    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-12-2014, 09:49 AM   #2026
Please post your setup, and what is the surface?
buyselltradeevy is offline   Reply With Quote
Old 03-12-2014, 09:56 AM   #2027
bilster44's Avatar
Originally Posted by rigor View Post
. Starting to bum me out.
You will find something from someone out there...heck, you live in the "hub" of all rc practically.
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 03-12-2014, 10:06 AM   #2028
rigor's Avatar
Trader Rating: 37 (100%+)
On my way into the office. I'll give further details once I get there. I am lucky enough to be in OC and see a lot of pro drivers at OCRC regularly.
* Jesse H. *
rigor is offline   Reply With Quote
Old 03-12-2014, 10:08 AM   #2029
Default loose rear end
May sound kind of simple, but make sure you don't have to much drag brake. My b5m with box set-up has been really good from the first run.
retat is offline   Reply With Quote
Old 03-12-2014, 10:13 AM   #2030
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
If you race OCRC why not chat it up with hartson. maybe have him take your car for a spin to give you feedback.
Have you tried Kody's OCRC setup? You have the engineer for the car racing there, I would definitely tap into that knowledge.
http://www.teamassociated.com/pdf/ca...C_Numedhal.pdf
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 03-12-2014, 10:22 AM   #2031
What up?'s Avatar
Trader Rating: 14 (100%+)
Rigar,
Ask Walnuts or Hartson for set up help, OCRC should be pretty locked in but if it was on the new track layout it wont be as locked in as it normally is.
I ran my car for the first time this last weekend at JBRL and my car pushed like a dump truck because my tires where new and not broken in. I borrowed a set from a buddy that had broken in foam and the car was way better without any set up changes.
I ended up running white k springs all around with 32.5 in the front and 30 wt ae oil and 1.6 piston front and back. Ride height was 23.5 f and 23 r car was good and with a little more time I will be used to it.
Josh Mitchell
Speedtechrc.com / Team Orion USA / Airtronics / Proline / Bartalone Racing / rcinsider.com / 818Designs
What up? is offline   Reply With Quote
Old 03-12-2014, 10:25 AM   #2032
D.Martijn's Avatar
So, anyone that drove this can on an outdoor track?
I'm still not sure what to buy, a B5 or a B5M..
Almost all the tracks in my country are astro or carpet. only my local track is hardpacked dirt (with a thin layer of dust in the summer) + there are some parts that are carpet/astro.
Any suggestions wich car would be the best?
D.Martijn is offline   Reply With Quote
Old 03-12-2014, 11:05 AM   #2033
TheBlueKnight's Avatar
Trader Rating: 19 (100%+)
Originally Posted by What up? View Post
Rigor- I ran my car for the first time this last weekend at JBRL and my car pushed like a dump truck because my tires where new and not broken in. I borrowed a set from a buddy that had broken in foam and the car was way better without any set up changes.
+1. Would your buddy with the Serpent that you say is super dialed in be willing to let you do a few laps with his rear tires off his serpant? That would be a huge help to determine if your rear tires aren't up to par.
Traxxas Summit and 3.3 Revo
TheBlueKnight is offline   Reply With Quote
Old 03-12-2014, 11:16 AM   #2034
Can or has someone dome a fr and RR weight bias with their buggy with a shorty to the rear and a saddle or square to the rear plz . thnx
Mike Richardson
At the track having fun with my friends
blingy is offline   Reply With Quote
Old 03-12-2014, 11:29 AM   #2035
Rigar,
So where do the white K springs fall in the associated world?
The chart I've seen shows the measured rate no where near the claimed rate.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875 vs Tekno EB410, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 03-12-2014, 11:30 AM   #2036
daravelli's Avatar
Hey guys, can someone give me a diameter on the hinge pins? Need to pick up some shims on the way home and forgot to measure. Thanks!
Hot Bodies Ve8 - Sold
Traxxas E-Revo - Sold
1/16 Traxxas E-Revo VXL - MMP Castle 5700kv - Sold
OFNA Ultra GTP-2E - Sold
Team Associated B5m
daravelli is offline   Reply With Quote
Old 03-12-2014, 11:30 AM   #2037
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
3mm
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-12-2014, 11:40 AM   #2038
Finally got the wiring finished so now time to get out and practice!
chancejeff is offline   Reply With Quote
Old 03-12-2014, 11:53 AM   #2039
lol, your receiver is bigger than your speedo, lol. GL with the new car.
Old 03-12-2014, 11:58 AM   #2040
mugenhatchie's Avatar
Soooo... Am I the only one that is having the rear end want to slide around on them pretty bad on hairpins / 180 turns? The cars feels like it has potential, and while it's not bad, it's not great either. I just cannot push it is hard as I want to drive it. It feels fairly edgy. I've tried a couple different spring and oils combinations in the rear, and I can get it a little better, but not great. Any ideas? I'm at the point where I might need to move on from the car if I cannot get it better within another week or two. I've driven my friend's Serpent mid motor, and its feels the way I think my B5m should. It just drives easier, handles the corners way better, and it's just a nice kit with a few features the B5m doesn't have, for only $40 more. I'd like to get this B5m dialed like everyone else is claiming they have theirs. Kind of confused at this point. My buddy who is a mechanical engineer and quite good with tuning cars is a little stumped how to help at this point. Both of us agree the car just feels edgy to drive and my car hooks consistently on sharp corners. Starting to bum me out.
Can you post your setup? I'm running 1.7 rear pistons, green springs, 1mm rear camber ball stud washers, camber link on middle hole on hubs, top shocks mounted on inside hole, lower shocks mounted on outside hole, and .5 toe inserts in the rear hubs.
Granted this suits my driving and it does rotate faster than my rear motor ever does but I wouldn't say I have any issues hooking up. Another thing is I am running less drag brake than I do with my rm. 10% vs 20% on my rm.
mugenhatchie is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
