    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-13-2014, 07:12 AM   #2086
D.Martijn's Avatar
Originally Posted by Mason View Post
where will you be racing the most?
Probably my local dirt track, and some races on the astro tracks
D.Martijn is offline   Reply With Quote
Old 03-13-2014, 07:36 AM   #2087
Originally Posted by Wildcat1971 View Post
I saw a MM B5 running at out outdoor track last night. It was not very impressive. lacked rear bite. The car might end up being good down the road, but more often than not, we lack the traction for MM. IMO, if your uncertain, go RM.
Really why where centroid working at the worlds, that was an out door sugared track?
xTotalghost is offline   Reply With Quote
Old 03-13-2014, 07:36 AM   #2088
Holeshot114's Avatar
Originally Posted by predu View Post
Raced my b5m there tonight. It was horrible,could not keep rear tires under it.
Traction is always a problem at our track
Holeshot114 is offline   Reply With Quote
Old 03-13-2014, 07:37 AM   #2089
D.Martijn's Avatar
My local track isn't sugared, and probably most outdoor tracks aren't
Old 03-13-2014, 07:39 AM   #2090
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
If you read his post he states that his track lacks the traction for mid motor. Just because he races outside doesn't mean he runs on manicured sugar coated high traction tracks.....
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-13-2014, 07:44 AM   #2091
predu's Avatar
Someone i think CAIN asked about running this car on a looser indoor track. I did it last night and it was horrible. our track is usually low/meduim depending on water and sweeping but usually race time it's pretty good. I took a few weeks off and went back last night to race with my sc10.2, b4.2, and b5m all are 17.5 . The track was way looser than normal like dusty concrete. The b5m was spinning out on power and backing itself into turns, i changed springs,oil,battery placement,and tires. It got a little better but still barely drivable.At one point right after a sweep and water it was alright but you still could not drive very hard at all.It was between tip toeing and driving really easy at best, if your track is medium and up it's a great car, anything less you will just be fighting it. For comparison both 17.5 my sc10.2 did 19.925 fast 17/6:09 right before water break and b5m did 19.811 17/6:03 just after water break
SC10.2 , LRP, SCHUURSPEED 17.5
B4.2, LRP, SCHUURSPEED 17.5
TC6.1, LRP, SCHUURSPEED17.5
TC7 , LRP, SCHUURSPEED 17.5
10R5.1, H/W, SCHUURSPEED 17.5
predu is offline   Reply With Quote
Old 03-13-2014, 07:46 AM   #2092
predu's Avatar
i normally have no issue with traction, last night was something else my short course times were a second a lap off
Old 03-13-2014, 07:46 AM   #2093
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
I tried MM at my local track. Somethings were good, some bad. My overall times between mm and rm were about the same, but the MM was a lot of work to drive. This was not a B5M, so I am looking forward to seeing how it will work out. The B5M might become a decent outdoor car, but it will take some time to develop those setups. Where as RM is pretty much a drop and go. The local B5RM cars are pretty much running kit setups.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-13-2014, 07:49 AM   #2094
Tech Legend
Wild Cherry's Avatar
Originally Posted by D.Martijn View Post
Anyone??
C-on !
Thats easy, get the one with the most traction cause there very little grip on moonscape layouts with dust bowls blowing in the wind.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 03-13-2014, 08:08 AM   #2095
Has anyone found a good setup for the b5m and what tires to use at IERC raceway? I plan to race there friday and I have never been there before.
chancejeff is offline   Reply With Quote
Old 03-13-2014, 08:33 AM   #2096
rigor's Avatar
Trader Rating: 37 (100%+)
Originally Posted by PHIL700XCSP View Post
Mine was doing the same thing. We have a hairpin at the end of our straightaway. I moved the rear hubs forward and it removed the hooking all together. Running the base setup besides that change and the car is leaps and bounds better, hope this helps.
Thanks. I forgot to include in my posting, moving the rear hubs forward was another thing I tried. It helped a little. I'm going to try a lot of things next time I'm at the track to see about locking in the rear more. However, after over hearing the discussion yesterday between my engineering buddy and Bob Stellflue, as well as some conversation with another AE team driver, my consensus is that the rear motor B5 is more dialed in than the B5m right now. So I don't feel like my rear end issue is isolated at all. No doubt both cars will improve over time.
* Jesse H. *
rigor is offline   Reply With Quote
Old 03-13-2014, 08:46 AM   #2097
Trader Rating: 28 (100%+)
Start w/Kody's setup from OCRC. I made some changes from there, and my car is wicked good.
Tires; Pink BK bars are great there, but people are having great results from the AKA Typo's as well.
FlyByWire is offline   Reply With Quote
Old 03-13-2014, 09:28 AM   #2098
Just an idea... but maybe you need to tone down the front end more instead of locking in the rear.
XFactory X6^3, XFactory SCX-60CF, Durango DEX410v3
All Kyosho damped with Viper Power and SMC Juice
Serpent SRX-2MM, Serpent 811E
VBC Firebolt DM
Barge is offline   Reply With Quote
Old 03-13-2014, 10:12 AM   #2099
What inserts for the AKA Typos? I was thinking Ions up front
Old 03-13-2014, 10:35 AM   #2100
rigor's Avatar
Will be trying some tuning tomorrow hopefully at OCRC.
* Jesse H. *
