    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree15Likes
Old 07-18-2016, 10:27 AM   #20506
Default New guy
I just bought a B5m. It is in very good condition, but it didn't come with any of the shims or additional pieces that a new kit comes with. Has anyone come across a place to buy these pieces in a package or do i need to order them seperately?
MisterLeon is offline   Reply With Quote
Old 07-18-2016, 11:06 AM   #20507
JAE
Trader Rating: 28 (100%+)
http://www.schelleracing.com/Schelle-Racing-Shop-By-Brand-Team-Associated/Schelle-Associated-B5-B5M-Products/Schelle-Aluminum-M3-Black-Ballstud-Washer-Set-SCH1209?limit=100
JAE is offline   Reply With Quote
Old 07-18-2016, 03:46 PM   #20508
how does changing the shock offset cups affect the handling? The stock setup suggests the 5deg cups, but how would the others affect the handling?
Cousinwilly is offline   Reply With Quote
Old 07-18-2016, 04:34 PM   #20509
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 158 (100%+)
Not at all, they are not a tuning option. They are there to better achieve ride height in certain situations and / or take up slack when running different sized springs. AE produces 2 sizes of springs, front and rear. The larger 9mm cups are used primarily on the trucks, the 5mm on the buggy and the 0 offset on the buggy when trying to achieve a lower ride height.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 07-18-2016, 04:37 PM   #20510
It was a good run, but I suppose it's time to move on. Zero complaints from the B5m, so kudos to AE for that. Was running the ACRC 3 gear laydown trans off of Shapeways and had no problems with it either.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 07-18-2016, 06:35 PM   #20511
tsair's Avatar
Originally Posted by Phillip F View Post
sweet.... let us know how the B5M drives with the B6 diff gear.
4k (kit wt) seems about right, it's smooth but a little more vague. Especially if you turn it in your hands from forward to back, it's not as immediate.
No leaks, probably not faster than a ball diff on dirt, but works well for my buggy as an RTR for my kids.
Razor RC blog:
http://razorrcblog.blogspot.com
http://youtube.com/c/RazorRC
tsair is offline   Reply With Quote
Old 07-18-2016, 10:03 PM   #20512
i noticed the b6d has smaller rear shock bodies than the b5m, yet has the same shafts and ride height (minus the limiters). What effect does the smaller shock bodies have?
Old 07-19-2016, 04:24 AM   #20513
eper's Avatar
Trader Rating: 14 (100%+)
i believe that ae went with the smaller shock body on the 6 to get as much weight as they could as low as they could which is great for higher grip and higher corner speed. the bigger(longer) shock body is going to be easier to drive on bumpy tracks with bigger jumps. thats what i gather from it anyway
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 07-22-2016, 10:54 PM   #20514
so i already know i'm way behind on trying out the 3 gear trans but after seeing my brother run his i'm gonna try it out. i'm also gonna try out the vrp pistons for the first time. looking forward to playing this weekend
mel_russ615 is offline   Reply With Quote
Old 07-25-2016, 08:17 PM   #20515
gotta say i dig the three gear transmission. i was looking through amain and i saw the schelle 0.5mm offset caster blocks. does anyone have these and what are your thoughts about them?
Old 07-26-2016, 08:26 AM   #20516
JAE
Default Wide turning radius
Picked up a 1 race day b5m lite for my 8yr old. Turning radius is wide. Tires were right. Checked kick up and its 25 degrees. added roll. Still seems like a wide arc. Anyone know if this is common? I have not built a b5m and would appreciate any tips. Thanks!
Old 07-26-2016, 08:39 AM   #20517
DennisNyholm's Avatar
Could it be something as simple as the epa on your transmitter? Or are you saying it is pushing?
DennisNyholm is offline   Reply With Quote
Old 07-26-2016, 09:03 AM   #20518
Trader Rating: 24 (100%+)
Move the battery forward, Run a 3 gear trans, stiffer rear springs, check to make sure the previous owner didnt install steering stop screws
Scott R is offline   Reply With Quote
Old 07-26-2016, 10:15 AM   #20519
Default shock shaft piston washer/perch
I have bent this M2.5 washer on the rear shock shaft "perch" a few times now (new one from Home Depot Racing shown here). By "bent" i mean the inner washer hole hogs out allowing the piston to drop to the bottom of the shock.
Question: does this have to do with the amount of limiters/ amount or droop ? or something else. thanks for any insight.
Team Associated RC10 B5m Mid-Motor Thread-screen-shot-2016-07-26-9.10.15-am.png
hsp-sandiego is offline   Reply With Quote
Old 07-26-2016, 11:32 AM   #20520
JAE
Did most this but will try the battery forward. Not something Ive seen others have to do with oher b5m lite's ive driven. Have white springs all the way around. Are there steering block shin adjustments or Ackerman adjustments on these? Thx all!
