    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 03-25-2014, 11:46 AM   #2701
Send a message via ICQ to JiuHaWong
Originally Posted by Jason Snyder View Post
I'm looking to make a first post similar to the RB6 thread.....but keep in mind that car has been out for years........it'll take time to collect, organize and enter all the information.
Glad to hear. Some of the information is simple cut and paste. And yes, I realize this is a hobby, but it is YOUR responsibility to keep things updated or pass the mantle on to someone who will. Just sayin'.
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
Last edited by JiuHaWong; 04-26-2014 at 03:35 PM. Reason: edited to not be so mean...
JiuHaWong is offline   Reply With Quote
Old 03-25-2014, 11:48 AM   #2702
Grasschopper's Avatar
Trader Rating: 54 (100%+)
Originally Posted by predu View Post
umm ok. i tried to use the blue b4 bottom balls and the hole is too small, hence why i said you need to use b5 parts. 3mm is bigger than 4-40.
maybe i just got 8 mismade b4/sc10 lower ft balls. good thing my b5 ones were made right.
i had no problem puting b4 balls in b5 eyelets. it was the b4 balls the 3mm b5screw would not go thru them.
Originally Posted by Matt Trimmings View Post
Gotcha. Overall there is not an issue to use the older stuff if youre in a bind and cant get newer.
Ok my bad slightly. The ball OD and the width of the flats where the screw goes through are identical. I did use the B5 ball in the B4 eyelet so I'm not sure if the B4 ball works...but the eyelet DOES work.
Here is what I used...but I stuck the B5 ball in it.
www.smc-racing.net for all of your Lipo needs
RC10B5, Caster S10B Pro, 22T
Grasschopper is offline   Reply With Quote
Old 03-25-2014, 12:29 PM   #2703
Jake S's Avatar
Trader Rating: 66 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
Originally Posted by DG Designs View Post
Design looks familiar
not even close thats like saying cav copied bk's design, yeah they both have drips, but thats it.
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 03-25-2014, 12:35 PM   #2704
predu's Avatar
you are right, i read how i wrote it and i meant ball not eyelet , sorry.
SC10.2 , LRP, SCHUURSPEED 17.5
B4.2, LRP, SCHUURSPEED 17.5
TC6.1, LRP, SCHUURSPEED17.5
TC7 , LRP, SCHUURSPEED 17.5
10R5.1, H/W, SCHUURSPEED 17.5
predu is offline   Reply With Quote
Old 03-25-2014, 12:39 PM   #2705
Skinny_j's Avatar
For those that have slop in the trailing inserts, I have found that a few dabs of shoe goo before installing them takes all the slop out. Plus you can still push them out if you need to.
Skinny_j is offline   Reply With Quote
Old 03-25-2014, 01:04 PM   #2706
Great idea. Did you to that for both the inner and outer peace? Im assuming a dab on each corner correct?
splking1 is offline   Reply With Quote
Old 03-25-2014, 01:14 PM   #2707
Skinny_j's Avatar
Exactly, no slop at all!
Old 03-25-2014, 01:22 PM   #2708
Mason's Avatar
that was my thoughts or some teflon product..
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 03-25-2014, 01:42 PM   #2709
Trader Rating: 14 (100%+)
Um, ok. Hope you weren't offended, wasn't my point.
And by the way Cav's and Bk's designs are similar ( similar being the operative word) before you add color.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 03-25-2014, 02:16 PM   #2710
Mxer59's Avatar
Trader Rating: 114 (100%+)
What are some changes I can do to keep the front end from pushing coming into the corner my setup is pretty much stock
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 03-25-2014, 02:24 PM   #2711
Trader Rating: 22 (100%+)
Originally Posted by rigor View Post
Matt,
We were in similar positions of feeling with the B5m, at first anyway. Even on my 3rd day out with trying to tune it, while it had made a little progress, I still wasn't thrilled with it... couldn't push the car out of the corners hard. Was also leaning towards getting rid of it. I hung onto it and it started coming together more on the 4th time out, and especially my 5th / last time out. Small changes on setup seemed to make larger changes of stability on the track than my previous cars, from what I can recall. Once you get it decent, you realize the car has great corner speed and forward bite, IMO. Not saying there isn't more refined tuning to go, but I am so much happier with the car now. Wish it would have been a lot closer to this out of the box.
Saturday will be here soon enough... maybe give it another go this weekend with the starting point setup for OCRC I gave ya, tweak as needed, and see how you feel after you sleep on it come Sunday morning. The B5m's are still tough to find, so selling yours in nice shape for a nice price shouldn't be an issue.
Not certain if I can meet up with ya Saturday. I'll check back with you though regardless. Good luck man!
please share as i am on the same boat as matt. i have a 13.5 in my b5m and i can't even beat my b4.2 17.5 lap times. getting on power out of the corners has been the culprit, otherwise b5m is pretty good everywhere else. any help or suggestions would be appreciated.
JVilla is offline   Reply With Quote
Old 03-25-2014, 02:44 PM   #2712
Trader Rating: 20 (100%+)
I am experiencing the same issue with on power corner exit.
GTSSTANG is offline   Reply With Quote
Old 03-25-2014, 02:53 PM   #2713
rigor's Avatar
Trader Rating: 38 (100%+)
If you're having issues getting on the power exiting corners, try all 4 of the following rear end changes together:
1.6 pistons
AE 30 weight oil
AE White Springs
Inner hole shock mounting position up top on the rear tower.
After that you can toy with the inner rear camber link ballstud height. I am currently happy with 0 washers, bringing the ballstud down.
These changes along with the flat front arms/tower made me much happier with the B5m so far! To each their own style and preference of feel.
Good luck
* Jesse H. *
rigor is offline   Reply With Quote
Old 03-25-2014, 02:58 PM   #2714
Rigor, thanks for the tips. Did you change the pistons too?
I do have the white springs on order.
Old 03-25-2014, 03:15 PM   #2715
rigor's Avatar
Yes 1.6 pistons on the rear as well. Forgot to mention that. Edited my post to reflect properly.
* Jesse H. *
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
crustyfeet
