    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree10Likes
Old 12-13-2016, 08:29 AM   #20911
DennisNyholm's Avatar
Also, if you aren't using any tire sauce, it will make a huge difference. Brand new tires are slippery and no sauce will make it even worse.
DennisNyholm is offline   Reply With Quote
Old 12-13-2016, 09:30 AM   #20912
Yes. I was running new tires, No prep, No tire sauce. I'll have to pick some up.
bongoray is offline   Reply With Quote
Old 12-14-2016, 05:59 PM   #20913
Just got a b5m lite to toy with the 1/10 class, plus there is a carpet track within 5 miles of my place. Just want to do stock class, but unsure what are some decent motor options that work well with a HW justock esc? Not looking to break the bank, just looking to have something that I'm gonna get floored on the straight either.
Calde315 is offline   Reply With Quote
Old 12-14-2016, 06:22 PM   #20914
jabroni racing's Avatar
Trader Rating: 37 (100%+)
Send a message via Yahoo to jabroni racing
Love this motor, VERY happy with it
https://www.amainhobbies.com/ecopowe...p-8000/p360110
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 12-14-2016, 07:50 PM   #20915
Trader Rating: 29 (100%+)
Oh stock racing.....
DustinEich is offline   Reply With Quote
Old 12-16-2016, 06:36 PM   #20916
what size motors are most of you running for high bite clay / carpet? 25ish second lap times?
Currently running a 9.5T Fantom. Wondering if I would be better suited to run a 6.5, 7.5, or 8t even...
tylem28 is offline   Reply With Quote
Old 12-17-2016, 11:21 AM   #20917
larsif's Avatar
I just put in and raced my B5M lite with the 3 gear AC RC Gear laydown transmission via Shapeways. Holy Cow! I can now carry so much speed in the corners - our track has a big fast sweeper. I picked up two laps per 6 minute run. The car felt very smooth and easy to drive. I was able to TQ both heats and win the main at our Weds night club race. The car also felt like it had a lot of punch. I run 13.5 with boost. Glad I spent the $60 to make my B5M a contender again. I was running slower than the 22 3.0 and B6Ds with laydowns. Now I do not see the need to buy the B6D as I have a lot of money already in my B5M and it is competitive.
larsif is offline   Reply With Quote
Old 12-18-2016, 03:09 AM   #20918
Pittster's Avatar
Just picked up a B5M CE for my 7 yo old for Xmas, bloody good things especially when they can be had so cheap 2nd hand, also the Jcon S2 body really set's it off. Electronics layout isnt as roomy as the B6D.
Team Associated B6D, Speed Passion Reventon Pro 1.0, Hobbywing V10 7.5t
Team Associated B64D, Speed Passion Reventon Pro 1.1, Hobbywing V10 G2 6.5t
Team Associated B5M CE, Tekin Rs Gen2, Fleta ZX 17.5t
Pittster is offline   Reply With Quote
Old 12-18-2016, 04:51 AM   #20919
a lot of people cut out the cross brace behind your receiver/esc..gives a little extra space
Old 12-18-2016, 02:32 PM   #20920
Greenbandit's Avatar
I just got a lot of B5m parts and there is an Exotek aluminum top shaft. I see that is a larger diameter than the FL and MIP top shafts. I have bearings that will fit, but my question is how does it stay centered in the gear box? It seems like it needs a spacer between the gear and bearing. The FL and MIP have a stop built in. Photo: Top MIP, Factory Lite, and then Exotek.
Todd Daly
Greenbandit is offline   Reply With Quote
Old 12-21-2016, 12:10 AM   #20921
czrlaker's Avatar
Trader Rating: 24 (100%+)
Where did you get the template? I have a shapeway laydown tranny but have been reluctant to install because I don't have a template. Do you have an electronic version of it by any chance?
czrlaker is offline   Reply With Quote
Old 12-21-2016, 07:05 AM   #20922
Trader Rating: 23 (100%+)
Looks like you are missing the sleeve that slides on the shaft to space it correctly.
I have one on my bench, I can take a picture of it, later tonight, if needed.
sstretch is offline   Reply With Quote
Old 12-21-2016, 08:12 AM   #20923
Mason's Avatar
asc 91426 top shaft spacer.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 12-21-2016, 04:10 PM   #20924
larsif's Avatar
I put a piece of white paper over the bottom of the transmission case with the two halves bolted together. I then rubbed a pencil over the paper placed on the bottom mounting holes of the case. I cut out this template and then lined it up on the bottom of my chassis. I used a hole punch to mark the center of the holes that needed to be drilled in the chassis. I started with a drill smaller than 1/8" and then finished with a 1/8" drill bit. I then used a countersunk drill bit to slowly remove material to have the mounting bolt sit flush with the chassis. Measure and measure again before drilling.
Old 12-21-2016, 04:11 PM   #20925
czrlaker's Avatar
Thanks, I'll give it a try
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
TC5Driven
