    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 03-14-2014, 01:53 PM   #2161
slakr's Avatar
Trader Rating: 28 (100%+)
Originally Posted by Tradin Paint View Post
Has anyone tried the aluminum shock mounts. Not sure what I'm doing wrong but there is a ton of slop between the shock mount and the hole in the shock cap
Yes, with the same results. Their either has to be an insert for use with the plastic shock caps or they must only be for use with the aluminum shock caps.
TLR 22 4.0, 22-4 2.0, 8IGHT & 8IGHT-E 4.0~XRAY XB2C~AE TC7.1
Tim aka "slakr" ROAR No. 3-119960
slakr is offline   Reply With Quote
Old 03-14-2014, 02:07 PM   #2162
hi.. you need to use the shock bushing that goes with the alloy shock mount parts..
rickster is offline   Reply With Quote
Old 03-14-2014, 02:08 PM   #2163
Tradin Paint's Avatar
Please clarify. What bushing is that?
Happy with: Team Associated, Team Tekin, Airtronics, Avid, JConcepts, Fantom motors and Aero Model batteries.
Proud Supporter of Warehouse 3 RC Hobby Shop, that just happens to have an indoor track
"Because Size Does Matter"
Ryan H.
Tradin Paint is offline   Reply With Quote
Old 03-14-2014, 02:12 PM   #2164
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Is this the part for the alloy shock mounts you need?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-14-2014, 02:13 PM   #2165
That part above is the only thing listed on AE's parts page that even looks like it might work.
Old 03-14-2014, 02:15 PM   #2166
are u guys using the plastice spacer with them? http://www.amain.com/product_info.ph...Bushing-Ball-4
xTotalghost is offline   Reply With Quote
Old 03-14-2014, 02:27 PM   #2167
Default shock slop issues
You can always use a piece of rubber/vinyl fuel hose till u find or order the right part. I mean if u need something temporally it's better than nothing
Justinb86 is offline   Reply With Quote
Old 03-14-2014, 02:30 PM   #2168
Send a message via ICQ to JiuHaWong
Would the Avid/Schelle shock bushings work?
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 03-14-2014, 02:42 PM   #2169
Yep, that's what I'm missing. Thanks guys
Ryan H.
Old 03-14-2014, 03:06 PM   #2170
The avid ones are to small of a diameter to fit.
Old 03-14-2014, 03:17 PM   #2171
F18engineguy's Avatar
Trader Rating: 216 (100%+)
Off topic, but are these the same company? I thought coach left Avid to do his own thing yet his stuff looks just like avid.
VA Beach
F18engineguy is offline   Reply With Quote
Old 03-14-2014, 03:56 PM   #2172
He took his designs with him
Old 03-14-2014, 04:20 PM   #2173
yes those are the bushings you need... once on they fit really good.
Old 03-14-2014, 04:28 PM   #2174
http://www.redrc.net/2014/03/rudebit...battery-brace/
Old 03-14-2014, 04:54 PM   #2175
TheBlueKnight's Avatar
Trader Rating: 19 (100%+)
Just got back from 2 hours of practice at the track. Car is dialed perfectly, I love this thing! Perfect balance between under and oversteer. Flies in the air perfect, nose pitches down just a hair so you land perfectly flat on the jumps.
Started with Kody Numedhal's set up, then went 30w in the rear shocks, took out the spacers from the rear inside ball studs and moved the rear hubs all the way forward. Battery is all the way back and I put a 1/2 oz of weight on the servo to give it a hair more steering.
Traxxas Summit and 3.3 Revo
TheBlueKnight is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Dmkiefer
