    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 03-28-2014, 10:53 AM   #2851
Trader Rating: 15 (100%+)
Originally Posted by TJ Hart View Post
When I am on quarter throttle or less, it's really choppy and makes some grinding noise. My diff was broken in and it's really smooth. Does anyone know what the problem could be?
Bad sensor wire...?
flybyublue is offline   Reply With Quote
Old 03-28-2014, 10:58 AM   #2852
TJ Hart's Avatar
Originally Posted by flybyublue View Post
Bad sensor wire...?
Unfortunately, it's not the sensor wire. I tried a couple of them..
Wisconsin > Wherever you live
Steve Stricker fanboy.
Slam Dekker.
Long hair, don't care, Clay Matthews.
TJ Hart is offline   Reply With Quote
Old 03-28-2014, 11:21 AM   #2853
Just a thought maybe your gear mesh is off. Check to see if your pinion is smashed up against your spur gear
chancejeff is offline   Reply With Quote
Old 03-28-2014, 11:22 AM   #2854
TonyWest's Avatar
Trader Rating: 50 (100%+)
Default Wow I am getting desperate
Does anyone know where I can find #91385
Arm Mount Inserts. I only need the 3 3 inserts.
WALDORFRC.com
301-932-9193
Team Associated / AKA / Byrons Fuel / Futaba
TonyWest is offline   Reply With Quote
Old 03-28-2014, 11:24 AM   #2855
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
They are on eternal backorder. I got 1 set from AE the week the rear motor was released. I have the 3/0 on my mid and the 2.5/2 on my rear.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-28-2014, 11:28 AM   #2856
vito's Avatar
new set ups at rc 10 .com
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 03-28-2014, 11:30 AM   #2857
vito's Avatar
http://www.teamassociated.com/setupsheets/RC10B5M/
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
Old 03-28-2014, 11:32 AM   #2858
TJ Hart's Avatar
There is the correct amount of play in the mesh, I'm pretty stumped where the noise is coming from especially when the diff is smooth.
Slam Dekker.
Old 03-28-2014, 11:32 AM   #2859
TonyWest's Avatar
I wanted to try the 3 0 set up but I have the alum mounts but no inserts. I was not paying attention when I ordered them. I assumed they came with the inserts. Who has ever heard of buying a block and not being about to use it.
WALDORFRC.com
301-932-9193
Old 03-28-2014, 11:45 AM   #2860
tschulz3's Avatar
I built both of my b5m kits with the alum. Steering rack. The best way to do it is put the 3mm screw in from the alum so the button head is against the aluminum. This will require a longer screw. Then us a 3mm lock nut against the bearings so you don't get and bind in the bearings. No loctite needed.
Terry Schulz
Sponsors: TLR, Horizon, Spektrum, Orion, Jconcepts, Lunsford Racing, Fantom Racing, Vision Racing, Schelle Racing and MIP
Cars: 22 3.0 stock, 22 3.0 mod, 2.0, 22 T 2.0 , 22-4, 8ight-E4.0
Home Track: CGRC, Cottage Grove, Oregon
tschulz3 is offline   Reply With Quote
Old 03-28-2014, 11:53 AM   #2861
Ruffy's Avatar
I bet it is from the end of your pinion rubbing against the gear cover.
Try this... take the gear cover off, try and see if sound goes away and you have free play. If so, forget about getting a full mesh to your spur gear and mount your pinion on the motor a little bit more in, like 3/4 engagement or 1/2 engagement to your spur and then mount your cover again. Check and see once again.
Ruffy is offline   Reply With Quote
Old 03-28-2014, 12:03 PM   #2862
TJ Hart's Avatar
I will try that, thank you.
Slam Dekker.
Old 03-28-2014, 12:19 PM   #2863
Graham11's Avatar
Trader Rating: 21 (100%+)
Really? Thats BS, i was about to order the aluminum mounts too, why wouldnt they come w the inserts?
Hot Bodies Racing - Team Pro-Line - Maxy's Fuel - LRP - Trinity
Hobby Hut - Trains N Lanes - Mushroom Bowl - LCRC
Graham11 is offline   Reply With Quote
Old 03-28-2014, 12:21 PM   #2864
Hi All!
Thanks for the answers to the questions I had asked a couple of days ago! It helps greatly!
I was hoping to pick up a B5m as soon as they are back in stock, but my wife nixed that idea! She said I can't get a new car until I sell one of my unused ones. Makes sense and she's the boss (even though I manage the finances ).
If anyone knows of someone that is interested in an MBX6R or a Recoil, please point them to these threads and help me get my B5m faster!
For Sale: SportWerks 1/4 Recoil
For Sale: Used Mugen Seiki MBX6R USA edition
Thanks!
DropPass is offline   Reply With Quote
Old 03-28-2014, 12:23 PM   #2865
Trader Rating: 14 (100%+)
Because when you wear out or want to replace a $1 piece you would have to spend $20.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
gabc
