    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-17-2014, 02:58 PM   #2296
rigor's Avatar
Trader Rating: 38 (100%+)
Originally Posted by TheBlueKnight View Post
Doh! The track was getting a bit dry and dusty so my B5m's rear end was starting to kickout a bit coming out of the turns. I needed more grip in the rear so someone told me to remove the spacers from under the rear inner ballstuds. If I want more grip in the rear going through and exiting out of turns do I want to remove the spacers under the rear inner ball studs or put spacers in there?
I can tell you that to get my rear end more under control, I removed the washers from the rear inner camber link stud, and pushed my rear hubs forward. I also went to rear 30 oil, 1.6 pistons, and went to the outside hole for lower rear shock mounting. Definitely helped. I might go down to 27.5 oil in the back and/or an even softer spring (AE black) and see how it feels tomorrow.
* Jesse H. *
rigor is offline   Reply With Quote
Old 03-17-2014, 03:04 PM   #2297
seth556's Avatar
Trader Rating: 42 (100%+)
Look, it costs another $40 to buy all the other front end combinations you can possibly get. Hard arms, flat arms, hard tower, short tower. Not a bad deal.
seth556 is offline   Reply With Quote
Old 03-17-2014, 03:19 PM   #2298
rigor's Avatar
I'm not disagreeing... Just seems AE fitted each car with not the optimal front arms in the box for us. Oh well. Gotta pay to play!
* Jesse H. *
Old 03-17-2014, 03:21 PM   #2299
Potoczak's Avatar
Trader Rating: 112 (100%+)
Has anyone been running the hard parts on their cars?? Does it feel any different ?
Pete Potoczak
Home entertainment specialist
Secure Technologies/ www.stiworldwide.com
Potoczak is offline   Reply With Quote
Old 03-17-2014, 03:27 PM   #2300
TheBlueKnight's Avatar
Trader Rating: 19 (100%+)
That's exactly what I did to, like to the "t". I'm confused now though because Wild Cherry said in the search for more steering to remove the rear inner ballstud shims. But I thought that was supposed to give the rear more grip, not give the front more grip/steering? I may be reading it wrong though.
And I'm on the same page with you about the arms to. All the guys at my track with RM say they are pushing and want the gullwing arms, and the mid motor guys say their cars are feeling twitchy and they want the straight arms.
Traxxas Summit and 3.3 Revo
TheBlueKnight is offline   Reply With Quote
Old 03-17-2014, 03:32 PM   #2301
DKSPLIT96's Avatar
im running the flat hard arms and tower in front and standards in back and im liking it but i dont have a comparison for the standard flat fronts as i traded front ends with a guy from my track who has the b5 and wanted the gull wing arms.
Grant Beckwith
Associated, Reedy, Orion, Futaba
DKSPLIT96 is offline   Reply With Quote
Old 03-17-2014, 03:40 PM   #2302
Trader Rating: 75 (100%+)
Adding ball stud washers under the rear inner camber link (raising the ball stud) is like lengthening the camber link. It's less of a change compared to actually lengthening the camber link by moving the ball stud position. Lengthening the camber link adds side bite, meaning traction "in to" the turn. This allows you to pitch the car in to a turn and it will help to prevent the car from spinning on entry.
Removing ball stud washers under the rear inner camber link (lowering the camber link) is like shortening the camber link. Shortening the camber link adds forward bite, meaning traction "out of " the turn. The car's rear end will square up better on throttle while exiting he turn.
The change does not add or remove rear traction through the entire turn. Like any other change, its a give and take proposition. What you gain in one part of the turn, you're going to lose in the other.
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 03-17-2014, 04:03 PM   #2303
Now I get it. Perfect, thanks for the clarification. I think I need to put the washers back then. When the track started to dry out and I would come hot into turns the rear end was coming around on entry. Exiting the corner was fine though.
Old 03-17-2014, 04:19 PM   #2304
Jake S's Avatar
Trader Rating: 66 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
http://www.petitrc.com/reglages/Basi...ing/index.html
one of my favorite tuning pages... thanks mark pavidis
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 03-17-2014, 04:21 PM   #2305
Jake S's Avatar
Originally Posted by b5m_manual
Changing the length of the camber link is considered a bigger step than adjusting
the ball end height on the rear chassis brace. Shortening the camber link
(or lowering the ball end) will give the rear end less roll and the car will tend to
accelerate or “square up” better. Lengthening the camber link (or raising the ball
end) will give the rear more roll and more cornering grip
and then right from the associated b5m manual.
Old 03-17-2014, 04:35 PM   #2306
Nice, I gotta pull my manual out and do some reading!
Old 03-17-2014, 04:48 PM   #2307
proraptor's Avatar
Please keep me updated. Im gonna try a couple of the things you listed. Already moved the hubs forwards and that helped a little.
B5M, Tekin RS pro with Tekin redline gen 2 8.5, Savox 1258TG
savage flux 2350, 7950th
Airtronics Mt4
proraptor is offline   Reply With Quote
Old 03-17-2014, 05:20 PM   #2308
markt311's Avatar
Trader Rating: 32 (100%+)
Maybe try a stiffer spring to see what it does, I'm running grey front white rear. I think the rear needs the support so the suspension doesn't roll over too much, seen as hooking. I race at a really tight track with lots of 180's though, so I need the car very reactive.
PR Racing Bellgate Distributors
Caster Racing Parts
311 RC Graphics
markt311 is offline   Reply With Quote
Old 03-17-2014, 06:53 PM   #2309
rigor's Avatar
Sharp turns / 180's is where I was having the most issue. I got my hands on front flat arms today. Hoping OCRC still has the front tower tomorrow when I go back to run and tune most of the day.
EDIT: Wait... Is it the same front shock tower for both the B5R and B5M ?? I heard a different tower was needed for each front arm type ?? I can't go wrench for another few hours to find out the answer :P
* Jesse H. *
Old 03-17-2014, 07:00 PM   #2310
rigor's Avatar
What oils & pistons you running ? Thanks
* Jesse H. *
