    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-26-2014, 10:38 PM   #2791
Originally Posted by SPDBuggy View Post
Yes, that is the part number for the B5 and B5M.
Awesome!! Thank you
splking1 is offline   Reply With Quote
Old 03-26-2014, 10:58 PM   #2792
rigor's Avatar
Trader Rating: 38 (100%+)
Originally Posted by JVilla View Post
hey rigor,
just wanted to say thanks. knocked off at least .5 off my times. haven't had a chance to try flat arms but laying shock down was money with those springs. appreciate it man.
* Jesse H. *
rigor is offline   Reply With Quote
Old 03-27-2014, 12:05 AM   #2793
hey rigor,
Going to try moving the rear springs in as well. Hope I can see .5 second drop as well
Old 03-27-2014, 12:10 AM   #2794
Cridd's Avatar
Trader Rating: 16 (100%+)
Originally Posted by DG Designs View Post
Another thing that helps is run the smallest spur possible. I'm running 66/33, puts the motor that much farther back.
I ended up running the motor all the way back and turned it into a B5. Joking aside I run a 75, was thinking of toying with a 69 if I ran into a traction issue.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 03-27-2014, 06:02 AM   #2795
I am looking for some help...I am trying to tune my new B5m for an indoor carpet off road track. The buggy is awesome but it has a bit of high speed push in the front that I can't get rid of. I am running the following settings:
-1 Camber all around
2 degree toe out
40 weight front / 32.5 rear oil
Mini Pin rear tires, Cut Stagger slim front
Ride height is around 16.
Any suggestions to get a bit more high speed steering?
Thanks...Scott
scraff33 is offline   Reply With Quote
Old 03-27-2014, 06:17 AM   #2796
TomErickson's Avatar
2 degree toe out
Thanks...Scott
What are you running for caster and offset in your front hubs? For high grip carpet you will want to reduce caster and move the spindle forward. The kit starts with higher caster and 4mm offset.
In addition what springs are you running. You can increase spring rate in the rear to reduce traction roll and increase steering (reduce push). I would also reduce your front oil weight.
---Thanks to my Sponsors: Novak R/C, and Nankin Hobbies ----
TomErickson is offline   Reply With Quote
Old 03-27-2014, 06:31 AM   #2797
Caster is 5 and the trailing axle insert is 3mm. I tried to drop the oil in the front down to 37.5 but it seemed to push a bit more. Also, how about the shock mount points...any suggestions?
Thanks for the help!! Scott
Old 03-27-2014, 06:37 AM   #2798
Bcholka's Avatar
Originally Posted by rigor View Post
Ball diffs for OCRC since it's med to high bite. Only need those gear diffs for super high bite I believe.
Originally Posted by Skeeter36 View Post
I dont want to offend anyone but if you cant get a RM car around the track then MM probably isnt going to help you. GEAR DIFFS, Unless your on HIGH HIGH bite astro, then i dont think its worth messing with, or its for lazy people? I run on high bite dirt/clay that MM car will wheelie down the straight and we all run ball diffs w/ no issue. we will run them for 6 months w/ no gritty feeling at all. Its all in the build and break in and final sttings. I love the B5M, great car, as good or better than anything available IMO. I have owned 22 2.0, RB6,and the B5M and I prefer the B5M for its steering characteristics. I wont bore you fellas anymore but just my thoughts!!
+1000
2-Tekno EB48.2's, 1-Tekno ET48, 1-Tekno NB48, 1-Tekno NT48, 1-Tekno SCT-410, 1-AE B5, 1-AE B5M, 1-Kyosho RT6, 1-Kyosho MP9e TKi, 1-TLR Losi Mini 8ight
Our Awesome Sponsors: Tekno RC, AKA Tires, Dialed Designs Airbrushing
Special Thanks to: Trackside Raceway, Clark R/C Park & RC Scoring Pro
Bcholka is offline   Reply With Quote
Old 03-27-2014, 07:47 AM   #2799
If you stand up the shocks more it can improve or reduce push. The stock set-up uses the center hole. You could try the outer hole to see if that helps. Most people used the inner hole on the tower and outer hole on the arm which will stiffen the response in the B4.2. I learned on high bite Astroturf that a more vertical shock on the front reduced push because the initial compression of the suspension was softer with the right spring/oil combination.
What holes are you using today?
Old 03-27-2014, 07:49 AM   #2800
I would also try the 0deg caster block insert to decrease caster.
The only other options look at camber link settings.
Old 03-27-2014, 07:54 AM   #2801
I was using the outer on the front and inner rear. I tried switching the front to the inner but I think things got worse. I am going to set the front back to the outer. What do you suggest for oil for the front? I dont have any other spring options yet since all of my old springs are for my b4.1 without the big bore shocks.
Old 03-27-2014, 09:05 AM   #2802
Trader Rating: 129 (100%+)
Can someone give me the part number for the shim to use on the rear inner hinge pin if your rear arms have excess play? Thanks.
Chris Gierse is offline   Reply With Quote
Old 03-27-2014, 11:15 AM   #2803
I used the plastic spacers that are used to center up your rear hubs. I took my body Remer tool to open the hole some. Used one and now there is zero play. I located the washer towards the rear shock tower. Hope that all makes since.
Old 03-27-2014, 11:37 AM   #2804
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
deleted
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-27-2014, 12:02 PM   #2805
Jake S's Avatar
Trader Rating: 66 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
http://www.amain.com/product_info.ph...ter-Set-TLR-22
is what i used, also takes a slight ream to slide on easy. guessing 4mm-ID shim is whats needed
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
