    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 09-20-2016, 03:29 AM   #20701
Hasi's Avatar
Originally Posted by thecman26 View Post
If I were you I would get the following to upgrade your stock shocks:
91495 X-Ring rebuild kit
91305 (X2) Ti_Nitride shock shafts Rear
91306 (X2) Ti_Nitride shock shafts Front
You're set!
Thank you very much, Chris
Didn't see #91305 and #91306 in the parts list for the B5, so thanks again for pointing me that direction.
Order is placed
Onroad: Tamiya TT-02, Tamiya TA-02SW, Xray T2'008
Offroad: Asso B5, Asso SC5M, Asso B64D, Tamiya Avante 2011 Re-Release
Trucks: Tamiya Mercedes SK 2638 6x6, Tamiya Mercedes 3553 8x4 heavy haulage
Hasi is offline   Reply With Quote
Old 09-20-2016, 03:41 AM   #20702
JsK
JsK's Avatar
Originally Posted by beansor2bacon View Post
Considering a lay down from shapeways for my b5m FL. Before I do tho, curious how a b5m with a lay down stacks up against the new b6. Is the b6 noticeably better than the b5m? Or does a dialed in b5m with lay down contend well against the new car? Considering I run same power plant (17.5) setup in each chassis, does one out perform the other?
I would do a YZ2 gearbox before the shapeways. Its a bit more work but alot better quality.
Are you running on clay or turf/carpet?.
JsK is online now   Reply With Quote
Old 09-20-2016, 05:08 AM   #20703
Trader Rating: 19 (100%+)
Also, if you run the YZ-2 gearbox, you can use the YZ2 shock tower and B6 arms to run the shocks in front
Scott R is offline   Reply With Quote
Old 09-20-2016, 05:30 AM   #20704
sport10's Avatar
After spending all this on a new gearbox diff arms and tower might as well just move up to a b6 imo. It is designed to be able to better run at the lower ride heights needed if you are running carpet and turf. On clay the laydown route is best put into the b6d since it is an 25.00 upgrade.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 09-20-2016, 06:05 AM   #20705
JsK
JsK's Avatar
Gearbox conversion is aboit 60 bucks, front mounted shocks are not really needed on all but
the highest grip tracks, 60 bucks is a long way from 310.
Old 09-20-2016, 10:05 AM   #20706
5tone's Avatar
Originally Posted by jabroni racing View Post
Anyone run a 4 gear & 3 gear transmission and can yu tell me the difference in feel??? All ive even know is AE 3 gear, last car was a b4, looking at a b5m & have option of either trans
4 gear is a little more stable and offer a little more on power traction
3 gear is more directive on brake/off power, and more handy on jumps
5tone is offline   Reply With Quote
Old 09-20-2016, 10:09 AM   #20707
What is the yz2 conversion? I did the shapeways conversion and it's ok, but would prefer something that feels a little more solid . . .
mupchu is offline   Reply With Quote
Old 09-20-2016, 04:42 PM   #20708
Thanks everyone for your input and information. I should have mentioned in the initial post, but im running on high bite clay. I believe the yz2 conversion is the gearbox from the Yokomo yz2, as well as its motor plate....could be wrong.
I think if i do end up converting the car to a laydown, ill go yokomo for quality sake.
beansor2bacon is offline   Reply With Quote
Old 09-20-2016, 10:59 PM   #20709
JsK
JsK's Avatar
Basicly your installing a YZ2 box in your B5. The front 2 gear box holes need to be opened up a bit with a dremel. You can still put your old gear box back in if you like.
2 More rear gearbox holes need to be located and drilled, you will also need to drill the new holes for the water fall brace. Last you will need to fabricate a small plate
from the gearbox to the shock tower. The gearbox comes as a kit(YOKZ2-302C3) with the 2 halves, motor plate,and idler. You will reuse your topshaft and diff.
http://site.petitrc.com/setup/associ...erlin20151101/
Old 09-21-2016, 06:28 PM   #20710
thecman26's Avatar
Trader Rating: 99 (100%+)
Order is placed
No problem! I did this to my T5M (granted different shafts since I didn't want to buy the Kashima shock bodies and all that is required for that. Made the shocks SUPER smooth!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 09-21-2016, 07:04 PM   #20711
aeRayls's Avatar
What all do you think is require for the kashima bodies?
You can use v2 shafts/Pistons with either the stock bodies or kashimas. Every part is completely interchangeable with either.
aeRayls is offline   Reply With Quote
Old 09-21-2016, 10:47 PM   #20712
thecman26's Avatar
When the Kashima shocks came out it was announced you had to change to the V2 shafts and pistons. That's a decent chunk of change for the broke guys out there... Either way the kashimas are stupid pricey and not totally necessary IMHO. I could get some kyosho velvets for less $ and they were always expensive to guys on a budget! But with the ti-nitride shafts and x-rings I think they're almost as smooth as velvets.
Old 09-22-2016, 08:09 AM   #20713
jkas10's Avatar
Trader Rating: 121 (100%+)
Hate to have to tell ya, but you broke your right rear arm and lost your left rear swaybar link. In case you hadn't noticed...
Jeremy Kasten - Cole's Pitman! (Dad); Kasten Racing: www.facebook.com/kastenracing
THANK YOU Sponsors: Mugen Seiki; REDS; AKA; Leadfinger Racing; NitroPro Fuel; RC Addiction Products; Dialed-RC Hobbies; Ben Brocato Designs (BDB); PT RC Racing Oils
jkas10 is offline   Reply With Quote
Old 09-22-2016, 09:58 AM   #20714
aeRayls's Avatar
That's a false assumption. You do NOT need to use v2 shafts with them. All parts are completely interchangeable.
No matter if you use the kit shock bodies or the kashima's they both accept the same internals(kit or machined) same orings or xrings, v2 shafts and Pistons or kit shafts and v1 pistons.
The kashima bodies are a better coating and they do provide slightly smoother shock action. Value or worth is up to each user.
Old 09-22-2016, 05:28 PM   #20715
thecman26's Avatar
My bad; nonetheless the kit bodies, ti-nitride shafts, and x-rings make for a smooth shock!
