    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 07-29-2016, 02:39 AM   #20536
Phillip F's Avatar
Trader Rating: 17 (100%+)
Guys my B5M lite stalls after a few laps especially landing hard on a jump and bottoming out. I took out the fan on my motor and the problem went away. Does anybody had any problem similar to my experience. Really need the fan to keep the motor temp down. Is it the reciever that I am using? I run the stock telemetry receiver that came with the Futaba 4PLS radio system the Futaba R304SB Receiver and the LRP Flow Works team ESC.
Phillip F is offline   Reply With Quote
Old 07-29-2016, 01:24 PM   #20537
twindad98's Avatar
Trader Rating: 18 (100%+)
Have any of you gone back to the original b5m setup? Gullwing arms and b5m rear arms?
I may try it Wednesday to see how I like it.
TLR 22 3.0
TLR 22-4
TLR 22T 2.0
RC8.2e
Sticky Kicks RC - Voodoo Racing Cells - Dialed Hobbies
twindad98 is offline   Reply With Quote
Old 07-29-2016, 01:25 PM   #20538
eper's Avatar
Trader Rating: 14 (100%+)
sounds like theres a short in the fan or the fan wiring. try a new fan
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 07-29-2016, 02:14 PM   #20539
Phillip F's Avatar
I have another fan in the mail.. But fyi this fan is like 1 month old and functions well.
Old 07-29-2016, 02:24 PM   #20540
Suspended
Trader Rating: 61 (100%+)
I would contact LRP and change the speed controller.
Best Avatar on rc-tech
Socket is offline   Reply With Quote
Old 07-30-2016, 01:01 AM   #20541
That's what I run, but I race on carpet
To finish first, you must first finish.
B6
I get my rug burns at Northwest Hobbies.
_danimal_ is offline   Reply With Quote
Old 07-30-2016, 01:23 PM   #20542
Phillip F's Avatar
Default Diff outdrive
Anybody knows if someone sells a more heavy duty diff outdrives. Mine got chewed up by the dogbone pins. And is there a dogbone or cvd/cva that has the pins going into the outdrive REMOVABLE or REPLACEABLE? I remember MIP had those for the RC10GT ... They we're called CVDs back then.
Old 07-30-2016, 08:57 PM   #20543
eper's Avatar
prettybsure they can all have the pins pressed out
new milford ct,
Old 07-30-2016, 09:08 PM   #20544
suby723's Avatar
Trader Rating: 21 (100%+)
edit
suby723 is offline   Reply With Quote
Old 07-30-2016, 09:29 PM   #20545
Originally Posted by suby723 View Post
So I just got done racing on a low/med bite track with my b6 laydown. I was the only one to even have a laydown car in the facility. I was very close on fastest lap times. I went to this race thinking my car was going to be undrivable and it completely exceeded my expectations. This laydown car can be successful on a low bite surface with the correct setup.
Good to hear but this is the b5 thread should share it in the b6 thread as well
Slashn77 is offline   Reply With Quote
Old 07-30-2016, 09:45 PM   #20546
suby723's Avatar
Wrong thread lmao oops
Old 07-30-2016, 10:46 PM   #20547
JAE
Trader Rating: 28 (100%+)
Just get MIP pucks if you're worried about outdrive wear. You'll have to replace the plastics pick over the pin every 5-10 race days but problem solved and you'll accelerate faster
JAE is offline   Reply With Quote
Old 07-31-2016, 01:21 AM   #20548
Phillip F's Avatar
good idea. I will do that after the next rebuild.
Old 08-02-2016, 10:01 AM   #20549
twindad98's Avatar
You guys that have added the 3rd hole in your front arm did you adjust your droop?
TLR 22 3.0
TLR 22-4
TLR 22T 2.0
RC8.2e
Old 08-02-2016, 10:08 AM   #20550
aeRayls's Avatar
Yes, you typically use 22-22.5mm with the 3rd hole
aeRayls is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Dmkiefer
