Team Associated RC10 B5m Mid-Motor & Rear Motor Thread
#241
The rear motor thread is filled with:
"Why doesn't if have any aluminum?"
"Why are the shock caps plastic?"
"Why are the shock shafts uncoated?"
"Why aren't the hexes aluminum?"
"Why can't I run my full-size stick pack?"
"When is the Factory Team edition going to be released?"
Don't believe me? Go see for yourself.
#243
Does anyone know why AE went with a 14 ball diff vs the standard 12 ball? TLR 22 owners had initial issues with 14 ball diffs. Rick? Patiofurniture?
#245
Didn't get a chance to comment on the most impressively significant improvement that I have been waiting on… The steering system.
Now THIS is how steering should be done!
http://www.liverc.com/pictures/news/...llcrank_lg.jpg
Provided the bearings are precision fit and firmly captured, along with precision fit on the cups, slop will be a thing of the past and this steering system will be the best in the industry.
#246
But yeah, who uses servo savers in 2wd these days
#247
Many systems are excellent but most have some sort of weakness. This one, if executed perfectly may not have a weakness. On top of that, it looks rather heavy duty and robust and I don't expect anything but excellence in this department.
#248
That's what I thought! Although I love the Yokomo B-Max2MR (give it a try and you will understand), I really like the look of the Yaiba and Avid parts on my SC10.
#251
Extra diff balls improve the grip for the diff to handle the power modern motor's have.
#252
I would assume the TLR 14 ball system suffered from poorer quality metals. Essentially, the more balls you have, the less pressure per ball which "should" improve longevity of diffs. Associated diffs are butter as is and I would assume this change will make them just that much better.
#253
Probably because not as many people desire or need a MM vehicle. It's funny though, more and more tracks are now trying to get the traction up as high as possible so people can and will run MM. MM seems to be the fashionable thing to do as of late, kinda doesn't make sense to me.
#255
The hub itself & the bottom of the tower I have no worries about at all. I agree a plastic hub can be as good or better that an Al one. My concern is the thin plastic that surrounds the blue Al pill that the camber link attaches to. If the thin plastic around the pill even cracks the camber link will be out of kilter. I am worried a good power slide into a wall on the edge of a fast sweeper will break that plastic only, not the rest of the hub. I like the concept, I'm just leery of the execution. Then again, I broke 2 Avid CF rear towers, maybe it won't be an issue for most folks.
