    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-24-2014, 10:37 PM   #2671
Thanks for all your help and advise
Originally Posted by tropmonky View Post
Oh yeah, HUGE difference. 50-60 grams can add up to a spring and oil weight change for sure.
If you check the last 30pages back there is a ton of info about how people have dropped weight.
splking1 is offline   Reply With Quote
Old 03-24-2014, 11:12 PM   #2672
VenturaDC's Avatar
Trader Rating: 32 (100%+)
Originally Posted by splking1 View Post
What run times you getting out of that battery?
I put back about 1200mah after a 7min main with no real noticeable drop in punch, I've never run it to the cutoff but have ran some decently long practice sessions with it.
Dustin Colt45 Aguirre
Kyosho RB6--Futaba--HW--Shuurspeed 17.5
Kyosho SCR--Hitec--Lrp--Yeah 13.5
Durango Dex210--Futaba--Trakpower--Tacon 8.5
VenturaDC is offline   Reply With Quote
Old 03-25-2014, 12:29 AM   #2673
thecman26's Avatar
Trader Rating: 99 (100%+)
Originally Posted by Jake S View Post
http://www.amain.com/product_info.ph...ts-74V-3200mAh
yeah 50g lighter then most shorties too
In fact they used to carry an even smaller one!
A 3000mAh, I have one and its almost like running without a battery!
Wonder why they stopped selling that one?
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 03-25-2014, 04:49 AM   #2674
triplesix's Avatar
So I finally got my B5m yesterday. The build was great so far, good fitment of the parts, no missing or defective parts - obviously the guy at QC had'n fallen asleep when my kit was produced My rear arms needed a washer to remove some slop (~ 2mm) on the inner hinge pins, at least the slop was equal left and right.
One question so far:
I'm quite familiar with all these geometry adjustments like caster, camber, anti-squat, etc.
but what's the difference between running 25 kick-up with 5 caster block inserts versus 30 kick-up und 0 inserts? Both cases result in a total 30 caster but does it drive differently?
MBX6R
B5M Lowrider
DEX410
Supastox GT
triplesix is offline   Reply With Quote
Old 03-25-2014, 05:04 AM   #2675
Ruffy's Avatar
All of the kits, including mine, seem to have this large amount of play in the rear arms. I heard that AE are going to address it, most likely by including spacers for the inner hinge pin. This is only my assumption.
The front will also develop a lot of play in the front axle plastic bearing holders ( the ones listed for 2mm, 3mm, or 4mm trailing axle) as the plastic itself seems to move around in the steering spindle. I think in time we will see them address this as well, but just wanted to let you know this is normal so far in the kits.
ALSO! The rear ball stud, that threads into the rear wheel hubs, by going through the plastic part and then threading into the blue aluminum rectangle... make sure to clean this ballstud and the blue rectangle with like motor spray to remove any lite oils it may have and then thread using a thread adhesive like Loctite 242 (blue loctite thread adhesive compound) to prevent the ball stud from backing out during a run and your loss of the small blue rectangle.
Ruffy is offline   Reply With Quote
Old 03-25-2014, 05:33 AM   #2676
celt's Avatar
A 10mm ballstud with an aluminum locknut eliminates any chance of failure permanently.
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 03-25-2014, 05:38 AM   #2677
+1. I did this during the initial build. No issues with the ballstud coming out.
xb2, xb4, RC10 re-release WC, sc5m, vintage rc10's
Eaglesrx is offline   Reply With Quote
Old 03-25-2014, 05:50 AM   #2678
Mason's Avatar
Either way, CHECK YO BALLS MAN!
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 03-25-2014, 05:52 AM   #2679
Mxer59's Avatar
Trader Rating: 114 (100%+)
What kind of temps are ppl seeing? In 17.5 my car seems to run a little hotter over my Kyosho trying to figure out if it's a weight issue or gearing
5ive T (Bartoline 28.5cc, Bartoline Pipe, Team Chase)
Futaba 4pls
Team Chase 2015
Rd. 2 TQ-1st--Rd. 3 3rd
Mxer59 is offline   Reply With Quote
Old 03-25-2014, 05:56 AM   #2680
Ruffy's Avatar
Our LHS hasn't had any ballstuds to buy yet, so yeah if you can find them buy them longer, add also a metal 1mm washer to the front side to protect the plastic part as well, then a locknut to the backside as mentioned...if you can find longer ballstuds to buy!
I've been looking for ballstuds and waiting for them from my LHS as some of my ballstuds (4 of them) have stripped out the hex on the top in less than 3 or 4 times removing them to make adjustments. They seem to be made of a "soft" alloy, or at least the secondary operation to make the hex may have left them soft in this area.
Old 03-25-2014, 06:00 AM   #2681
Mason's Avatar
could be weight, could be airflow, could just be you on the throttle more being faster?
Mason McCombs
Old 03-25-2014, 06:02 AM   #2682
Mason's Avatar
Ruffy, are you using power tools? I've had no issues with any screw heads yet *knock on wood*. Though I haven't fired up the power screwdriver yet.. fingers are worn out with these threads!
Mason McCombs
Old 03-25-2014, 06:03 AM   #2683
celt's Avatar
I don't think the Kyosho is considered light either. I had an RB6 - it wasn't any lighter than the B5M.
Stan Garvin
Old 03-25-2014, 06:13 AM   #2684
Mxer59's Avatar
That's my issue are track kind of tighter, I'm geared 72/32 and it's getting hot I'm not sure if it's the motor. Yea I tend to have a heavy trigger finger in stock I just know in mm I'm able to really get on it sooner
Futaba 4pls
Team Chase 2015
Old 03-25-2014, 06:38 AM   #2685
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
you can use the TLR ones also.....
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
