With Quote
Old 03-29-2014, 10:23 PM   #2930
SMcD's Avatar
Trader Rating: 61 (100%+)
Originally Posted by JiuHaWong View Post
Not sure I follow (might be a translation issue).
I use the shock pump after refilling the shocks with clean oil and after pumping the shock shaft and piston (no cap installed). It creates a vacuum which removes the bubbles at a much faster rate then if you were to fill/pump and then let sit in a shock stand. I then follow the bleeding procedure outlined in this video:
http://www.youtube.com/watch?v=-hU6B9Z62hw
I originally bought the shock pump for my Tamiya TRF sedan shocks, but it works well with any offroad shock.
I was skeptical at first, but it does work, and I look at it like shock pliers...not necessary, but nice to have.
I have the same tool, which I highly recommend. Put shocks in, pump, get a doughnut, coffee, hit the head, pop lid, build shocks no bubbles - ...
We Shall See
The Track Raceway, RCRNV, JMR
Team Jacobs Racing
YouTube: looking for turtles entertainment
B6D, X-1 2016, T4 2014 VTA, SCX-10 II
SMcD is offline   Reply With Quote
Old 03-29-2014, 11:21 PM   #2931
hey pumpkinfish..
on your setup its hard to say as tracks around country even though yours is hardpack its a different surface then what ryan ran on at cactus.. and I am sure your driving styles are not the same either.
what are your jumps like? big ? small? is track smooth or bumpy hard pack? all make a difference.
go back to a 1.6 pistion front and back, 35 wt front, 32 back with whites all around, arms level front and bones level back. use the 30 deg. block instead of the 25 with the 0 inserts.. here are the tricks.. take the 2mm spacer out from behind the front hub and replace with 1mm spacers on each side of hub, this puts more weight over front of car and will provide more steering. run battery in middle, use a 81 spur and go to outside hole on tower in back with hub in mid position. shorten your rear camber one hole in on hub. 1 deg. neg camber front and back with 0 toe. and the 3/1 block..
this should be a good start point
rickster is offline   Reply With Quote
Old 03-30-2014, 12:19 AM   #2932
racer_guy's Avatar
kinda my thought they should both be the same...on tower it says the longer ones are for both though and the short are b5m specific but in the manual they all have the same part and the skinny nut mount
Old 03-30-2014, 07:59 AM   #2933
Vegas456's Avatar
Originally Posted by splking1 View Post
What line did you use on the rear wing to cut it down to?
I cut the wing to the second to lowest line on the wing
Team Losi Racing~Spektrum~Trackside Hobbies~Motiv RC~Gravity RC~MIP~R17~RC Scoring Pro
Vegas456 is offline   Reply With Quote
Old 03-30-2014, 08:04 AM   #2934
pumpkinfish's Avatar
Originally Posted by rickster View Post
hey pumpkinfish..
Rickster, our track has one group of triples that are "big" and the rest of the track is smaller jumps. I only used the Cactus setup as that was the only one out when I built thecar. I'll try out your setup this coming week. maybe I canmake changes and get some prctice time before race day. With all the spring sports starting and two kids time is getting short!
pumpkinfish is offline   Reply With Quote
Old 03-30-2014, 10:03 AM   #2935
hey pumpkinfish...
try the setup and see... that's just a start point.. then let me know what you want the car to do more of less of after you try it and I can help you fine tune it.
Old 03-30-2014, 10:40 AM   #2936
Default WING Replacement
New to buggies and need a new wing for my b5m. Looks like I may need a few so wondering if there are wings that hold up better than others.
Micah123 is offline   Reply With Quote
Old 03-30-2014, 10:46 AM   #2937
knucklehead459's Avatar
Trader Rating: 87 (98%+)
Send a message via Yahoo to knucklehead459
who runs shorty servos in this buggy?
Mike Salvato
www.mugenseiki.com
www.mugenracing.com
OCRC Raceway
http://upgrade-rc.com/
knucklehead459 is offline   Reply With Quote
Old 03-30-2014, 10:49 AM   #2938
lee_double2000's Avatar
Trader Rating: 45 (100%+)
the losi wing works miracles. They are the most durable and they also come pre-cut.
lee_double2000 is offline   Reply With Quote
Old 03-30-2014, 10:52 AM   #2939
Trader Rating: 31 (100%+)
Originally Posted by pumpkinfish View Post
Guys need some input on setup. I am setup with Cavalieri's Cactus setp outside of tires. I run on a high grip indoor clay track using slicks and traction compound. The traction was through the roof today. My rear was so locked I had to almost stop to make turns. The only other mid motor car (Centro) had the same issues. I moved battery all the way forward and still couldn't turn too well on the 90 degree turns or the 180. Once the track dried out some after the mains the car was feeling better but still had the push. Any ideas on what to start with?
If you want to try a quick change to see if it loosens up your rear, change the anti squat to 1deg. This may be a simple fix to your problem.
MBX6-ECO, B5m
Cspurlock is offline   Reply With Quote
Old 03-30-2014, 11:42 AM   #2940
I am, the servo lead is kinda sketchy but so far no problems.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
