    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree17Likes
Old 01-05-2014, 10:18 AM   #226
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Originally Posted by lbckevin View Post
I was with Bill at OCRC raceway and the new buggy is really sweet. There is only one buggy right now and the engineer was testing it. It was running the same lap times as the current fast Centro's ( Hartson, Theilke, Barry Baker, Drew Moller, Kevin Motter) . Lots of new features that were not mentioned yet. No pictures were allowed, but definitely made me go and pre order it last night.
So who is the engineer...? Coach...???
Man Florida sucks I want to move to Cali
A battery pack a day keeps the stress away
RED-LINE M03 is offline   Reply With Quote
Old 01-05-2014, 10:24 AM   #227
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Coach? Didnt he leave AE a long time ago? I heard he was going to start his own rc company.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-05-2014, 11:38 AM   #228
I thought DrewMo ran for kyosho.
(Team Rifles) USS Chung Hoon DDG-93
Paul Pierce is not a hall of famer, not even close.
Sierrahotel is offline   Reply With Quote
Old 01-05-2014, 01:04 PM   #229
BillPear's Avatar
Send a message via Yahoo to BillPear
Originally Posted by JW91 View Post
I wonder if the factory guys will have them for the Reedy?
We were told no that it wont be raced.
BillPear is offline   Reply With Quote
Old 01-05-2014, 01:07 PM   #230
I know the guys in CO are hoping one makes it to the Rumble in the Rockies in early Feb. An AE engineer is a CO native.
XFactory X6^3, XFactory SCX-60CF, Durango DEX410v3
All Kyosho damped with Viper Power and SMC Juice
Serpent SRX-2MM, Serpent 811E
VBC Firebolt DM
Barge is offline   Reply With Quote
Old 01-05-2014, 02:26 PM   #231
Yeah maybe it's an Area 51 cover up
Old 01-05-2014, 03:20 PM   #232
lbckevin's Avatar
Trader Rating: 91 (99%+)
Engineer is Kody Numedahl
Drew Moller just signed with A main hobbies. He ran a centro for 2wd and an Xray for 4wd
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 01-05-2014, 03:35 PM   #233
Lance Tanner's Avatar
Thought this was the likely 'culprit', he's been kind enough to weigh in on the threads a few times to give some great insight..... and the dude is faaaast Good on him and good for you guys to be the first of the few to lay eyes on the gold at the end of the rainbow.
Lance Tanner is offline   Reply With Quote
Old 01-05-2014, 04:42 PM   #234
Thanks for the info....!!!
Old 01-05-2014, 04:49 PM   #235
Was he testing the RM or MM? I would have thought the RM was done by now. If not, then that car will be a ways off. Unless he is just looking for a good base setup for the manual.
Old 01-05-2014, 05:30 PM   #236
lbckevin's Avatar
Kody and Brent were testing the MM
Kevin Smith
Old 01-05-2014, 05:38 PM   #237
ah, ok. That makes more sense since that car is slated for a later release. I kinda figured that since this was the MM thread, but you never know...
Old 01-05-2014, 08:04 PM   #238
is the rear offset the same as the B4.2? if it is, thats the only upgrade Ill make is the aluminum hexes, always had better luck with those on the rear.
CaseyD is offline   Reply With Quote
Old 01-05-2014, 09:03 PM   #239
Jmuck69's Avatar
Trader Rating: 14 (100%+)
The rims for the B5 are the same as the B4.2 but the axle diameter and hex thickness might be either thicker or thinner depending on rear A arm length. The existing hexes will probably not work.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 01-06-2014, 07:18 AM   #240
Originally Posted by FantomLeopard View Post
I would imagine that plenty of companies tried out a motor orientation to use a 3-gear transmission instead of 4 and found that the 4 gear box was better. Why? I have no idea.. It might even be because it pushes the motor forward just a tad bit more than 3 gears would.
I'm in the same boat though, no B5 for me until bugs have been worked out. I can't afford getting new 'needed' upgrades and not to mention new batteries that will fit
From my understanding you have to run a second idler so the car go will go forward. It is the same tooth as the first idler so the ratio doesnt change. Isnt that how real cars work? When you shift to reverse another gear kicks into main gear and everything goes backwards. Thats an oversimplification but it makes the point.
I can remember once breaking a hub in my 25+ years of racing and that was my fault. Aluminum and Carbon are bling, nice, but not needed.
A shorty battery will work and you have the convienience of moving it around for wieght bias.
I will be the first to admit waiting for the FT would be a good thing but cant see why after seeing what this team kit has. Punisher turnbuckles and im on my way.
See you when the FT comes out LOL!
Bubonic-X is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
