    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree16Likes
Old 05-24-2016, 05:57 PM   #20326
Cridd's Avatar
Trader Rating: 16 (100%+)
Originally Posted by Phillip F View Post
Do you guys have a noticable play in your B5Mlite front steering block? I observed this after a couple of batteries at the track.
Yes I have alot of play in rack and front end. Mine actually could use a rebuild but from the git go I had some play.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 05-24-2016, 06:10 PM   #20327
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
yep, I glued my inserts in. I look forward to NOT doing this on my b6
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-24-2016, 08:39 PM   #20328
I hope so but don't be so sure. Sometimes it's not worth it or they can't fix certain things with out glue or other improvising
Slashn77 is offline   Reply With Quote
Old 05-24-2016, 09:14 PM   #20329
Phillip F's Avatar
Trader Rating: 17 (100%+)
thanks for the tip... I glued the inserts now and it helped .
Phillip F is offline   Reply With Quote
Old 05-24-2016, 09:16 PM   #20330
Phillip F's Avatar
kindda odd for that amount of play for a newly built kit. Design flaw?
Old 05-25-2016, 06:02 AM   #20331
Trader Rating: 24 (100%+)
Mine is Rock Solid, all stock parts too
Scott R is offline   Reply With Quote
Old 05-25-2016, 06:05 AM   #20332
thecman26's Avatar
Trader Rating: 99 (100%+)
The steering, yep, a WELL KNOWN issue! Why else would the B6/B6D have gone away from the 2 piece front knuckles?
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 05-25-2016, 09:08 AM   #20333
Default Initial Transmitter (MT-4) Setup for B5M Recommendations?
Hello. I am new to hobby. I purchased a used B5M Lite that has been outfitted with Savox 1257 servo (new), 17.5 Reedy Mach 3 Motor (used), JustStock Hobby Wing ESC (new). I waiting arrival of new Airtronics MT-4 Transmitter/Receiver. Car will be run on indoor high bite clay track.
Please recommend any initial settings for the Transmitter with regards to servo speed and any other transmitter set up that will help get best feel and general baseline. I have baseline set up for car at this particular track so looking for some Transmitter help.
I understand this can be subjective / personal style but any general recommendations would be appreciated that may improve overall experience and accelerate learning curve. I will not be signing up for races anytime soon. My goal is to run lots of laps to be consistent and as fast as possible.
rrwj is offline   Reply With Quote
Old 05-25-2016, 10:50 AM   #20334
I am new too, <3 months, but I have the same car and ESC, Transmitter. This is the most important thing-- "My goal is to run lots of laps to be consistent and as fast as possible."--However I would club race as soon as you feel comfortable in traffic just to get the experience. Everyone has a first time, mine was last Saturday.
As far as the MT-4, my advice isn't B5M specific. First thing is to set the steering sub-trim so your wheels are straight when you power up. The only other things I have done is to set the Throttle D/R to one of the programmable buttons, as well as the Braking D/R to another programmable buttons. This way I can turn either up or down quickly without going in the menu. Braking I like to mess with while I practice, throttle I don't too much but sometimes I turn it down for a new track and various other tuning things (diff break in). One thing with the ESC is I would turn off drag brake to start and practice without it to get used to braking on your own. THen maybe adjust after you have practiced with it off.
That's all I got but like I said I am new too, so maybe someone else has other advice.
40yoCaliRacer is offline   Reply With Quote
Old 05-25-2016, 05:36 PM   #20335
I have the factory lite that I run with a Mach 3 stock and mod and have a anny edition Mt4s and you really don't have to adjust anything on the radio except for endpoint settings for turning and throttle and of course trim settings just to make minor adjustments to make sure your car is going in a straight line on a flat even surface
Old 05-25-2016, 05:55 PM   #20336
Hi All,
With the delay of the B6d, I decided to get a B5M Factory Lite to get into off road racing (have been racing on road, and will do both) before I get a B6D next year.
I've been doing some research and reading up on this forum, but with 1356 pages its tricky to follow what people have done with the car.
Just wanted some advice on the initial build and things to look out for/change/setup differently.
So far I have looked at gluing the inserts in as per above (will run the car first), build the diff as per videos on page 1 incl sanding the discs and slipper pads then running it in, and just made sure everything was lined up properly. I havent done shocks or turnbuckles as yet, and electrics. Motor/ESC is Reedy 800z+17.5T, Sanwa MT4S radio and Savox 1258TG servo. Shorty pack batteries.
Also looking to upgrade to aluminium steering very soon!
Thanks.
Quantum RC
Team Associated B6D /// XRAY XB4 '17 /// Kyosho M3 Evolva
total3d is offline   Reply With Quote
Old 05-25-2016, 06:08 PM   #20337
Silverstonev8's Avatar
Originally Posted by total3d View Post
Hi All,
Thanks.
Use x-rings when you build the shocks
Silverstonev8 is offline   Reply With Quote
Old 05-26-2016, 01:54 AM   #20338
Phillip F's Avatar
What's pretty odd is in the span of 2 weeks, I built 2 brand new B5M lite kits and both of them have the same slop in the caster block. Maybe it's a quality control thing or you bought it used and the former owner already addressed that issue. ....or there's a batch of kits out there with good caster blocks.
Old 05-26-2016, 01:55 AM   #20339
Phillip F's Avatar
x-rings..... part number? ... and why use that instead of the stock ones?
Old 05-26-2016, 03:28 AM   #20340
Do you have a packaging date for the two kits? Our two kits were July 2015 and seem ok.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
