    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-29-2014, 09:44 AM   #2896
Send a message via ICQ to JiuHaWong
Originally Posted by 34x17 View Post
The AE top shaft can cause your car to push. The MIP really frees up the rear end, especially in tight 180's. Exotek top shafts jump better.
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 03-29-2014, 09:49 AM   #2897
SMcD's Avatar
Trader Rating: 61 (100%+)
Originally Posted by TonyWest View Post
I wanted to try the 3 0 set up but I have the alum mounts but no inserts. I was not paying attention when I ordered them. I assumed they came with the inserts. Who has ever heard of buying a block and not being about to use it.
I don't think you will need 0 degrees of antisquat in this MM car. Try playing with your front tires, Tony. I did last Wednesday and WOW much better. I also have the RM front end just in case...
We Shall See
The Track Raceway, RCRNV, JMR
Team Jacobs Racing
YouTube: looking for turtles entertainment
B6D, X-1 2016, T4 2014 VTA, SCX-10 II
SMcD is offline   Reply With Quote
Old 03-29-2014, 09:50 AM   #2898
SMcD's Avatar
Originally Posted by DG Designs View Post
Over/under on how many don't realize you used the sarcasim font.
We Shall See
Team Jacobs Racing
Old 03-29-2014, 09:50 AM   #2899
BRSracing's Avatar
Trader Rating: 55 (100%+)
Originally Posted by davidbarton87 View Post
Check out petit RC, they have a guide with pictures
Link?
BRSracing is offline   Reply With Quote
Old 03-29-2014, 09:51 AM   #2900
ok.. you guys are joking right? these are super easy shocks to rebuild.. read the directions in your manual again and you should be fine.
I also heard if you use the wrong stickers on the body it can cause your car to jump funny.. ya that top shaft push is bad.... lol I heard if you mount a rear wing on the front of the car to increase downforce it takes the push away. lol
its like the guy at the track who uses the 4 turn mod and cant figure out why he has trouble getting around the track..lol
rickster is offline   Reply With Quote
Old 03-29-2014, 10:14 AM   #2901
Old 03-29-2014, 10:24 AM   #2902
I can see the MIP Puck System really frees up the rear end. Which will be on the list, hopefully released soon.
SPDBuggy is offline   Reply With Quote
Old 03-29-2014, 02:10 PM   #2903
Originally Posted by JiuHaWong View Post
what if you undid the bleeder screw used this to get negative pressure in the shocks wouldnt that make it easier to build shocks.
xTotalghost is offline   Reply With Quote
Old 03-29-2014, 02:36 PM   #2904
$38 to suck some bubbles out of my shocks
chancejeff is offline   Reply With Quote
Old 03-29-2014, 02:45 PM   #2905
Not sure I follow (might be a translation issue).
I use the shock pump after refilling the shocks with clean oil and after pumping the shock shaft and piston (no cap installed). It creates a vacuum which removes the bubbles at a much faster rate then if you were to fill/pump and then let sit in a shock stand. I then follow the bleeding procedure outlined in this video:
http://www.youtube.com/watch?v=-hU6B9Z62hw
I originally bought the shock pump for my Tamiya TRF sedan shocks, but it works well with any offroad shock.
I was skeptical at first, but it does work, and I look at it like shock pliers...not necessary, but nice to have.
Old 03-29-2014, 02:49 PM   #2906
Tech Legend
Wild Cherry's Avatar
Well you do save 2 minutes per rebuild...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 03-29-2014, 03:52 PM   #2907
racer_guy's Avatar
aight guys in the manual its got a couple racer tips. set screw 4670 for the caster block insert and hinge pin, and the rear hub inserts and hingepin. anybody done this? not done this? advantage or not needed? feedback plz
W.E.D. Winning Edge Designs
racer_guy is offline   Reply With Quote
Old 03-29-2014, 03:59 PM   #2908
steam's Avatar
I'm sorry what? Why would a top shaft impact anything but rotating weight?
Yokomo YZ-2, Kyosho Ultima SC-R, RT5, Airtronics M12
steam is offline   Reply With Quote
Old 03-29-2014, 04:01 PM   #2909
Vegas456's Avatar
You don't need those setscrews. Just put a dap of tire glue or any glue on the inserts that go into the hubs (front and rear) and you get rid of slop. Also saving grams of weight which you want to do wherever you can since the b5m is such a heavy car.
Team Losi Racing~Spektrum~Trackside Hobbies~Motiv RC~Gravity RC~MIP~R17~RC Scoring Pro
Vegas456 is offline   Reply With Quote
Old 03-29-2014, 04:08 PM   #2910
Trader Rating: 14 (100%+)
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Currently Active Users Viewing This Thread: 6 (1 members and 5 guests)
axoid
