    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-19-2014, 06:39 PM   #2431
Trader Rating: 33 (100%+)
Originally Posted by Kave View Post
Exclusively short packs in 17.5.
Why not squares? Weight distribution?
dnuggett is offline   Reply With Quote
Old 03-19-2014, 06:41 PM   #2432
Trader Rating: 8 (90%+)
Originally Posted by DKSPLIT96 View Post
Has anyone tried or know anyone that has used the PSM carbon fiber shock towers?
http://www.psm-rc.com/products/team-associated-b5m/
Hmmm... if the front shock towers arent interchangeable like Rigor has mentioned then these carcon bling ones wont work for 1 of the cars.
juicy74 is offline   Reply With Quote
Old 03-19-2014, 06:42 PM   #2433
Originally Posted by roundguy View Post
What about using the B5 rear arms on the B5M? Are the heights ok with the M tower? The rear shock towers aren't interchangeable....
I heard the rears have different spacing and would not work interchangeable
Hyperhobbies.ca
Rcbatterydepot.com
lee111m is offline   Reply With Quote
Old 03-19-2014, 06:54 PM   #2434
Mason's Avatar
anyone with virgin ball cups please check the inner diameter.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 03-19-2014, 07:02 PM   #2435
If ur asking if they stretch yes they do, I just undo the screw instead of the cup
xTotalghost is offline   Reply With Quote
Old 03-19-2014, 07:13 PM   #2436
AE-Reedy
The rear arms are not exactly the same but can be run on either car.
The dog-bone sweep changes slightly. Shock mounting is the same on both.
Sean Cochran is offline   Reply With Quote
Old 03-19-2014, 07:58 PM   #2437
DKSPLIT96's Avatar
The b5 front tower works on the b5m, you just need to match it with the correct arms, either gull or flat. I'm currently running the flat arms and tower that I traded a guy for at my track and he took them off his b5. I'm just curious from a quality and function standpoint if anyone has tried the carbon fiber towers or heard from anyone who has.
Grant Beckwith
Associated, Reedy, Orion, Futaba
DKSPLIT96 is offline   Reply With Quote
Old 03-19-2014, 08:09 PM   #2438
mugenhatchie's Avatar
Mainly weight. Compared the the other chassis its a chubby car.
mugenhatchie is offline   Reply With Quote
Old 03-19-2014, 08:39 PM   #2439
BillPear's Avatar
Send a message via Yahoo to BillPear
Originally Posted by Skeeter36 View Post
Does anyone have a pic of the b5m with an orion R10 pro mounted in it. Im just curious cause mine looks like a rats nest, LOL
Originally Posted by Wildcat1971 View Post
Those are all nice esc's. And i have v2.1 esc that I plan to try in my B5RM. But the esc has a 4 bank of 330uf caps, and it might be hard for me to get that in the chassis. If it becomes an issues, I will just use my viper. Might use my viper anyway, because it is a very nice esc. But the viper is in my reference stock buggy, I and I prefer to not remove it. I plan to run both cars in stock and sell the loser of the shoot out
I told you guys earlier I'd post some photos but now that the Orion is specifically asked for here you go. I think this weekend I'm going to break it down some and run the sensor wire under the battery, and break off the plastic case from the caps and just shrink wrap them for a little more room and 1/2 a gram less.
Wildcat doesn't the HW 3.1 come with the 2 caps similar to the Orion, that you can use?
BillPear is offline   Reply With Quote
Old 03-19-2014, 08:55 PM   #2440
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
Nice Gulf scheme! Did you paint the logo, or is it a decal? Ive been trying to find gulf decals forever! haha
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 03-19-2014, 08:59 PM   #2441
BillPear's Avatar
Thanks! I'm getting a lot of those complements. They are very nice decals from Carl in the VTA thread here, drop him an email he's ready to print them.
USVTA/Trans Am Decals
Old 03-19-2014, 09:24 PM   #2442
Trader Rating: 29 (100%+)
Bill Pear, what changes have you made specifically to run @ OCRC. It is a very similar track to mine. I am just curious as I cant stand a car that pushes.
Skeeter36 is offline   Reply With Quote
Old 03-19-2014, 09:25 PM   #2443
rigor's Avatar
Trader Rating: 38 (100%+)
I've been doing the same... Unscrewing the ballstud instead of popping the cup for diff adjustment. Careful though, that rear shock tower piece that the stud mounts to, can / will weaken over time. Not certain I'd constantly want to be doing the same thing with the FT aluminum upgrade version either.
Which brings me to my new discovery (to me anyway). AE is being strategic with their parts packaging. You can only replace that rear shock tower mount by purchasing an entire rear tower replacement, which is like $6 to $7 instead of $2 for that piece. Also, I didn't learn about using an oversized washer behind the rear hub ballstud until after I had discovered one of my rear hub link plastic inserts had imploded (busy evening practice with 8-scale and some crazy drivers, took a few collisions). Guess what? Should be like a $2 replacement pack of 4 (each side & hub type). No. Can only aquire the piece with a complete rear hub replacement, which is like $8 to $9. Lesson learned. Thankfully I found the HARD rear hubs in stock.
* Jesse H. *
rigor is offline   Reply With Quote
Old 03-19-2014, 09:39 PM   #2444
rigor's Avatar
I'd be shocked if your B5m pushes. Most are trying to mellow / smooth the steering out for more consistency.
I just filled out my setup sheet for OCRC today. If anyone wants it just PM me with your email address to send to. It's certainly a good starting point.
* Jesse H. *
Old 03-19-2014, 09:42 PM   #2445
rigor's Avatar
I never said the towers aren't interchangable; in fact my post reflected that you absolutely need the correct matching arms along with the tower, or the shocks do not function properly. Just wanted to clarify.
* Jesse H. *
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
