    Hide Wikipost
R/C Tech Forums Thread Wiki: Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 04-16-2016, 08:43 AM   #19696
xfbaap's Avatar
Default Aluminum Bellcrank Set
Has anyone else purchased an Aluminum Bellcrank Set for there b5m or even t5m? Ive got the associated version and had to trim the servo case and chassis with a hobby knife to have enough clearance for the servo horn and ballstud. Im running a low pro savox and still had to trim. Now ive seen 3 other brands,jconcepts,rdrp,strc and every review is saying that they all bend and dont fit proper. Does anyone have any feedback??
xfbaap is offline   Reply With Quote
Old 04-16-2016, 08:48 AM   #19697
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
You may have to trim the servo case depending on servo. You should not have to trim any part of the chassis. When the T5m came out people started bending/breaking them and many went back to the plastic. JConcepts stopped production on theirs to revise it but havent seen anything come out stating that its been done. Most run the plastic version with no issues.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-16-2016, 03:46 PM   #19698
xfbaap's Avatar
OK thanks. Im j in the process of building a b5m from scratch. I just got the protek screw kit, fast eddy bearing and a prime waterfall brace. Ive heard that some bodies dont fit if you want to run a fan on the brace. I know that the jconcepts finsisher fits with no issues but I kinda like the proline phantom with the center spliter. Any idea if that would fit
Old 04-16-2016, 04:33 PM   #19699
Super Moderator
Doubt it, but couldn't tell you. The finnisher sits the highest so thats what most use with the waterfall brace fan mount.
Old 04-16-2016, 05:54 PM   #19700
Tim Johnson's Avatar
I'm just starting my B5M Lite. Any tips or things to watch out for during the build?
_______________________________________________________
Support your Local Hobby Shop, because you can't race on Ebay!
Airtronics|Kyosho|
Tim Johnson is offline   Reply With Quote
Old 04-16-2016, 07:08 PM   #19701
JC8390's Avatar
I would get the caged thrust bearing just because I don't like to mess with building the kit bearing. If I were doing it again I would build it with the titanium screw kit to begin with but that only applies if you want to drop weight.
8ight E 4.0
Orion| Hobby Wing| Savox| Turnigy| AKA
RC10 B5M CE
Fantom| HobbyWing| Savox| Turnigy| JConcepts
JC8390 is offline   Reply With Quote
Old 04-17-2016, 06:55 AM   #19702
RCBuddha's Avatar
Trader Rating: 35 (100%+)
I'm in the process of updating and verifying all the links in the first page's Aftermarket section (found a few that didn't work).
If there any links you want to see for products that are not already on there, please PM me or post to the thread.
RCBuddha is offline   Reply With Quote
Old 04-17-2016, 11:28 AM   #19703
I just finished my B5M CE a couple weeks ago. My advice on the ball cups is to use the boiling water method instead of the squeezing with plier method. I just heated up a cup of water in the microwave for a minute or two. After installing the turnbuckles to the ball cups, I put a mini screw driver head through the ball cup and just let them sit in the the water for a minute. Flipped them over to the other side and did the same. When I put them on the ball stud they moved freely. Unfortunately, I didn't do this the first time around and had to do some breakdown when my front suspension was so tight it would just stay up when I pushed it up.
40yoCaliRacer is offline   Reply With Quote
Old 04-17-2016, 01:17 PM   #19704
F18engineguy's Avatar
Trader Rating: 216 (100%+)
Default 3 gear conversion
Is there a list anywhere of what parts are needed to do it three gear conversion from a 4?
VA Beach
F18engineguy is offline   Reply With Quote
Old 04-17-2016, 01:40 PM   #19705
JC8390's Avatar
You'll need the gear box, gear cover and motor plate for sure.. the only other thing I can think of would be the top shaft. Not sure if theyre the same or not. The CE topshaft does both.
8ight E 4.0
RC10 B5M CE
Old 04-17-2016, 02:03 PM   #19706
thecman26's Avatar
Trader Rating: 99 (100%+)
The best advice on tight ballcups, is IF you get tight ballcups, email AE and they will ship you out new ones as this issue has been fixed already.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 04-17-2016, 02:26 PM   #19707
I advise you to do the glued in caster block insert (91400) alteration even though the set scew (4670) method would be superior
Team NovakŪ (1-touch programming)
Team Orion
ProLine
Dialed-RC Hobbies
TEN-SCTE 3.0/22SCT 3.0
Keith B is offline   Reply With Quote
Old 04-17-2016, 05:07 PM   #19708
Trader Rating: 31 (97%+)
building my first kit... b5m lite ,
after hours of contemplating between kits.... lol...
28 yrs in the hobby and this is my first kit...so should be interesting..
What are some must have upgrades? during the build?
Running mod set up, clay to hard pack dirt outdoor tracks
Thanks for the input guys !
plumber007 is offline   Reply With Quote
Old 04-17-2016, 05:49 PM   #19709
Pville Stig's Avatar
You have a good car to start with. Don't get caught up with the upgrade bug until you have run a lot of laps and feel the car is holding you back.
Pville Stig is offline   Reply With Quote
Old 04-17-2016, 07:25 PM   #19710
AZJP's Avatar
Trader Rating: 20 (100%+)
If running mod, build the kit to box setup. Get the correct turn motor for your layout, a few pinions for gearing tuning and most importantly the correct tire package for your track. Once you can run 10 consecutive laps without a mistake, start making changes to shave tenths off your time. Modified cars really need nothing as far as hopups go on a lite.
AZJP is offline   Reply With Quote
